[How-To] Create Your Own Bootlogo (RazrHD, RazrM, RazrOG, Bionic Sizing)
bootlogo razrhd razrm howto bionic razr help learning center of things
67 replies to this topic
#1 zooyork0721
zooyork0721
    All Around Man
  • 979 posts
  • LocationNew York, NY
Posted 27 May 2013 - 10:44 AM
So you want to make a Bootlogo? :) came to the right place
This How to is sized for Razr HD, Razr M, Bionic, and Razr OG (yes...the flip phone)
(I believe you can follow this with any phone, just remember your sizing will be different so make sure to use the right sizing for your phone)
What is the Bootlogo? The bootlogo is the Red Motorola M in the picture above. It appears right after you hit that power button to turn on your phone
1. Easiest way is to start by downloading this stock Motorola M logo.bin http://d-h.st/1Cr
2. See how its named logo.bin? Change the bin to raw
. (Photoshop only, Gimp users you should be fine with bin)
3. Then place a black layer over the M to hide any unwanted colors or pictures
4. Drag your image in!!!
5. Size to your liking :) remember it needs to be within 540x540
6. Merge into one layer
From here it depends if your using Photoshop or Gimp so fellow accordingly!
Photoshop-
1. Photoshop: select Image > Adjustments > Channel Mixer
2. Select Output channel: Red and change the red value from 100 to 0 and the blue value from 0 to 100
now select Output channel: Blue and change the red value from 0 to 100 and the blue value from 100 to 0
press okay
Note: the colors will look invert and might seem weird, but thats the right way! Your phone will see it normally (why? i have no idea!)
3. Photoshop: select file -> save as
name "logo.bin"
format "photoshop raw"
save
__________________________________________________________________________________________________________
Gimp-
(I dont use gimp so you might be better off following this link :)
http://www.droidrzr....go/#entry327528)
1. Gimp: select Colors -> Components -> Channel Mixer
press okay
3. Gimp: select file -> export
name "logo.bin"
select "All Files" from drop-down menu
expand the "select file type (by extension)" menu and select "raw image data"
export!
You have just made your first Boot Logo!
Before Installing anything like this be sure to be at least 50% battery!!!! its important
Im not responsible for anything that happens to your phone due to your misreading or not understand if you dont understand something i am more than happy to answer any question asked.
Be sure to understand everything before flashing, as like flashing anything else
Installing for RAZR HD and RAZR M
Now to get that sucker onto your phone :)
(For RAZR HD and RAZR M ONLY)
Manual way-
ADB- code;
fastboot flash logo logo.bin
Easy way-
1. Download this flashable zip i put together :) Link-http://d-h.st/xMH
2. Replace the logo.bin already in the zip with yours!
3. Copy the zip to your phone
4. Flash that thing!
5. An awesome custom bootlogo you made all by yourself will appear :D
Installing the Bootlogo for the RAZR OG and Bionic
1. Download this ZIP  (Link- http://d-h.st/roF)
2. Unzip the ZIP
3. Place the logo.bin you just made or one of your liking sized 540x540
(Windows Users place in Main folder with the LOGO FLASH.bat, Mac or Linux Users place the logo.bin in the folder called " files")
4. Windows - Run LOGO FLASHER.bat
Linux- Run LOGO FLASHER.sh
6. Follow the prompt :)
7. Enjoy your AWESOME new Bootlogo :)
This How-To too hard to follow, or you dont have Photoshop, or Gimp? Feel free to request one on my thread for Razr HD, and Razr M. I am willing to make one of your choice :)
Pm me with any questions
  • zipikiki, usmcamgrimm, johnthehillbilly and 5 others like this
#2 Guest_BDH_*
Guest_BDH_*
Posted 27 May 2013 - 11:53 AM
Hell yes!! Thanks for posting this zoo!
*bookmarked* lol
  • zooyork0721 likes this
#3 livinginkaos
Posted 27 May 2013 - 12:01 PM
I'm thinking you guys are on a roll here :) Keep 'em coming! This is awesome stuff!
#4 jeremym
jeremym
  • 53 posts
  • Google+:linuxfan24@gmail.com
  • LocationDubuque, Iowa
  • Current Device(s):Droid Razr HD MAXX Galaxy Nexus, Xoom LTE
Posted 27 May 2013 - 09:11 PM
By renaming logo.bin to logo.raw nothing will open it up.  I tried a few different raw photo editors for linux with no luck.  One tried to open it but said its not a raw format.  I tried Gimp but it wouldnt even try to open it.
#5 zooyork0721
zooyork0721
    All Around Man
  • 979 posts
Posted 27 May 2013 - 09:25 PM
sorry about that. That part was meant for Photoshop. I don't use gimp what do you think is best to use for gimp? Or can you import the bin just fine ?
#6 johnthehillbilly
Posted 28 May 2013 - 06:44 PM
There is a plugin for gimp (Linux) that will allow it to handle the .raw file...... I would link to it but I honestly forgot where I got it :wacko:
Talk to our good friend Google LOL
tapadriving.....hillbilly style
#7 johnthehillbilly
Posted 28 May 2013 - 07:10 PM
Also....FYI .. the sizing is the same for the OG RAZR / MAXX and the bionic ..... so that opens it up to a wider group :)
Thought you might want to know that :)
Not sure if the flashable.zip will work on those ones tho.... but you all know me.... I will try it just to see.... :)
#8 zooyork0721
zooyork0721
    All Around Man
  • 979 posts
Posted 28 May 2013 - 07:20 PM
oh alright :) didnt know! lol didnt have either. yeah i think i read somewhere that the og razr and bionic need to use ap ? so i dont think the flashable zip will work, but i will look around and will add some [spoiler]'s to add some more devices ;) thank you
- if anyone wants a device added just tell me
#9 nine5raptor
nine5raptor
  • 371 posts
  • LocationMO
  • Current Device(s):Droid Bionic, Droid Razr M, Nexus 5, Moto X
Posted 29 May 2013 - 07:23 PM
Thank you for these! Just flashed the boot loader warning as I bought my HD unlocked with the original M logo back on it. Wanted the warning just for fun :-)
Sent from my Red Swingline Stapler
#10 PantherVT
PantherVT
  • 17 posts
  • Twitter:RaiderVT
Posted 04 June 2013 - 03:07 PM
Gimp user here, neither .bin or .raw formats are working for me.  Has anyone found a work around for Gimp?
#11 zooyork0721
zooyork0721
    All Around Man
  • 979 posts
Posted 04 June 2013 - 03:15 PM
i do not use gimp but maybe try this? :)
http://digital-photo...dows-the-basics
hope it helps!
#12 somber73
somber73
    Ringmaster
  • 466 posts
  • Twitter:@xSomber73
  • LocationNY
  • Current Device(s):Razr M
Posted 09 June 2013 - 10:11 AM
Thanks for the tut my screen came out great :) JBaTDni.png Gave me a reason to start up PS again lol thanks
#13 johnthehillbilly
Posted 09 June 2013 - 10:13 AM
That's pretty wicked :) nice work
  • somber73 likes this
#14 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 09 June 2013 - 10:18 AM
Thanks :) I can put up a flashable zip if anyone else would like it. Like I said the tut helped a lot i kept screwing up the colors didn't know about adjustment
#15 johnthehillbilly
Posted 09 June 2013 - 10:26 AM
I think that's a great idea..... :) while the flashable won't work for me I would like the image :)
tapadriving ...... hillbilly style
#16 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 09 June 2013 - 10:54 AM
Heres the bin http://www.mediafire...2q8nu5/logo.bin
And the zip http://www.mediafire...ockBootlogo.zip
Enjoy Glad ya like it
  • PantherVT likes this
#17 johnthehillbilly
Posted 09 June 2013 - 10:58 AM
Thanx :)
#18 zooyork0721
zooyork0721
    All Around Man
  • 979 posts
Posted 09 June 2013 - 03:26 PM
nice work bro! glad i could help, would you mind if i put that up on my bootlogo thread? :)
#19 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 09 June 2013 - 04:34 PM
Sounds good to me bud :) Sharing is caring lol
#20 romma1
romma1
  • 127 posts
Posted 19 June 2013 - 08:37 AM
Is there anyone willing to help me make a boot logo if I supply the logo? I do not have either program on my computer...
Also tagged with one or more of these keywords: bootlogo, razrhd, razrm, howto, bionic, razr, help, learning center of things
