Best Droid Razr Rom
Posted 20 April 2012 - 04:45 PM
The question is : what is the best rom for our phone? I mean...exist a better rom than arctic?
Posted 20 April 2012 - 04:52 PM
Hi guys! After tried arctic rom i've realized that the razr can go speedy.
Only way to find out is to flash all of them then decide for yourself. We all like different aspects of the available roms. What's great for me may not be for you. I must say that I'm a fan of the aokp ports!
#3 Guest_BDH_*
Posted 20 April 2012 - 05:11 PM
Posted 20 April 2012 - 05:53 PM
Sent from my DROID RAZR using Tapatalk 2 Beta-6
Posted 20 April 2012 - 06:12 PM
Posted 20 April 2012 - 08:18 PM
See now for me, the stock ICS leak has been the only ROM I've run longer than 7-10 days. I REALLY like it "stock". Go figure, lol.
Have your tried DTs mid script. I tried both for a couple days and like that a lot too
Posted 20 April 2012 - 08:37 PM
There is no such thing as the 'best' ROM. It is 100% personal preference. You should browse the ROM section and see which one suits you best.
Keep in mind though, you can only install ROMs that were built for the version of the Razr that you have. Since you are using Arctic I assume you have a GSM Razr, which really limits your choices.
My favorite ROM to date is Eclipse (CDMA). It is by FAR the most modified (from stock) ROM out there, and it's not just pasted scripts from other ROMs slapped together. Nitro has been developing Eclipse for years and it really shows; has it's own launcher, Eclipse settings, extremely fast and somehow amazing battery conservation as well. I probably won't be taking the OTA update to ICS until Nitro releases something for it.
:-D :-D
Posted 20 April 2012 - 08:52 PM
Man I hate this question...
Completely agree with everything you said. There is no right answer to this question now and never will be. Its all about what you feel is right for you. I have run almost every ROM we have and each has their good points. I have actually been root stock for about 2 weeks now because I am just not sure what to go with right now lol.
Sent from my DROID RAZR using Xparent Red Tapatalk 2
Posted 22 April 2012 - 11:34 AM
Posted 22 April 2012 - 12:32 PM
lol oh man...myself as well. Stock rooted just awaiting the ics.. but I've flashed all the ics custom roms..just trying very hard to not jump for the leak... lol its not easy..lol peaceCompletely agree with everything you said. There is no right answer to this question now and never will be. Its all about what you feel is right for you. I have run almost every ROM we have and each has their good points. I have actually been root stock for about 2 weeks now because I am just not sure what to go with right now lol.
Posted 31 May 2012 - 08:28 AM
I don't ask for donations and don't expect them, but if you feel inclined here's the link:
https://www.paypal.c...gif%3aNonHosted
Posted 31 May 2012 - 09:49 AM
Posted 31 May 2012 - 09:51 AM
Posted 26 June 2012 - 02:31 AM
Posted 26 June 2012 - 03:27 AM
I have not tried Hicks yet. Not sure if I want his Soldierness trying to take over my phone... joking bro. Or am I?....... The dunt da dun would sound right now.
Posted 13 February 2013 - 11:14 AM
Posted 07 March 2013 - 10:50 AM
Unfortunately I dropped for 1sec my Razr Maxx in a sink, in an instant turned it off, wiped it and left it for 48 hrs in a rice bowl. Then turned it on, works perfectly, no lags, but those 4 touch buttons at the bottom of the screen are unresponsive. They are lighted but dead, the worst part is I can't use backspace, the only way to get back to the desktop or close an application is to restart the phone. I rooted it, instaled safe strap 3.11, and now I need a ROM that have home and back buttons on the screen. I'm in EU with GSM, using ICS 4.0.4 system version 673.94.328.XT910.AsiaRetail.wn.03
Posted 29 April 2013 - 11:52 AM
Hi all I'm a newbie.
Hi Lance
I have the exact same phone as you, even AsiaRetail matches.
After long and careless consideration I've done the following
- rooted the phone using the one-click method, worked great
- used SuperSU and OTA rootkeep to preserve root (probably not needed)
- installed safestrap 3.x
- used safestrap to make a backup of current system on SD
- used safestrap to install AOKP (worked nice with r5, good with latest release Milestone1)
- in AOKP you can enable those buttons as touch buttons at the bottom of the screen and use them instead of the soft-touch buttons.
Please read again and again all docs before performing each step, or even better, find your own steps to get to the custom ROM.
It worked great for me, but I am also quite new to this and might have messed something up.
Good luck and let us know how it went.
Radu
