[Cdma Razr][Ics Leaks .84-.85] [Rom] Simplexrom - Droidrazr - System Build 6.14.84(5/10/12) | 6.14.75(5/19/12)
#161
Posted 11 May 2012 - 06:06 PM
#162
Posted 11 May 2012 - 06:38 PM
using unbrick now...bummer
#163
Posted 11 May 2012 - 06:55 PM
#164
Posted 11 May 2012 - 07:22 PM
Two things i noticed:
When going to the gallery from the camera, it takes you to album view...normally that goes to the last picture taken. Not sure if that's possible or not.
Also, i use Ubuntu one, and it force closes fairly often.
And something else that may or may not be me...swype didn't show suggestions, but then I switched to other input methods then back to Swype and it started showing them again.
Awesome Job, Outstanding for sure!
#165
Posted 11 May 2012 - 07:26 PM
Which system build were you on? Matter of fact I'm going to remove the. .75 from this thread to limit the confusion...
.84
#166
Posted 11 May 2012 - 07:29 PM
#167
Posted 11 May 2012 - 07:31 PM
#168
Posted 11 May 2012 - 07:32 PM
.84
Curious. Shouldn't have caused that issue. Ive flashed this more then everyone put together multiple times! Lol. But i haven't encountered that... wipes prior to install?
#169
Posted 11 May 2012 - 07:35 PM
I'm no quitter...going to try again once I reroot. Going to let the ole battery get some juice first after all that unbricking process. Right before I tried I had bootstrap hang on me so maybe it was doomed from the start.
Lol. Now thats the spirit! Especially woth a rom in early stages! Haha. I honestly try to have as little bugs as possible. But trust me when I say even if everything is exactly as it should be... some will still have issues! Stupid phones!!!! ;-) haha
#170
Posted 11 May 2012 - 08:25 PM
#171
Posted 11 May 2012 - 08:45 PM
#172
Posted 11 May 2012 - 09:06 PM
#173
Posted 12 May 2012 - 04:37 AM
This time everything is super smooth...must have been a bad flash. Great work!
Sounds good man.
#174
Posted 12 May 2012 - 06:57 AM
#175
Posted 12 May 2012 - 08:00 AM
?Thanks for the ROM even if it doesnt work for me. Its all learning...BTW I used safestrap enabled
#176
Posted 12 May 2012 - 08:07 AM
#177
Posted 12 May 2012 - 09:18 AM
Need a little help....I was running DT Axion Kang off 173. I read thru every post and it seemed as though you could flash 75 over 173. I thought I read it worked. So I preceded to use Matts utility to wipe everything then I flash the 75 leak. It installed fine but went black screen after M logo. Did I need to leave DTs latest build in place and just wipe cache and Dalvick? Or am I completely off track and 75 would not work over 173.
75 over 181
#178
Posted 12 May 2012 - 09:20 AM
Any interest in seeing SimplexROM with a touch of Sony Xperia?
I likey. Flashed your rom last night and running great. Battery life is better than stock. Awaiting more updates brother!
#179
Posted 12 May 2012 - 10:11 AM
Or.???
#180
Posted 12 May 2012 - 10:12 AM
Also tagged with one or more of these keywords: rom, ics, razor
