There is no unlock after update and that unicorn will probably never be seen again.
You don't think another exploit will be found?
Posted 21 August 2013 - 04:23 PM
Posted 21 August 2013 - 04:24 PM
Also, FYI, you need to create a ROM slot in SafeStrap to be able to flash a ROM. You can't flash over the stock ROM. The flash you're doing now will probably fail, too. You'll probably need to restore your backup or RSD back to stock.
I used MAtt's Utility to put back on the stock rom.
Posted 21 August 2013 - 04:26 PM
Nope. The guy that found this one is currently retired. It's a sad day for this and many future Moto phones. You can thank VZW. :
Posted 21 August 2013 - 04:29 PM
Is it possible to remove the update from the bootloader to re-enable the exploit?
Posted 21 August 2013 - 04:30 PM
Nope. You can root, but that's it.
Also, glad you got it worked out with the utility.
Posted 21 August 2013 - 04:31 PM
Yeah, Matt's Utility has saved my phone multiple times. I hope someone finds a way to unlock the bootloader. I'd praise them.
Posted 21 August 2013 - 04:39 PM
It's saved mine too.
Posted 21 August 2013 - 04:47 PM
Do you think this would work if I wanted to put this ROM as my stock?
Because I just want my stock rom to be Deodex, so I can customize it.
Posted 21 August 2013 - 04:50 PM
Yeah, that should work. Personally, I haven't tried it, but when the bootloader was first unlocked, I was able to restore a SafeStrap backup with TWRP. So, the backup part does work. If you do that, I would completely set up the ROM in slot 1, first. Get it how you like it, back it up, then try that method. If it doesn't work, well, you know how to use the utility, so you should okay.
Posted 21 August 2013 - 04:52 PM
Yeah. That's what I'd do. By the way thanks for all the helpful insight into everything.
Posted 21 August 2013 - 04:54 PM
No problem. When you get it up and running, come back and let us know how it worked out.
Posted 21 August 2013 - 04:55 PM
Well, I have it install on slot1 already, now to just install all my stuff and start customizing.
Posted 26 August 2013 - 03:55 PM
Posted 26 August 2013 - 04:09 PM
If I Download this and flash it in cwm will I loose my unlocked boot loader??
No
Posted 07 October 2013 - 03:12 AM
Interested in a version for the Australian XT905 - did you make any progress on this or did you never received the files?
Posted 16 November 2013 - 11:50 PM
i need help finding the right program and the right firmware to get my phone back working.
it is a razr m on verizon of course and my phone instantly boots to the ap fastboot flash mode (s) screen and it wont load past it i can use the selection to get into fastboot mode but that is THE ONLY option i have, is to go into AP Fastboot mode. so im guessing i have to flash.
i have tried Matt's utility so that did not work.
but this is the idea of what my phone screen shows me
Device is locked, status code:0
Battery: low
transfer mode:
USB Connected
No valid piv block in sp for system
piv validation failed (system)
fastboot reason: boot failure
usb connected
Posted 17 November 2013 - 12:41 AM
Here are the fxz files for the 905:
Battery: low
transfer mode:
USB Connected
usb connected
Since your battery is low, you won't be able to fastboot. Power off the phone and charge it for about 12 hours, then try again. That's probably why the utility didn't work.
Posted 17 November 2013 - 03:04 PM
well this is what happens,
I power phone off (phone screen is off)
i plug it in to the default usb wall outlet and
it brings up the same screen and im not sure how to make sure its charging
Posted 17 November 2013 - 04:29 PM
update on whats going on at this point.
the battery is on
"ok"
and everything on the utility says "OKAY"
except for when it says
"Preflash validation failed"
FAILED (remote failure)
Posted 17 November 2013 - 08:06 PM
the battery is on
"ok"
i think you trying to flash the link that rikrong posted and it isnt the one for you man.. read... you need flash this one.
if not thant use
