[Cdma Razr][Ics Leaks .84-.85] [Rom] Simplexrom - Droidrazr - System Build 6.14.84(5/10/12) | 6.14.75(5/19/12)
#141
Posted 10 May 2012 - 06:50 PM
#142
Posted 10 May 2012 - 07:12 PM
#143
Posted 10 May 2012 - 07:27 PM
#144
Posted 10 May 2012 - 07:46 PM
#145
Posted 11 May 2012 - 03:04 AM
I had no issue with the notification bar. Just my icons resetting due to using a different launcher. I really need to remember to backup my apex settings. Did a cache wipe only, runs great as did earlier!
Wipe data if you wanna loose it... ;-) lol
#146
Posted 11 May 2012 - 06:14 AM
#147
Posted 11 May 2012 - 06:53 AM
everything works great, i just keep getting "unfortunately, Calendar has stopped" and "unfortunately, Clock has stopped" messages every like half an hour.
Unfortunately I can do any testing to see why you would be getting that on .85. I can tell you on .84 its not happening. You could attempt to clear data for both of those apps in the app manager.
#148
Posted 11 May 2012 - 07:01 AM
#149
Posted 11 May 2012 - 07:38 AM
#150
Posted 11 May 2012 - 08:03 AM
I'll pass for now, maybe next beta i'll try it. :-P
#151
Posted 11 May 2012 - 08:08 AM
Does someone have a link to give me?
#152
Posted 11 May 2012 - 08:38 AM
#153
Posted 11 May 2012 - 08:42 AM
I pulled it. I shoild have a new link up tonight though.
Alright! Thanks man
#154
Posted 11 May 2012 - 09:09 AM
#155
Posted 11 May 2012 - 11:48 AM
#156
Posted 11 May 2012 - 12:12 PM
Is the same update also going to be for the .75 build as well.
This thing is fast. Thank you.
#157
Posted 11 May 2012 - 01:15 PM
Is the link you're putting back tonight the Beta from last night?
Yes... but with accurate battery removed. It causes issues with data wipe and losing notification bar. I think i know what the issue is now though. But it turns out im working late tonight so the link may have to wait until tomorrow
#158
Posted 11 May 2012 - 01:17 PM
#159
Posted 11 May 2012 - 03:20 PM
#160
Posted 11 May 2012 - 05:47 PM
- crpp2401 likes this
Also tagged with one or more of these keywords: rom, ics, razor
