Ics Question
Posted 22 April 2012 - 09:25 AM
Im a nnob and to tell the truth very confused,
is there a working ICS rom for the GSM version?
and by working i mean a stable one with h/w accel camera gps etc.
if so which one and how can i install it?
thanks for your help
Posted 22 April 2012 - 09:59 AM
Posted 22 April 2012 - 10:03 AM
am i wrong?
Posted 22 April 2012 - 11:06 AM
From what i understand the ROM in the link yiu posted is not suitable for GSM RAZR (xt910) but only for xt912
am i wrong?
You are correct. Completely overlooked the the fact that the question was GSM related. Post removed
Posted 22 April 2012 - 12:28 PM
Posted 22 April 2012 - 12:50 PM
i have a general question for the xt912... on the leak is there anyway to have the toggles in the notification bar? i had it on aokp and i dont know if theres an app or something? thanks
I did see a post about pulldown toggles on any stock ROM. Have it saved to my SD right now but scared to use it on the leak because I haven't read up on if it works with ICS. Try searching Google for "toggles stock rom" and see a if u find it. If ur daring enough to try it, let me know if it works.
Posted 22 April 2012 - 01:03 PM
Try this:
Works awesomely on the ICS leak, especially if you make it a system app
Posted 22 April 2012 - 05:21 PM
Post your own thread, don't hijack someone elses. Especially when the thread is in the GSM section and you are asking about CDMA issues.
Back on topic, as posted by nitro there is a leak but depending on how patient you are it may not be 'stable'. But if you want ICS as badly as everyone else does for some reason give it a go and report back, I'm sure all the other GSM owners that are wondering the same thing would appreciate it.
:-D :-D
Posted 22 April 2012 - 08:02 PM
Try this:
Love this app!
