[ROM][CDMA/GSM] Buttered AOKP 4.2.2 [2013-6-5]
374 replies to this topic
#1 BigJArm
BigJArm
  • 212 posts
  • LocationIdaho
Posted 15 May 2013 - 01:26 PM
General Information:
I love this build on my Nexus 10 and wanted to bring it to the RAZR. I hope you enjoy it as much as I do.
This ROM is built from source : AOKP 4.2.2 -> mr1.1 with all current merged commits + PUB Optimizations
What is PUB? Project Unicorn Butter is a project from stephen.k.spear. It has all the features of AOKP plus Tons of optimizations for speed and smoothness.
Current PUB Optimizations
Google GCC 4.7 Toolchain
O3
Strict-Aliasing (Linaro)
C++11 Mode
Optimized String Handling Routines (Linaro/Sony)
Misc other Linaro and Code Aurora Optimizations
Visit the
site for features and screen shots
The original thread for reference:
Installation:
  1. Download rom zip and gapps
  2. Reboot to recovery (I have only tested this on SS3.xx)
  3. Wipe cache/dalvik (full wipe when needed such as coming from another ROM)
  4. Flash rom (be sure to flash this in ROM Slot 1 only)
  5. Flash gapps
  6. Reboot
Downloads: NEW BUILDS ARE FOR ROM SLOT 1
[CDMA] Buttered AOKP Spyder-- 2013-06-05 :: ::
[GSM] Buttered AOKP umts_Spyder-- 2013-06-05 :: ::
 :: :: Mirror
You must flash gapps after flashing this ROM as it can not be included in the ROM zip.
Current Gapps:
Slim Gapps(needed for full Dark UI functionality):
 - Swyping on AOSP Keyboard does not work with this Gapps package
Known Issues:
HDMI
Wifi or Bluetooth Issues - Reboot into SS and under Advances select Fix Permissions. That will correct 99% of the problems.
-Entire AOKP team for all their contributions. Any
direct to them.::
-CyanogenMod team for the Kernel used by AOKP :: Source
-Hashcode , dhacker29 for getting AOKP to the RAZR
-stephen.k.spear for PUB and pushing optimizations for an already great ROM
-mrRobinson for maintaining PUB and adding it to the RAZR
-xlightwaverx for getting me started building AOKP
  • sankyou, burmjohn, joshuahist and 7 others like this
#2 BigJArm
BigJArm
  • 212 posts
  • LocationIdaho
Posted 15 May 2013 - 01:27 PM
2013-06-05
-- Added Google Analytics Support
-- frameworks_base / Add BAMF theme engine
-- frameworks_base / Fixed battery bar showing on all 3 locations
-- frameworks_base / reduced observers in system ui
-- Telephony: Add DCHSPAP to getTcpBufferSizesPropName
-- ROMcontrol / ROMControl: Remove Duplicate String
-- dalvik / numerous JIT updates and optimizations
-- frameworks_base / Lockscreen Longpress: Unlock Logic
-- omap4_common / Use shared mapphone_mmi_defconfig and variant for differences
-- frameworks_base / Fixing crash in PhoneNumberUtils getNumberFromIntent
-- framworks_base and ROMcontrol / AutoHide for SystemBar
-- ROMcontrol / Toggles: Preferences Enabled for Ribbons
-- packages_apps_settings / Settings: refactor TRDS toggle and add some apps
-- packages_apps_email / email occasionally crash on boot complete
-- frameworks_base / Navbar buttons spacing for Phablet UI
-- external_skia / Add optimization of Skia (multiple areas)
-- contacts, MMS and Settings TRDS2.0 update
-- system_core / libsysutils: fix null pointer and memory leak issue
-- packages_apps_MMS / MMS: Fix lookup of vanity addresses
-- settings / Allow changing auto-brightness responsitivity.
2013-05-27
--Added O3 optimizations to Kernel
--Added network enhancements to help with speed
--Notification count updates
--Add transparency setting for lock screen
--Ribbon v1.0 overhaul
--Smooth Spinners: Makes the loading "spinner" animation smoother in non-holo apps
2013-05-20
-- Now Boots from ROM Slot 1 only
-- Some sysctrl and RAM management changes
-- Sync all mGerrit changes
-- Holo-fy the icons (PermissionsManager)
-- DynamicChangelog
-- Update to AOSP 4.2.2_r1.2
-- Many internal "Buttered" updates/changes
-- Allow custom density setting
-- LockScreen: Fix crash when unlocking twice
5/16/2013:
Added Dark UI Mode Toggles
OMAP 4 Devices: uses device specific 4.1 audio.primary and ap_gain
SystemUI: More memory leak fixes
AOKP Torch: using sysfs instead of camera HAL
5/15/2013:
First Release
  • canezila, extirpate, asdtech153 and 1 other like this
#3 dave5777
dave5777
    Crack Flashing MOFO
  • 145 posts
  • LocationCali
  • Current Device(s):RAZR MAXX, NEXUS 7 32gb
Posted 15 May 2013 - 01:36 PM
Thanks for the Flash candy<br /><br />Sent from my DROID RAZR using Tapatalk 2<br /><br />
#4 fatmando2
fatmando2
  • 235 posts
  • LocationMichigan
Posted 15 May 2013 - 02:18 PM
Super fast download, I look forward to trying this out!
#5 larrydp
larrydp
  • 18 posts
Posted 15 May 2013 - 02:19 PM
I haven't flashed a new rom this evening...looks like this is good timing!  Downloading now :)
#6 floatingfaceup
floatingfaceup
  • 54 posts
Posted 15 May 2013 - 02:27 PM
Screen shots would be awesome
#7 dave5777
dave5777
    Crack Flashing MOFO
  • 145 posts
  • LocationCali
Posted 15 May 2013 - 04:20 PM
No boot :(<br /><br />Sent from my DROID RAZR using Tapatalk 2<br /><br />
#8 BigJArm
BigJArm
  • 212 posts
  • LocationIdaho
Posted 15 May 2013 - 04:38 PM
No boot :(
Did you flash it in slot 2?
#9 dave5777
dave5777
    Crack Flashing MOFO
  • 145 posts
  • LocationCali
Posted 15 May 2013 - 04:40 PM
No boot :(
Awww just saw that. Thanks will give it another try :ph34r:
#10 mattkilla
mattkilla
  • 187 posts
  • Google+:mattkilla420
  • LocationNorth Carolina
  • Current Device(s):Droid Razr Maxx xt912 , Samsung Droid Charge (FP8)
Posted 15 May 2013 - 05:52 PM
Gotta get in on this PUB action. Looks really sweet. Will report bugs once i flash
sent from my Droid RAZR Maxxfrom another dimension...
#11 androidlearner
androidlearner
  • 904 posts
  • LocationPeoria, AZ
Posted 15 May 2013 - 06:10 PM
I've been waiting for something like this!
Sent from Maximized FlyingPlatyRazrJellyRaptor
#12 thebluegod
thebluegod
  • 66 posts
Posted 15 May 2013 - 06:22 PM
Awesome!!! Downloading now... So can this be used as a daily driver? Seems like it to me. Don't care much for HDMI.
#13 dave5777
dave5777
    Crack Flashing MOFO
  • 145 posts
  • LocationCali
Posted 15 May 2013 - 08:24 PM
Very nice, love the reboot to recovery menu. Trace doesn't work on the AOSP keyboard.<br /><br />Sent from my XT912 using Tapatalk 2<br /><br />
#14 BigJArm
BigJArm
  • 212 posts
  • LocationIdaho
Posted 15 May 2013 - 08:46 PM
You mean the swipe function of the keyboard right? I just tested mine and it works fine. Have you tried it typing a message in talk or the body of an email. I know the swiping doesn't work everywhere with the AOSP keyboard.
#15 rjnb2112
rjnb2112
  • 6 posts
Posted 15 May 2013 - 10:51 PM
Anyone else having wifi issues?
#16 larrydp
larrydp
  • 18 posts
Posted 16 May 2013 - 02:02 AM
Did you try opening terminal emulator doing su then wifical.sh?  That worked for me
  • BigJArm, rjnb2112, RikRong and 1 other like this
#17 monkteo
monkteo
  • 41 posts
  • LocationRomania
Posted 16 May 2013 - 02:28 AM
We need GSM patch for XT912 CDMA ?
I have CDMA but I use GSM system in Europe !
#18 floatingfaceup
floatingfaceup
  • 54 posts
Posted 16 May 2013 - 05:05 AM
Finally! The AOKP I've been looking for!!! Haven't ran into any bugs so far.
One concern is the amount of ram it uses, even with no apps running.
#19 BigJArm
BigJArm
  • 212 posts
  • LocationIdaho
Posted 16 May 2013 - 05:54 AM
There is Global and GSM modes listed in the ROM. You can try and see if those work if Europe.
I'm hoping to put out a new build tonight that includes a fix for a memory leak.
#20 sankyou
sankyou
  • 158 posts
Posted 16 May 2013 - 07:04 AM
Just flashed this last night.  Coming from Aviator AOKP and so far so good.  Thanks for cranking this out.  Your development is appreciated!
