Messeging and sound Problem - Please Help
2 replies to this topic
#1 MoonspellPL
MoonspellPL
  • 6 posts
  • LocationPoland
  • Current Device(s):XT910 - JB
Posted 07 May 2013 - 08:50 PM
Hi,
So i have successfully moved into 4.1.2 however i deleted some of the stock apps and after a while I noticed I am having a problem with receiving txt messages. Then I downloaded Handcent SMS and the situation has changed - I can receive but cant send - I am out of options.
Second problem appeared in the same time - My phone wont recognize plugged phones :-(. It keeps play music externally. Now I dont know if this is hardware problem or sofwere.
Unfortunately I havent backed up my stock apps and cant reverse the process.
#2 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 08 May 2013 - 04:21 AM
I would suggest a factory reset. After installing major updates usually a factory reset is needed to prevent issues.
#3 MoonspellPL
MoonspellPL
  • 6 posts
  • LocationPoland
Posted 09 May 2013 - 03:12 AM
It dosent work - What happens now is that I am getting one sms over and over. This is really annoying.
Is there a way to re-flash the entire 4.1.2 ? or something ?
