Fastboot stuck problem
6 replies to this topic
#1 victorwfh
victorwfh
  • LocationBrasil
Posted 10 May 2013 - 05:03 PM
Hi guys...
I have one of the earlyest versions of razr xt910, so my phone could automaticly update to ICS... So i tried doing it by myself...
I instaled RDS lite, downloaded the oficial ICS version of my operator and tried instaling it... But it failed !
Now my phone is stuck on fastboot screen and i cant make it go back!
Iv tryed the power + Volume up&down but no result... always takes me back to the fastboot screen...
Here is what the screen says:
AP Fastboot Flash Mode (S) (Flash Failure)
0A.74
eMMC Info: Size 16G
To return to normal mode - fisrt press power key to power down
Battery OK
OK to Program
Connect USB
Data Cable
Help me please !!
#2 cmh714
Posted 12 May 2013 - 12:28 PM
First I am not an expert by any means, especially with the foreign versions. I think 0A.74 is the ICS bootloader code. There is often another error message below what you posted here but regardless, you are getting a flash failure and the first thing is you need to get something/anything to flash so that you can try RSD again.
I would recommend that you try and flash just the logo.bin file ONLY. after that hopefully when you go back into AP Fastboot mode the message will be gone and you should be able to flash all of it through RSD.
Good luck
#3 victorwfh
victorwfh
  • LocationBrasil
Posted 13 May 2013 - 06:36 AM
How do i flash the logo.bin if the RSDlite only sees xml files ??
Im sorry, i really dont know how to mess with this stuff yet...
#4 hillmom
hillmom
  • 131 posts
  • Twitter:whillmom
  • LocationIdaho
Posted 13 May 2013 - 06:48 AM
Did you check MD5 to make sure the download of the fastboot files are good?
#5 victorwfh
victorwfh
  • LocationBrasil
Posted 13 May 2013 - 04:51 PM
I dont even know what MD5 is...  :(
#6 cmh714
Posted 13 May 2013 - 05:12 PM
I havent played with rsd in some time and unfortunately I am swamped with work. Also I am not running windows atm.
The command would be from the command line:  fastboot flash logo logo.bin
where logo.bin is the file on your pc.
Sorry I cant offer better help atm, if you jump into the chatroom, you can get realtime help from someone in there generally, usually me :) but as I said I am swamped with work.
#7 anuragdj2u
anuragdj2u
  • 10 posts
  • Locationnew
Posted 19 May 2013 - 08:29 PM
Hi guys...
0A.74
eMMC Info: Size 16G
Battery OK
OK to Program
Connect USB
Data Cable
Help me please !!
This problem is actually occurred because ya flashed a wrong fastboot files .. First look out for appropriate fasboot file made for ya region and then flash that using rsd lite .
Edit : ya just cant download any fastboot and flash because our RAZR bootloader is locked .
Edit 2 : flash jellybean fastboot instead of ICS i believe ya kernel has been changed
Thanks!!
Please hit the thanks button if i helped ya in anyways !!!
