[Cdma Razr][Ics Leaks .84-.85] [Rom] Simplexrom - Droidrazr - System Build 6.14.84(5/10/12) | 6.14.75(5/19/12)
rom ics razor
274 replies to this topic
#241 tankdroid
tankdroid
  • 36 posts
  • Twitter:@Tank_oZ
  • LocationBirmingham, Alabamastan
Posted 19 May 2012 - 04:13 PM
Thanks for fulfilling my addiction to flashing Roms. Loving it, seems to work flawlessly. Just wondering... is there any way to get rid of the google search bar at the top of the screen?
If you are using Apex, go into the Homescreen settings.
#242 EmericanX
EmericanX
    Developer
  • 1,027 posts
  • Twitter:@EmericanX
  • LocationPrince George, VA
Posted 19 May 2012 - 04:14 PM
Download apex launcher from the market. You could remove the static search bar then.
#243 EmericanX
EmericanX
    Developer
  • 1,027 posts
Posted 19 May 2012 - 04:17 PM
@tank.... nice man.. thanks for letting everyone know it works on .79 as well!
#244 mikeymax
mikeymax
  • 102 posts
Posted 19 May 2012 - 08:03 PM
Hey....I installed this ROM on. 79.....how the heck so I get back to clean. 79? So basically I am asking how to uninstall this without doing the whole thing again? I can't do that again!
#245 EmericanX
EmericanX
    Developer
  • 1,027 posts
Posted 19 May 2012 - 08:08 PM
if you made a nandroid you could restore. I don't have a /system pull for .79 so theres nothing I can do for you on my end as of right now.
#246 mikeymax
mikeymax
  • 102 posts
Posted 19 May 2012 - 09:19 PM
OK that's fine.....figured I would check, I actually cleared up the issues and I'm cool with it. Hey does your simple blue theme work on my setup? .79 with the. 75 build of this ROM? Or you not sure?
#247 EmericanX
EmericanX
    Developer
  • 1,027 posts
Posted 20 May 2012 - 06:59 AM
I didn't build the blue theme but I'm pretty sure it was based on the .84 version so I wouldn't recommend trying it.
#248 Guest_BDH_*
Guest_BDH_*
Posted 20 May 2012 - 10:19 AM
You are correct. After I finish porting it to your new 84 build, I can port it to the .75 build as well. :)
#249 mikeymax
mikeymax
  • 102 posts
Posted 20 May 2012 - 02:08 PM
Oops! My bad SPC! Was late night and Its tough to tell apart talented peeps like you too!
#250 bmb0y
bmb0y
  • 27 posts
Posted 20 May 2012 - 07:58 PM
build for .75 updated in OP. Remember considered untested and unsupported!
You are the man!!!! I can't wait to flash this.Something to look forward to at work...heehee.
#251 beeryooper
beeryooper
  • 185 posts
  • LocationWisconsin
Posted 21 May 2012 - 10:14 AM
Has anyone tried this with the new safestrap 2.0 and the .84 leak?
#252 jaredgibson82
jaredgibson82
  • 5 posts
  • Twitter:jaredgibson82
Posted 27 May 2012 - 09:05 PM
Just an FYI to anyone who is thinking about flashing the .75 Simplex... I flashed the .75 Simplex over DTs mod and it worked nicely, it was faster than Eclipse on my wife's Razr. I then flashed the 1% and it worked, however I get crazy battery readings. I went from 86% to 49% in less than 2 minutes. I have seen that there are issues with the ICS reading battery stats and levels, so it is probably not an issue with this Rom.
Mine seems to be stuck at 100 percent. Is yours still jumping around?
#253 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 27 May 2012 - 09:20 PM
The battery stats problems is well known with leaks 75-85. Whenever you reboot you'll get like 30% off. Just don't reboot that often
#254 disturbed58
disturbed58
  • 55 posts
  • LocationLancaster, PA
Posted 29 May 2012 - 10:48 AM
Mine did get stuck at 100% for 6 hours and I knew that wasn't right, eventually it dropped back to where it should have been. As mentioned in the above post, its the leaks not the roms. I've used several roms over the 75 and 79 leaks and have had erratic battery stats.
#255 W0017roid
W0017roid
  • 128 posts
  • Twitter:17akota
  • Google+:17akota
  • LocationNorth Carolina/Pennsylvania
Posted 30 May 2012 - 10:29 AM
So i loved your ROM while is was on .75 and since they found out how to update everyone to .206, will we see SimpleXROM for that build? :)
I Just want something that is debloated and the tweeks that you use on the newest build. AOKP and CM9 are cool, but data drops and always having to reboot to get data working again is extremely annoying.
Ill test for you if need be! :)
#256 EmericanX
EmericanX
    Developer
  • 1,027 posts
Posted 30 May 2012 - 10:48 AM
I'm on the fence about it honestly. I've got a project brewing but its based on the AOKP(2nd-init).. I'm sure the data drops will be worked out eventually! I'm not saying I'm not going to do a build based off of the leak... just haven't started one yet.
#257 theonlycosmic
theonlycosmic
  • 470 posts
  • LocationCalifornia
Posted 30 May 2012 - 11:30 AM
Is this AOKP build that is brewing going to be for the leak builds or will it only be for .181.
#258 W0017roid
W0017roid
  • 128 posts
  • Twitter:17akota
  • Google+:17akota
Posted 30 May 2012 - 01:05 PM
Seems like the builds that devs are making works on all the leaks. So, what would need to be done for your ROM to do that? Does it have something to do Safestrap?
#259 EmericanX
EmericanX
    Developer
  • 1,027 posts
Posted 30 May 2012 - 01:54 PM
That's due to them being based on 2init. Which safestrap has been tuned for. This is because the primary developers working on it has been DHacker and Hashcode. Hashcode the developer of safestrap makes sense it would get love over bootstrap! Lol. As of right now I will probably be building off of the same platform. Why you may ask. Well it takes all of the "does this rom work on this leak?" Out of the equation. Thus more people being able to access the rom. Are there issues, sure but in time they will be worked out. There's great guys on the job! Additionally building on 2-init allows building from source instead of decompiling/recompiling/baksmili/smali....
#260 W0017roid
W0017roid
  • 128 posts
  • Twitter:17akota
  • Google+:17akota
Posted 30 May 2012 - 02:00 PM
Got it.
Im want to become a developer someday, but i have to start some college and learn a lot more about coding and all that good stuff rather than just a very little bit of Java. lol
Also tagged with one or more of these keywords: rom, ics, razor
