help please =(
tx910 help brick
Best Answer ozorn , 03 June 2013 - 06:55 AM
solved.
Sorry the bad english =)
that's what i do:
in my case i don't downgrade the phone but works any way =)
THIS IF FOR LATAM see europe post link below (forum.xda...)
1) download the OTA from here (http://www.grupoandroid.com/topic/73918-ota-update-retail-brasil-jelly-bean-412/)
 (REMEMBER THAT I WAS ORIGINALLYRUNNING A JB ROM)
2)download the unbrick tool https://mega.co.nz/#...epg6gfqBcUr82eI (HSD-pilot)
3) turn on the phone (fastboot) if you bricked the phone you now how to do it haha
4) conect the phone to the computer and execute unbrick.bat
5) let the phone do all the process (i had to do it twice becuase the first time send me some fails) some times the phone (blink or something like that) after finish the process press enter.
6) after unbrick.rar flashed press power button once, and immediately hold volume up + volume down and press power again and  go to recovery and press volume up
7) wipe data and catche (navigate to factory reset)
8) Then go to install update from external memory and install the OTA that you downloaded (you have to put it to your external SD card)
9) If all is fine it will update, just reboot and its unbricked
original posts:
http://www.grupoandr...tutorial-latam/
http://forum.xda-dev...068&postcount=8
credits for the creators.
Go to the full post
3 replies to this topic
#1 ozorn
ozorn
  • Google+:ozorn66@gmail.com
  • Locationmexico
  • Current Device(s):tx910 max
Posted 02 June 2013 - 10:54 AM
Hi!
first sorry for the bad english.
My phone (XT910) was bricked and I try to flash it again with RSD Lite 5.6.
But I try many firmware and all of this get this error (Failed flashing process. 1/01 flash cdt.bin "cdt.bin_signed" -> Phone returned FAIL.)
also I try whit the eternity project flash tool
can you help me bring my phone back
my rom was 4.1.2
an before that i erase the cid (because my phone is LATAM, and works fine, until i saw the official release for my country soo i put on it and restore de cid whit bmm and get here =(
help please
#2 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 02 June 2013 - 10:01 PM
I would also try using an updated RSD Lite.  I failed to fastboot on your version of RSD, but when I upgraded to 6.1.4 I was successful.
  • shane1 likes this
#3 ozorn
ozorn
  • Locationmexico
Posted 03 June 2013 - 06:08 AM
thanks i try but didn't work
#4 ozorn
ozorn
  • Locationmexico
Posted 03 June 2013 - 06:55 AM   Best Answer
solved.
that's what i do:
 (HSD-pilot)
original posts:
  • shane1 likes this
Also tagged with one or more of these keywords: tx910, help, brick
