That's correct, yes.
[SCRIPT] DROID RAZR HD Utility 1.21 - Windows/Mac/Linux
#81
Posted 07 April 2014 - 03:47 AM
#82
Posted 07 April 2014 - 04:03 AM
#83
Posted 07 April 2014 - 04:15 AM
It's called 30.1 on the FXZ but it's literally the same version. How it shows up on your phone is dependent on a few things, but, it's EXACTLY the same update.
- RikRong likes this
#84
Posted 07 April 2014 - 04:23 AM
#85
Posted 07 April 2014 - 01:34 PM
#86
Posted 07 April 2014 - 01:41 PM
I finished getting your utility running but the flashing fails. I know my drivers are up to date cuz I used this threads utility on my HD a couple weeks ago and it worked fine. The HD I'm trying to fix is getting the encryption unsuccessful error and I thought a clean flash could fix it. I think that's why its not taking
Sam is going to ask for the exact fail and a screenshot/copy of the failed script.
#87
Posted 07 April 2014 - 01:42 PM
#88
Posted 07 April 2014 - 02:00 PM
That I am. I need to see the errors if I'm going to help. Also make sure you're not using a USB3 port and are using the OEM cable that came with the phone. As for the encryption unsuccessful error, you're like the 3rd person now with the HD that I've seen that issue on. In any case, show me the rsd log or copy and paste the fastboot window depending on how you chose to flash it.
#89
Posted 07 April 2014 - 02:12 PM
#90
Posted 07 April 2014 - 03:20 PM
Same nonsense I saw on the other two guy's phones. I really don't know what is going on with the HD's right now. I don't have a fix for this issue. It's not the HoM that's causing it as straight RSD flashing doesn't work, either. I seriously wish I had an answer for you.
#91
Posted 07 April 2014 - 03:25 PM
#92
Posted 07 April 2014 - 03:28 PM
I'd like to get to the bottom of this problem at some point. I may hit up Timmy10Shoes and see if he wants to look into it. Something screwy is going on and I just don't have any way to look at fixing it for you guys. My gut instinct tells me there's a driver issue but I don't know.
#93
Posted 07 April 2014 - 03:31 PM
#94
Posted 07 April 2014 - 03:36 PM
It's happening a LOT on the HD and it has me worried. You're the 3rd case I've seen of it and NOTHING I've had them try has fixed it. It bugs me when I can't help people. But this one's out of my control it seems.
#95
Posted 07 April 2014 - 03:39 PM
#96
Posted 09 July 2014 - 01:06 PM
Question...
It has a big warning of "DO NOT USE THIS UTILITY ON THE LATEST 4.1.2 OTA UPDATE."
I don't remember what my phone had. I just did a factory reset and it it when it started, it was with a sys version of 9.18.94 XT926 4.1.2
Can I use this?
I have already rooted, but I want to unlock the bootloader.
#97
Posted 09 July 2014 - 01:07 PM
Question...
Can I use this?
edit: See
also- Aqua009 likes this
#98
Posted 11 October 2014 - 04:24 PM
After using option 1 of this utility my xt926 is stuck in a bootloop. The install seemed to go alright withougt any error messages, then I used option 2 for the stock recovery, and now it just stays at the "M" logo and reboots.
#99
Posted 11 October 2014 - 04:29 PM
This utility is kinda dated .... Go here and read the directions ..... It will help you out
#100
Posted 11 October 2014 - 04:48 PM
Thank you, I will give it a go and see what happens
