[SCRIPT] DROID RAZR HD Utility 1.21 - Windows/Mac/Linux
102 replies to this topic
#41 RangeOfficer452
RangeOfficer452
  • 50 posts
Posted 20 August 2013 - 02:13 PM
Sees phone with RSD not with Utility
  • rafa721 likes this
#42 RangeOfficer452
RangeOfficer452
  • 50 posts
But fails immediately
#43 RangeOfficer452
RangeOfficer452
  • 50 posts
Posted 20 August 2013 - 06:02 PM
I just tried Mr. Parkinsons utility, it fails at each level, and when it reboots AP Fastboot, the screen goes black and has to be hard reset.......
#44 rafa721
rafa721
Posted 12 September 2013 - 09:37 PM
Will this utility work on 9.18.79? I'm not sure if anyone has said it
#45 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 13 September 2013 - 12:07 AM
DO NOT USE THIS UTILITY ON THE LATEST 4.1.2 OTA UPDATE.
^^^In the OP.
#46 bweN_diorD
bweN_diorD
  • 69 posts
Posted 13 September 2013 - 02:21 PM
i have used this on  9.18.79 many times, but im unlocked.
#47 msassounian
msassounian
  • 39 posts
Posted 18 September 2013 - 08:52 AM
If i installed TWRP and want to switch to CWM, can i just run this utility?  do i have to delete TWRP first?
also, are the nandroid backups cross compatible? i googled it and i'm getting mixed answers....
or is there another way to do this if i'm on 9.18.79?  is there a .zip of CWM i can flash (via twrp? haha)
thanks!
#48 bweN_diorD
bweN_diorD
  • 69 posts
Posted 18 September 2013 - 12:58 PM
use this updated version of the recovery flasher
no deleting of your current recovery is needed.
i don't know if the backups are cross compatible, however they would be in the wrong folder by default.
  • Devilalwayscries likes this
#49 msassounian
msassounian
  • 39 posts
Posted 18 September 2013 - 04:04 PM
thank you!  i actually ended up just flashing the CWM .img through an app called flashify... CWM booted up nicely.  just doing a back up now to make sure all is good!
thanks for your help!
#50 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 18 September 2013 - 05:54 PM
thanks!
Back ups are not compatible across the recoveries.  They are saved in different formats.
  • Memnoch73 likes this
#51 Devilalwayscries
Devilalwayscries
  • 93 posts
  • LocationUpstate NY
  • Current Device(s):droid razr maxx hd, og droid razr
Posted 19 September 2013 - 03:28 PM
thanks smoke  exactly what i was looking for :D
  • bweN_diorD likes this
#52 7eregrine
7eregrine
  • 163 posts
Posted 03 October 2013 - 10:39 AM
Well worst case scenario has happened.
Broke the screen on my phone. Paid the deductible to Asurion to get a replacement. They sent one with the older FW so I jumped at Unlocking and Rooting. Loaded Rage and then Blurry.
Now me SD Card slot is failing. It unmounts and remounts a few times a day. Tried a few cards. Same result.
This happened twice before I unlocked but I didn't assume there was an issue.Happened in stock, Rage and now Blurry so I know it's hardware.
Asurion will replace my phone under thier warranty (not an insurance claim).
Can I use this utility to get back to stock including the boot animation (which is now Blurry)?
Will the "WARNING YOUR BL IS UNLOCKED" message return?
Thankfully I've saved the files I need so in the chance that I get another old FW phone I can return...
Wierd part is SD Card always shows in CWM so I can still use it there if need be.
#53 cmh714
Posted 03 October 2013 - 11:26 AM
The answer is yes and no. :)
Matts utility will reset you to stock and should replace the boot animation. However, Matt didnt include the boot logo. Having said that, you can easily flash that after by hand.
HTH
#54 digdug1
digdug1
  • 89 posts
Posted 15 October 2013 - 03:10 PM
I noticed the op says do not use on the latest 4.1.2 ota. Being as I'm new to this phone can I use this to root firmware 9.20?
#55 SamuriHL
  • 44,375 posts
Posted 15 October 2013 - 05:47 PM
No.  Look for motochopper 1.3.
  • ibolski likes this
#56 ibolski
ibolski
  • 535 posts
  • Twitter:iBolski
  • Google+:Ivan Samuelson
  • LocationColumbus, Ohio
Posted 16 October 2013 - 08:42 AM
How can I tell if I'm on the latest firmware 4.1.2? I'm also new to this phone (just got it today as a swap for my RAZR MAXX xt912 which had a swelling battery pack). Darned thing wasn't insured and was out of warranty, but the Verizon store manager went ahead and got me a free replacement for it anyway. Figured I would get another RAZR MAXX, but I guess they don't have them anymore, so they got me this instead!<br /><br />Still running unlimited data too. Gotta love it!<br />
#57 SamuriHL
  • 44,375 posts
Posted 16 October 2013 - 08:44 AM
Post up a screen shot from about phone and we can tell you what you've got and what you can and can't do with the version you're on.
  • ibolski and johnthehillbilly like this
#58 ibolski
ibolski
  • 535 posts
  • Twitter:iBolski
Posted 16 October 2013 - 09:03 AM
Here is my system info. Thanks.
#59 SamuriHL
  • 44,375 posts
Posted 16 October 2013 - 09:07 AM
MR4 eh?  That's certainly interesting.  *IF* it never had been updated to 79 (or 20.1 depending on your point of view...ignore that) it might be unlockable on the current version.  You can certainly root it with the original motochopper posted by Dan.  The one I released is not necessary for that version.  Once rooted, you have to decide whether or not to try your luck with motoapocalypse and unlock it or not.  Let us know what you want to do and we can help you through any of it.
#60 johnthehillbilly
Posted 16 October 2013 - 09:09 AM
If i were you.....I would absolutely attempt to unlock..... then you are "free" ... LOL
