[THEME] BLU for Flying Jelly
38 replies to this topic
#1 jayrod
jayrod
  • 6,525 posts
  • LocationWilmington NC
  • Current Device(s):Taimen
Posted 12 May 2013 - 05:37 PM
Blue semi-transparent menus and backgrounds, themed icons and as much XML editing as I know how to do ..this is BLU for Flying Jelly
What is themed
Mms.apk
LatinIME.apk
MotGallery2
Settings.apk
Calculator.apk
Phone.apk
Contacts.apk
SystemUI.apk
framework-res.apk
MotCamera.apk
Calender.apk
MotoEmail (Semi-Transparent Blue)
Gmail.apk (Semi-Transparent Blue)*UPDATED VERSION*        5/19/13__Removed until theme is updated
Talk.apk (Semi-Transparent Blue)                                              5/19/13__Removed until theme is updated
Music2 (Transparent) *UPDATED VERSION*                              5/19/13__Removed until theme is updated
Browser.apk
DownloadProviderUi.apk (Icon)
GoogleServicesFramework.apk                                                5/19/13__Removed until theme is updated
noFrillsCPU-1.apk (Icon)
Vvm.apk (Icon)
I have ported this from the RAZR build with the exception of Framework,Settings and SystemUI which is why Browser is included.All screenshots are from the RAZR theme OP. The only differences between what is shown and what is included is the settings and clear notifications PNGs on the quicksettings pulldown. The carrier name change may or may not work for you. It worked perfectly on my RAZR but not on either of my Bionics. This is the most editing of .pngs and XML that I have done thus far. I have no clue just how many images I edited..and over all, I tried to keep things as aesthetically pleasing and functional as possible. The only thing leftover from my original Bionic theme is the name and a handful of icons!
  296.02KB   130 downloads
  194.33KB   133 downloads
  287.78KB   132 downloads
  166.85KB   129 downloads
  232.63KB   126 downloads
  237.29KB   128 downloads
  246.3KB   124 downloads
  234.51KB   123 downloads
  224.66KB   126 downloads
And 4 different pulldown options
OPTION 1 OPTION 2
  268.4KB   133 downloads
  298.82KB   135 downloads
OPTION 3 OPTION 4
  569.37KB   138 downloads
  473.12KB   128 downloads
  • usmcamgrimm, T3T3droid, jp1044 and 2 others like this
#2 jayrod
jayrod
  • 6,525 posts
This theme works for me. Flash at your own risk.I am not to be held responsible for damaging your phone.
I want to thank Jp and T3T3 for making such a stable ROM as well as continuing to assist me when I need it
Also want to thank dubsx for being there to answer my questions no matter how confusing they are
And I really want to thank Timmy10shoes for the very AWESOME work on scripting .There is now only 1 zip that does the work of 9! (Aproximately :D)
5/19/13..........Due to both updates by Google as well as to the ROM, the themed Gapps including GMail have been removed. I will update as time permits.
Why is this AWESOME?
Now when you flash this .zip, a backup of your existing theme is backed up on to your SD in a Theme Eraser folder.
****IMPORTANT NOTE**** IF YOU DECIDE AFTER RUNNING THIS THEME TO RETURN TO STOCK VIA THE THEME ERASER,YOU WILL HAVE TO WIPE GMAILS DATA AFTER RETURNING TO STOCK THEME AND THEN REBOOT,GMAIL WILL FORCE CLOSE AND AFTER CLEARING OF DATA AND A REBOOT<IT WILL BE BACK TO NORMAL WORKING ORDER****
It also creates a Pull downs folder with all 4 of the Pull downs. This means,if you get bored with your pull down, all you need to do is:
-In Safestrap, Navigatate to the Pull Downs folder on your SD.
-Select whichever .zip you want ,flash and reboot.
It's that simple!
The script also wipes caches when you flash the theme so you don't have to!
This setup eliminates the need to have to flash the whole theme every time you want to change your pull down and can open the door to other possibilities.
****You will be on the default solid blue when you flash this for the first time*****
How to install:
-Download from the link below to your SD
- Reboot into SAFESTRAP Recovery
- Install .zip from SD card
5/19/13 UPDATE
USAGE POLICY:  Feel free to use anything that I have made in this theme for any other project . All I ask is you  please credit me in your OP.
  • T3T3droid, Bama and nobe1976 like this
#3 jayrod
jayrod
  • 6,525 posts
Posted 12 May 2013 - 05:38 PM
14 different optional backgrounds with 3 options each.
Simply download whichever .zip(s) to your phone and using RootExplorer or other file manager, unzip to your SD
  • T3T3droid and bionichillbilly like this
#4 jayrod
jayrod
  • 6,525 posts
Reserved for additional info...just in case.
#5 Bama
Bama
    Needs Beer
  • 582 posts
  • Locationsalem,al
Posted 12 May 2013 - 06:00 PM
that was fast lol
  • jayrod likes this
#6 jp1044
jp1044
    DEVELOPER
  • News Writer
  • 1,104 posts
  • Twitter:@jp1044
  • Google+:jp1044@gmail.com
  • LocationColorado
Posted 12 May 2013 - 06:01 PM
Very nice!
  • jayrod likes this
#7 zooyork0721
zooyork0721
    All Around Man
  • 979 posts
  • LocationNew York, NY
Posted 12 May 2013 - 06:02 PM
looks sick! ;) dont have the device but makes me want it :p
#8 jayrod
jayrod
  • 6,525 posts
Posted 12 May 2013 - 06:04 PM
that was fast lol
I was sooooo ready to run this on my Bionic when I finished it for the RAZR...I didn't even add anything from it to Icarus at all. As soon as the Beta came out I started porting it!
  • Bama likes this
#9 shanewerner
shanewerner
  • 61 posts
Posted 12 May 2013 - 07:44 PM
very nice work dude love this theme  but the blu wall links don't work
  • cgillie92 likes this
#10 cgillie92
cgillie92
  • 129 posts
Posted 12 May 2013 - 09:45 PM
Wallpaper links dont work for me either
#11 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
  • LocationWhere I AM
Posted 13 May 2013 - 02:34 AM
Tring to download on mobile and nothing. Link transfers to new window, but nothing starts downloading. Will try later after work. TY.
#12 Guest_BDH_*
Guest_BDH_*
Posted 13 May 2013 - 02:38 AM
Works for me with Chrome as default browser. I click in the link in Tapatalk, Chrome opens and starts downloading. Are you using a different browser?
#13 jayrod
jayrod
  • 6,525 posts
Posted 13 May 2013 - 02:47 AM
Wallpaper links are fixed. Sorry bout that... apparently copy/paste wasn't my friend last night!
#14 mjs27541
mjs27541
    I have no idea what's going on...
  • News Writer
  • 1,276 posts
  • LocationSouthern MD
Posted 13 May 2013 - 09:10 AM
Looks sick Jayrod! Looks like FJ will be the next ROM I tinker with.
#15 DevildogMP
DevildogMP
  • 55 posts
  • LocationRaleigh, North Carolina
  • Current Device(s):Motorola Droid Bionic
Posted 13 May 2013 - 10:06 AM
Link not working on phone..
#16 jayrod
jayrod
  • 6,525 posts
Posted 13 May 2013 - 10:34 AM
Not sure what's up.. link works with boat browser and automatically downloads with chrome
  41.21KB   32 downloads
  58.32KB   32 downloads
Sent from my BLU Jelly Flying Bionic
#17 DevildogMP
DevildogMP
  • 55 posts
Posted 13 May 2013 - 10:55 AM
Nope not working. Tried on different browssrs too
#18 jayrod
jayrod
  • 6,525 posts
Posted 13 May 2013 - 10:58 AM
It'll have to be later on..I'm at work
#19 Guest_BDH_*
Guest_BDH_*
Posted 13 May 2013 - 11:19 AM
Nope not working. Tried on different browsers. Can you drop box it to me through Google talk? I got some questions anyway.. if you don't want to I understand.. johnalexwallwall@gmail.com
Just did it again. Still works
#20 braum
braum
  • 21 posts
  • Current Device(s):Bionic, rzr max, infinity pad
Posted 13 May 2013 - 11:36 AM
would it be posable to theme webtop with more of your theme now that we are EOL on the bionic?
  39.07KB   29 downloads
  36.52KB   29 downloads
