"Insufficient Storage Space"
13 replies to this topic
#1 larrygeary
larrygeary
  • 160 posts
  • LocationNJ, USA
Posted 14 June 2013 - 09:33 AM
Sorry if this has been discussed before, but I have a problem. I'm using SafeStrap 3.11 and have one ROM (slot 1) besides stock. It was created with 1 Gb of Data space. Now that it's been running a few weeks, I am getting "Insufficient Storage Space" messages when some apps try to automatically update. It isn't consistent. Yesterday two apps failed. Today a bunch updated and all succeeded, including the ones from yesterday. The system says I have 141Mb left in "app and data storage".
Any suggestions? And Hashcode, would you consider the option of allowing additional system space in the next update?
#2 garywojdan81
garywojdan81
  • 633 posts
  • Twitter:gwojdan_81
Posted 14 June 2013 - 10:47 AM
First off, the app& data storage capacity fluctuates because of what gets kept in open apps individual cache files. The system manages those files during operation in order to keep the foreground apps running, but if you have background apps updating + a lot of/large foreground apps running you're going to run out of room periodically. Once the caches get cycled out you get more room for updates.
Since you only have one ROM on the unsafe side the best thing to do is to back it up, then delete & recreate slot 1 with a 2gb data partition. Then you can restore your backup, wipe cache/dalvik & reboot. You will have lost nothing but 15 minutes and doubled your favorite ROMs operating capacity.
  • larrygeary likes this
#3 larrygeary
larrygeary
  • 160 posts
  • LocationNJ, USA
Posted 14 June 2013 - 12:49 PM
Thanks. My misunderstanding was in my assumption that I needed more system space for the apps, not more data space. I did as you advised, and I now have 1.02Gb free space for apps, where before it was about 167Mb.
#4 garywojdan81
garywojdan81
  • 633 posts
Posted 14 June 2013 - 02:02 PM
Glad to help
#5 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
  • Current Device(s):Razr Maxx
Posted 13 October 2013 - 01:45 PM
Glad to help
Evening Garywojdan...
How do I get more Data Space or Storage to Flash another Slot?
Need 1975 to create a New Slot...Most I can get is 400mbs...Moved Pictures, Vids, Deleted unnecessary Backups and Apps...Cleaned Caches
What's left to do...
#6 garywojdan81
garywojdan81
  • 633 posts
Posted 14 October 2013 - 08:49 AM
Hey man, sorry to get back to you late... If it were me, I'd go thru my ROM slots & pare down what you haven't used in awhile. With ss3.6 you can flash anything to the stock slot to use as a daily driver, then free up that space for safestrap to use.
How many ROM slots do you have active?
Where are your backups stored? This got me after I upgraded to ss3.6. It defaulted to internal storage for backups so I ate up a lot of room without realizing it.
Sent from my Nexus 10 using Tapatalk 4
#7 robocuff
robocuff
  • 415 posts
Posted 14 October 2013 - 09:00 AM
Maybe give
 a try.  It won't get rid of stuff for you but it will show you what's using what when it comes to your phone storage space.  It might point out something you haven't noticed already.
  • The Persuader likes this
#8 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 14 October 2013 - 10:39 AM
Maybe give
RBC...
You're Da Man my friend:)
Its Bubba
#9 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 14 October 2013 - 10:49 AM
Maybe give
RBC...
Twrp and Backup...Aren't they one in the same?
If that's the case i have double Backups...
Its Bubba
#10 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 14 October 2013 - 03:05 PM
Maybe give
You are absolutely correct...Its Points out what is taken Lots of Space...Reviewed the Apps and Misc and picked up 2000 MBs to Flash another Slot and enough for a Backup as well...
Thanks my good Friend...Awesome, Awesome App...Gives you a Point In Time with Apps Stealing your MBs....Woooo-Hoooo
I Love Flashing...
To Bad the Junk doesn't support the Run... :p  :o You Idiot
Over and Out...Its Floppy
#11 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 15 October 2013 - 06:32 AM
Question I have 3 ROMs that are backed up in restore can I move them to my Internal SD card to get more space on my External SD card? Its Bubba "Stubborn In Your Bones"
#12 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 15 October 2013 - 07:18 AM
Question I have 3 ROMs that are backed up in restore can I move them to my external sd card to get more space on my internal sd card?
Its Bubba
Note...Internal SD to External SD...
The result are...Yes!!!
It does increase space on your Internal SD card...
Awesome...
What I might try is to flash it from the External at some point...or bring back or swap out ROMs
:D
Its Bubba
#13 robocuff
robocuff
  • 415 posts
Posted 15 October 2013 - 07:42 AM
I've always kept all ROMS on the external sd. They flash just fine from there.
  • garywojdan81 and The Persuader like this
#14 The Persuader
The Persuader
    Droid Elite
  • 2,009 posts
  • LocationMaine
Posted 15 October 2013 - 07:56 AM
[quote name="robocuff" post="364335" timestamp="1381851772"]I've always kept all ROMS on the external sd. They flash just fine from there.
Sent from my DROID RAZR using Tapatalk[
Thanks for All your Tips with Storage...never New I could do this...
Oh boy oh boy its now going to be a flashing Fiasco
Your the Best!!!
Its Bubba
