Phone returned failed in RSD lite XRT912
10 replies to this topic
#1 G912G
G912G
  • 5 posts
Posted 28 May 2013 - 06:02 PM
Hello All, I need help with my new XRT912 which I managed to destroy after a failed rooting.
The phone went to Encryption failed mode.
I tried to flash it via RSD lite using a stock ROM.
Flashing process never starts, I get a "Phone returned fail" message.
File is:   cdma_spyder_9.8.2O-72_VZW-16_1ff
Does somebody know how to tackle it?
Guy
#2 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 28 May 2013 - 06:05 PM
Use
utility. Option 1. Should get you going.
  • johnthehillbilly likes this
#3 johnthehillbilly
Your best bet is to try this ....
(All In One!)#entry227369
That is Matt's latest utility for the RAZR ....:)
Got Ninj'd :blink:
tapadriving.....hillbilly style
  • Memnoch73 likes this
#4 Memnoch73
  • 5,016 posts
Posted 28 May 2013 - 06:09 PM
That is Matt's latest utility for the RAZR .... :)
Got Ninj'd :blink:
:wub:)
#5 G912G
G912G
  • 5 posts
Posted 28 May 2013 - 06:18 PM
Hi there, thanks.
I have used it, it seems to have a similar problem, the utility sends the first MBM 512KB .... and stays in that message, no progress.
#6 cmh714
Posted 28 May 2013 - 06:20 PM
Are you using the Motorola usb cable or something else? Also we have seen problems with USB 3.0 ports
#7 johnthehillbilly
Posted 28 May 2013 - 06:23 PM
Just to cover all the bases...... you have the most current drivers installed?.... using OEM USB cable? ..... 2.0 USB port....
Dang... ninj'd again LOL :blink:
Must be getting slo in my old age LOL
#8 G912G
G912G
  • 5 posts
Posted 28 May 2013 - 06:27 PM
I am using an original motorolla USB cable via USB2. Drivers are uptodate from motorola website.
#9 G912G
G912G
  • 5 posts
Posted 28 May 2013 - 07:45 PM
[*] Simple Razr Restore
[*] Windows Version
[*] Created by mattlgroff
[*] Before continuing, ensure your Razr is in the
[*] "AP Fastboot" mode and connected via USB.
[*] Be VERY aware! This WILL wipe your userdata, including contacts, apps, etc.
[*] I am not responsible if this wipes your internal sdcard, and you should
[*] backup anything worth it to you to your external sdcard and computer before
[*] you choose to continue. You can exit now with the X button on this window.
[*] WARNING: Do not do this at LOW BATTERY! You have been warned!
[*] Press any key to continue.
        sending 'mbm' (512 KB)...
#10 G912G
G912G
  • 5 posts
Posted 28 May 2013 - 08:00 PM
In RSD lite similar communication problem:
               1/14 flash mbm allow-mdmloader-flashing-mgm.bin. -> USB error occured while reading/writing.;phone connected.
#11 FareakyGeek
FareakyGeek
  • 29 posts
Posted 07 February 2015 - 03:23 PM
do not use hub ports use rear usb ports if you are using desktop then that is going to solve the issue.
