[Cdma Razr][Ics Leaks .84-.85] [Rom] Simplexrom - Droidrazr - System Build 6.14.84(5/10/12) | 6.14.75(5/19/12)
rom ics razor
274 replies to this topic
#121 jerkwad
jerkwad
  • 109 posts
Posted 10 May 2012 - 05:02 PM
the widget thing wasn't a big deal, but i was surprised that the widgets disappeared - i had assumed they were part of Apex, not the homescreen.apk stuff - interesting but no big deal - already put it back the way it was. Yeah, the white on white is exactly as you described, no big deal - there are other ways to do it...great job man - so far so good (again). Thanks for your efforts!
#122 0rion_black
0rion_black
  • 17 posts
  • Twitter:0rion_black
  • Google+:busablack
  • LocationUnion, NJ
Posted 10 May 2012 - 05:05 PM
I wiped cache/data forgot to wipe Dalvik and my notification bar is gone as well.
#123 jerkwad
jerkwad
  • 109 posts
Posted 10 May 2012 - 05:09 PM
i did NOT wipe dalvik the first time and retained my notif bar - i went back, re-wiped cache and dalvik and i still kept my notif bar...odd that others are experiencing this!
#124 theonlycosmic
theonlycosmic
  • 470 posts
  • LocationCalifornia
Posted 10 May 2012 - 05:19 PM
Yea my notification bar is gone yet I wiped everything. Not /system of course but data, cache and dalvik.
#125 theonlycosmic
theonlycosmic
  • 470 posts
Posted 10 May 2012 - 05:22 PM
I had hicks' theme flashed if that makes a difference...
#126 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 10 May 2012 - 05:23 PM
I donwloaded another file and flashed over without wiping data. I only wiped cache and dalvik. Still missing the bar. I guess Ill restore the backup and follow instructions :)
#127 EmericanX
EmericanX
    Developer
  • 1,027 posts
  • Twitter:@EmericanX
  • LocationPrince George, VA
Posted 10 May 2012 - 05:27 PM
Hmm... I think I may pull the file for now. Three of you'll tested all day no issues... now people losing they're notification bar! Haha... let me know what you get trikotret....
#128 mina.girgis
mina.girgis
  • 83 posts
  • LocationEast Brunswick, New Jersey
Posted 10 May 2012 - 05:59 PM
i wanna try it, it should work on .85?
#129 EmericanX
EmericanX
    Developer
  • 1,027 posts
Posted 10 May 2012 - 06:03 PM
Ok I can confirm that the issue is the data wipe. The latest update has the 1% mod included. Problem is it causes systemui to crash unless it is flashed after a first full boot. I have removed the link for the night. I will address the issue tomorrow. For those currently without a status bar. You've got two options. #1 restore from nandroid. #2: as I just did to confirm this working. Reboot to cwm. Wipe data&cache. Flash the alpha. Reboot. Allow the phone to boot completely. At this point you can stay there or reflash the latest BETA without wiping data!!! Data wipe is definitely whats causing the issue.
#130 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 10 May 2012 - 06:12 PM
I can confirm that wiping data is the problem. I restored my back up. I wiped cache and dalvik cache and flashed the new update. My status bar is back :D
#131 EmericanX
EmericanX
    Developer
  • 1,027 posts
Posted 10 May 2012 - 06:20 PM
Ill be digging into the issue to trt to find resolution. Until I do a simple fix will be needing to boot the rom before flashing a theme or 1% mod...
#132 mina.girgis
mina.girgis
  • 83 posts
Posted 10 May 2012 - 06:32 PM
i am gonna try flashing it over .85, wish me luck!
#133 mina.girgis
mina.girgis
  • 83 posts
BTW, thanks X for adding the date :D
#134 jerkwad
jerkwad
  • 109 posts
It will probably work... Good luck! ;-)
#135 mina.girgis
mina.girgis
  • 83 posts
Posted 10 May 2012 - 06:35 PM
thanks :) do i need to flash the base first? or is it ok to flash only the beta?
#136 jerkwad
jerkwad
  • 109 posts
Posted 10 May 2012 - 06:39 PM
thanks do i need to flash the base first? or is it ok to flash only the beta?
Excellent question. I would defer to X for that info... Probably just need the beta...I think the base was an earlier stage of the beta. But I would wait to hear from X
#137 mina.girgis
mina.girgis
  • 83 posts
Posted 10 May 2012 - 06:43 PM
i only flashed the beta, now it says android is upgrading :)
good job on the boot animation X
#138 mina.girgis
mina.girgis
  • 83 posts
Posted 10 May 2012 - 06:46 PM
yeah i lost my notification bar!
#139 jerkwad
jerkwad
  • 109 posts
Yeah, I dig the animation too. Simplicity (and quiet lol)
#140 jerkwad
jerkwad
  • 109 posts
Did you wipe /data?
Also tagged with one or more of these keywords: rom, ics, razor
