[Cdma Razr][Ics Leaks .84-.85] [Rom] Simplexrom - Droidrazr - System Build 6.14.84(5/10/12) | 6.14.75(5/19/12)
#181
Posted 12 May 2012 - 10:44 AM
#182
Posted 12 May 2012 - 11:51 AM
@papi. It may work. I honestly don't know myself. I'm pretty sure some have reported it to work. I prefer bootstrap honestly so thats what I work with.
#183
Posted 12 May 2012 - 12:58 PM
If I'm not mistaken... the .75 ics "leak" is an update for .173... You should have been fine but sometimes things don't flash properly. the .84 and .85 leaks are to be flashed coming from .181. If you want to be on .75 you need to flash back completely to .173 boot, root, then protect root. Do not install bootstrap or safestrap.. reboot into stock recovery after you've protected root then install the .75 from sdcard.
You're right. 173 to 75. Sorry for the bad info!
#184
Posted 12 May 2012 - 01:55 PM
#185
Posted 12 May 2012 - 06:41 PM
Sent from my ICS Leak RAZR
#186
Posted 12 May 2012 - 07:30 PM
Hey i upgraded to the beta and i still get a force close on startup for exchange service. Does anyone else have this issue?
No issues here. Check and see if you have more than one exchange services. Plus did you wipe data
#187
Posted 12 May 2012 - 08:30 PM
No I thought i was allowed to only wipe cache and dalvik
#188
Posted 12 May 2012 - 08:51 PM
No this build requires wipe data
#189
Posted 13 May 2012 - 11:22 AM
#190
Posted 13 May 2012 - 02:29 PM
BTW... Ive ended up working all weekend so updates will be off a couple of days... i hope to have something to share soon!
#191
Posted 13 May 2012 - 04:12 PM
#192
Posted 14 May 2012 - 06:53 AM
#193
Posted 14 May 2012 - 07:05 AM
Manage apps> Clock, Calendar, Calendar Storage> Force Stop> Clear Data...I keep getting calendar and clock stopping errors. Flashed twice. Tried deleting app cache. Also tried reinstalling gapps. I know early on in posts it was said this was happening, just didn't know if it was supposed to be fixed in beta 0.3
worked for me, hope it does for u
#194
Posted 14 May 2012 - 08:26 AM
#195
Posted 14 May 2012 - 08:39 AM
#196
Posted 14 May 2012 - 09:08 AM
Someone else posted that he had to exchange services running, so he froze one of them with Titanium backup...and it worked. I tried the same, and I haven't gotten a FC yet.
I'm guessing could have to do with backing up and restoring apps via Titanium. I think i'm guilty of this, restoring the old exchange service, which causes me to have 2 services running. I could be wrong though.
#197
Posted 14 May 2012 - 11:22 AM
#198
Posted 15 May 2012 - 10:17 AM
#199
Posted 15 May 2012 - 11:15 AM
I bricked, brick, brick. Anyone needs an addition on to their house cause I got the bricks
What did you do that led to the brick? I read the post a few back, and I'm trying to understand what it is you're trying to accomplish...
#200
Posted 15 May 2012 - 03:54 PM
I think its because you are trying to go from gingerbread to this rom. you can't do that. at least that's what I understood from all your posts.I bricked, brick, brick. Anyone needs an addition on to their house cause I got the bricks
Also tagged with one or more of these keywords: rom, ics, razor
