help with GAMELOFT GAMES.
9 replies to this topic
#1 shawnlee6184
shawnlee6184
  • 118 posts
Posted 16 June 2013 - 04:33 PM
I got nova 3 and it keeps freezing wondering if I did a different build prop if it helps and which one works the best? Thanks
#2 Guest_BDH_*
Guest_BDH_*
Posted 16 June 2013 - 09:30 PM
Did you overclock or underclock your phone?
#3 shawnlee6184
shawnlee6184
  • 118 posts
Posted 17 June 2013 - 12:19 AM
Yes
#4 Guest_BDH_*
Guest_BDH_*
Posted 17 June 2013 - 12:53 AM
Yes
Lol which one?
#5 shawnlee6184
shawnlee6184
  • 118 posts
Posted 17 June 2013 - 01:45 AM
I tryed not over clocking it froze still. I was over clocked tho.
#6 shawnlee6184
shawnlee6184
  • 118 posts
Posted 17 June 2013 - 01:46 AM
Do u by any chance have a torch app or the RAZR torch app its a clear flashlight icon
#7 shawnlee6184
shawnlee6184
  • 118 posts
Posted 17 June 2013 - 01:47 AM
I tryed changing my build prop too I forgot I put that on there. It didn't work either. Have u played the game?
#8 Guest_BDH_*
Guest_BDH_*
Posted 17 June 2013 - 01:53 AM
I don't have a torch app. I have played Nova 3 but my phone is a Galaxy S3.
Sent from my SCH-I535 using Tapatalk 4 Beta
#9 shawnlee6184
shawnlee6184
  • 118 posts
Posted 17 June 2013 - 02:42 AM
I think it might just be the app. It happens when the enemies come out and some big dude in the garage. Its in the very beginning u have to go dwn in a garage. I think thats what causes it is all the guys at once. I was just wondering if anyone knew a way around it. It happened when I had it before but only once or twice at that part now it happens right away every time I try to play. My phone was set up a little different before with tweaks. It could be that but the part im talking about is on the list on the customer support website. Maybe a script or something for loading quick or killing apps when I'm playing or something. I fell like it could be apps running or something. But I tryed killing apps then playing. It didn't work. I have no idea.
#10 biggiesmalls657
biggiesmalls657
  • 74 posts
  • Google+:biggiesmalls657@gmail.com
  • LocationUSA
Posted 28 June 2013 - 10:32 AM
what about memory tweaks to make it smoother/
