XT912 GSM
gsm xt912 motorolla phone problem
5 replies to this topic
#1 csss
csss
Posted 01 June 2013 - 08:12 AM
Hi,
I have a little big problem, i flashed my xt912 yesterday with a cyanogenmod rom but i couldn't connect to the gsm network. I think it is a rom problem because it says that xt912 works with CDMA but i need a GSM rom.
Where can i find a gsm rom or what can i do?
Guido
#2 cmh714
Posted 01 June 2013 - 08:17 AM
Some ROMS have a GSM version and the CDMA version. Also there are often GSM patches you can use to make the cdma rom work as GSM.
ZKK007 wrote a GSM how to in the forum, you can look there.
Or you can get the correct version of cm for gsm phone:
#3 csss
csss
Posted 01 June 2013 - 08:41 AM
how can i see if there is a cdma rom or a gsm rom?
#4 cmh714
Posted 01 June 2013 - 08:46 AM
its usually in the OP for the rom....spyder=cdma and umts_spyder=gsm
#5 csss
csss
Posted 01 June 2013 - 08:50 AM
Ohh thanks
#6 aktrazer
aktrazer
    SMod/News Team Leader
  • 537 posts
  • LocationGreensboro, NC
  • Current Device(s):Smasung Galaxy Note 2, ASUS TF700T
Posted 05 June 2013 - 04:32 AM
Moving to general.
Also tagged with one or more of these keywords: gsm, xt912, motorolla, phone, problem
