No Data/Service after ROM Install {I am not having issue but know this may be coming for many}
efi imei flash rom sticky? oh the humanity general
6 replies to this topic
#1 Pr0digy
Pr0digy
  • 57 posts
  • LocationLawrence Kansas
  • Current Device(s):Razr M (retail) Samsung Vitality (Sitting unused) iPad 2
Posted 10 May 2013 - 11:06 AM
in this thread
BwingG, on 10 May 2013 - 08:48 AM, said:
I tried yesterday to install and every time it boots with no service. Anyone else have this issue. I've been wiping properly.
Not sure if this is the case in this particular issue but apparently some Motorola DEV phones (And we have a unlocked boot loader now so yeah) will loose their IMEI data
So anybody without data/signal after an upgrade or ROM flash could you please do the following and tell us if you get real data or zeros/unknown/null as a result?
  1. From a home screen, select Apps ( apps_icon.jpg located at the bottom).
  2. From the All Apps tab, select Settings.
  3. Select About phone.
  4. Select Status.
  5. Locate the IMEI.
Could you report back here and tell me if your IMEI and MEID is a real number or something like this
MEID
Dec:17600000000
Hex:0xB0000000
IMEI
0
Or simply says unknown or null
and/or also try dialing from the dialer *#06# and tell me if a real MEID number comes up
#2 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
  • Twitter:@timpohladthomas
  • Current Device(s):MOTO X
Posted 10 May 2013 - 04:01 PM
Hey guys!  If you are having this issue...try flashing this and see if it fixes it...it is the 4.1.2 radio.
Let me know if it fixes it.
  • RikRong likes this
#3 BwingG
BwingG
  • 140 posts
  • LocationSeattle
  • Current Device(s):RazrM
Posted 10 May 2013 - 04:03 PM
i posted in the main thread to but my instance was due to a bad download.  i downloaded with phone then transfered from phone to sd, this didnt work.  i then downloaded with pc then transfered with the usb cable, worked first time.
#4 sourj
sourj
  • 18 posts
  • LocationNew York
Posted 11 May 2013 - 09:29 AM
I am also getting this issue but only when i flash deadrage.
I noticed I recently switched from CWM recovery to TWRP, and since then it has been having the issue.... Might be because of TWRP?
not sure about bad downloads because ive downloaded it twice to be sure.
#5 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 11 May 2013 - 10:11 AM
TWRP's not the issue.  I'm not sure what the issue is with DeadRage, I didn't have an issue.  However, there is one thing that I have done differently than most people.  I was running MRage and flashed the updated radio by itself.  Then, I updated to DeadRage, which is based off of 4.1.2.  Possibly, DeadRage doesn't flash the 4.1.2 radio, leaving you with the 4.1.1 radio.img, and that's proving incompatible.  Bump your baseband version against my screenshots:
Old baseband:
  118.59KB   9 downloads
New baseband:
  77.46KB   11 downloads
#6 Pr0digy
Pr0digy
  • 57 posts
Posted 11 May 2013 - 10:20 AM
I used matt's utility and flashed stock 4.1.2 then through CWM flashed DeadRage mine is running smoother than anything else.
Sent from your Mom's XT907 using Tapatalk 2
#7 sourj
sourj
  • 18 posts
  • LocationNew York
Posted 11 May 2013 - 01:23 PM
Okay well I think the issue was that instead of wiping everything, I had only factory reset and wiped caches..... Hadn't wiped system because I fastbooted to 4.1.2 and then tried again wiping system and its all good now.
  • timpohladthomas likes this
Also tagged with one or more of these keywords: efi, imei, flash, rom, sticky?, oh the humanity, general
