[BASE ROM] VZW_XT907_4.1.2-9.8.1Q-66-1 (Updated: 6/6/2013)
80 replies to this topic
#41 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
  • Twitter:@timpohladthomas
  • Current Device(s):MOTO X
Posted 05 July 2013 - 11:40 AM
downloaded twice on PC. Downloads in about a second.
Hmm, same on my phone... Something is squirrelly. I will check it out and get back to you.
  • lowvolt likes this
#42 DevilMind
DevilMind
Posted 06 July 2013 - 01:53 PM
plz make one more file for Razr M XT905 the Australian version of razr m
plz plz plz
#43 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 06 July 2013 - 06:27 PM
plz plz plz
May be possible if you can find me a system.img and boot.img... Too busy to look myself.
#44 Pr0digy
Pr0digy
  • 57 posts
  • LocationLawrence Kansas
  • Current Device(s):Razr M (retail) Samsung Vitality (Sitting unused) iPad 2
Posted 08 July 2013 - 09:44 AM
download it from
(AZ) Main Server
(CO) Mirror #1
(CO) Mirror #10
as (IL) Mirror #5 is zero bytes :D
By the way guess who has a working computer again :ph34r: ;)
  • timpohladthomas likes this
#45 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 08 July 2013 - 09:51 AM
download it from
(AZ) Main Server
(CO) Mirror #1
(CO) Mirror #10
Glad to know some of the mirrors work. Thought it was something on my end.
#46 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
plz plz plz
Any luck? Google sbf Droid developers
#47 am03b4
am03b4
  • Current Device(s):Defy
Posted 06 August 2013 - 11:47 PM
any somebody help me step by step  how to flash this zip?
thank you
#48 dbreezy187
dbreezy187
  • 6 posts
Posted 19 August 2013 - 01:33 PM
I can't get this to flash in tarp 2.5... says error executing update binary in zip... where could I find flashable deodexed stock rom
#49 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 19 August 2013 - 03:19 PM
Try rebooting recovery after you wipe, and then mounting system.  Most stock ROMs don't have a mount script included.
#50 Corton
Corton
  • 12 posts
Posted 20 August 2013 - 07:38 PM
Is this something I can flash over my stock rom to deodex my phone? I'm kind of new to all this.
#51 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 21 August 2013 - 02:38 AM
If you have an unlocked bootloader, yes.
#52 Corton
Corton
  • 12 posts
Posted 21 August 2013 - 03:24 AM
Can't just flash it like on rsd? Via fastboot?
#53 jco23
jco23
  • 414 posts
Posted 21 August 2013 - 03:42 AM
not this file.  this is flashable via TWRP/CWM only.
install TWRP and you'll be glad you did.
ROM: OSE KitKat 4.4.2
#54 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 21 August 2013 - 04:36 AM
Like JCO said, this is recovery flashable.  You'll need a .xml to flash in RSD.  I think you can flash normal .zip files through fastboot/ADB, but I'm not sure how.  However, the issue is mute if you haven't unlocked your bootloader.  In that case, you can only use SafeStrap for some ROMs or RSD for the FXZ files.
#55 Corton
Corton
  • 12 posts
Posted 21 August 2013 - 02:31 PM
Could I do safestrap and flash this into my stock rom through there? Because I was a dumb rear end and took the latest update, that blocked the Bootloader exploit. :(
#56 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 21 August 2013 - 02:52 PM
Should be able to.
#57 Corton
Corton
  • 12 posts
Posted 21 August 2013 - 02:57 PM
Hmm, I may try it and get back to you. :) if all else fails I'll just flash stock back on.
#58 Corton
Corton
  • 12 posts
Posted 21 August 2013 - 04:04 PM
Okay, so  tried to flash to my stock rom via Safestrap, it failed. Then when I tried to reboot into my phone it wouldn't even let me and put me into the AP Fastboot, so I'm flashing a stock rom at the moment. Does anyone know if there's a way to unlock the bootloader after the latest update? Sorry for the double post. :/
#59 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 21 August 2013 - 04:07 PM
There is no unlock after update and that unicorn will probably never be seen again.  :(
#60 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 21 August 2013 - 04:23 PM
Also, FYI, you need to create a ROM slot in SafeStrap to be able to flash a ROM.  You can't flash over the stock ROM.  The flash you're doing now will probably fail, too.  You'll probably need to restore your backup or RSD back to stock.
