RAZR M ROM STOCK
951 replies to this topic
#141 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
  • Twitter:@timpohladthomas
  • Current Device(s):MOTO X
Posted 08 May 2013 - 07:50 AM
This thing is pretty dang debloated.  The only ROMs I've seen with less were CM builds.  You can debloat and freeze with TiBU or similar apps.  Like Tim said, his BlackWhite theme blacks out PlayStore and several other apps.  For others, I also use inverted apps by BBoy.  These can easily be found on his website or XDA.  My FB, Instagram, Chrome all get inverted.
I also dug around the internet for quite a while and couldn't find anything specifically talking about the debugging issue.  Just to be sure I wasn't losing my mind, I restored my backed up Rage ROM and debugging worked as advertised.   :wacko:
Hmm, Thats good to know about RAGE.  Maybe I will get BDH to take a look at what I have and see whats different! I still haven't given up on you guys.  I think I have the rotation issue fixed.  Now back to usb debugging.
  • dreamjaeil and RikRong like this
#142 mrnathanman
mrnathanman
  • 5 posts
Posted 08 May 2013 - 08:22 AM
Hey man,
Do you have a list of specific apk files you want gone?  They can be found in /system/app
You can look around for inverted apps on the forums, here or xda.  I use apps by B-boy when i choose to invert.  However, I will probably not add inverts to my base theme.  If you want to add inverts to your phone, you can always flash my
theme.
Also, glad you like it!
Sugestions:
Globalunplug.apk should be removed
calendar.apk should be replaced by the google calendar .apk
I'll try and think of more, but for now these are the only two that I can think of.
When I used to be on stock, almost all the apks (even bloat) had the option of being disabled in the settings/apps/all area. For some reason, I was not able to disable the moto calendar and a few other apps (can't remember exactly which at the moment) in this defalt way. Instead i disabled them via titanium backup. Is there any reason this should occur?
Again, I would just like to say thank you so much for the ROM. I love it.
  • timpohladthomas likes this
#143 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 08 May 2013 - 08:39 AM
Sugestions:
System apps can't be disabled through stock App Manager.
#144 ANDROIDRAZRM
ANDROIDRAZRM
  • 56 posts
Posted 08 May 2013 - 08:58 AM
Hey man,
theme.
SmartActions.apk
SmartactionFW.apk
SmartACtionMFW.apk
SmartCarDock.apk
SmartDock.apk
StrokeiME.apk
VMWareReady.apk
PhaseBeam.apk
MotoSmartHandWriting.apk
MotionTrigger.apk
MotoEmailConfig.apk
MotoDockhelperService.apk
MotoCareInt.apk
LiveWallpaperPicker.apk
LiveWallpapers.apk
Latin.apk
LatinImeGoogle.apk
LatinIMEDictionaryPack.apk
HoloSpiralWallpaper.apk
GlobalUnplug.apk
Dockservice.apk
cce.apk
Noisefield.apk
There's probably some others that I've already nuked and am missing. Pretty much all of the Motorola stuff I'm not sure about. Also, do you recommend using Seeder and CPU sleeper since they are in your ROM?
Thanks!
Edit: Also, is the recommended theme install method to simply flash the theme after loading the ROM or to manually copy the files to Dead RAGE before flashing the ROM?
#145 Metman87
Metman87
  • 6 posts
  • Current Device(s):Motorola droid RAZR m
Posted 08 May 2013 - 09:10 AM
also having trouble with proximity sensor not turning off screen during call. but again...loving the rom. battery life is great as is everything else. just a few minor kinks to work out.. wish i could help
Haven't seen them, have noticed when I am on the phone (calling) the screen isn't turning off when I put it to my ear. Bad flash or proximity sensor issue? Maybe something mistyped in the build.prop? Anyone else confirm this. Hope it's just me :-D
#146 mrnathanman
mrnathanman
  • 5 posts
Posted 08 May 2013 - 09:16 AM
Not true. At least not true with some some system apps. I dissabbled email(system app) and some of the moto keyboard crap all in stock app manager.
#147 Gerland the Oracle
Gerland the Oracle
    Co-Owner and Support Specialist for Team Rage
  • 212 posts
  • Twitter:gerlandh
  • Google+:gerland.hardin@gmail.com
  • LocationJerome, Idaho
Posted 08 May 2013 - 09:24 AM
As a Live wallpaper user i belive we've slimmed this Beast down as far as it should go! But too do more on your own i find that "ROOT UNINSTALLER PRO" works great! Just my 2 cents worth!.
  • neckchop and timpohladthomas like this
#148 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 08 May 2013 - 09:30 AM
Hey man,
theme.
SmartActions.apk
SmartactionFW.apk
SmartACtionMFW.apk
SmartCarDock.apk
SmartDock.apk
StrokeiME.apk
VMWareReady.apk
PhaseBeam.apk
MotionTrigger.apk
MotoEmailConfig.apk
MotoCareInt.apk
LiveWallpapers.apk
Latin.apk
LatinImeGoogle.apk
GlobalUnplug.apk
Dockservice.apk
cce.apk
Noisefield.apk
Thanks!
Thanks for the suggestions.  I will keep them in mind, however, we are getting close to being so slim it doesn't function the way the masses would like.  Apps like live wallpaper can be disable in Titanium backup if you would like but most people like this option.
Also, always use seeder and cpu sleeper, combined with lagfix, so its up to you.
The theme should always be flashed after setting up the ROM then rebooting into recovery.
Glad you are enjoying the ROM.
#149 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 08 May 2013 - 09:35 AM
Alright guys,
I am in the process of uploading an update to Dev-host.  I will post a link in the OP when it finishes.
Changelog:
DeadRage v1.2
-Added custom boot sound
-Fixed USB Debugging issue
-Fixed Rotation Issue (I think?)
-Added/Removed Tweaks to remove any conflicts
You are welcome to try a "dirty" flash if you want, however, you are not allowed to come in here and tell me things are wrong if you do.   :D
  • neckchop and hillmom like this
#150 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 08 May 2013 - 09:48 AM
UPDATE LINK IS LIVE!!!!
  • hillmom, RikRong and moto13 like this
#151 Metman87
Metman87
  • 6 posts
Posted 08 May 2013 - 09:54 AM
Awesome! downloading now.
#152 brandon71
brandon71
  • 553 posts
  • Google+:tbd7171@gmail.com
  • LocationKodak, TN
Posted 08 May 2013 - 10:34 AM
settings fc when i go into settings>launcher did a clean flash too
#153 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 08 May 2013 - 10:40 AM
Yeah, that's an issue I know about...haven't figured out how to get it to go the the setting on the default launcher yet. That will be fixed in an upcoming build. Thanks for the heads up though.
  • brandon71 likes this
#154 arc1880
arc1880
  • 74 posts
  • Current Device(s):RAZR M
Posted 08 May 2013 - 10:41 AM
Ninja edit. I just flashed last night also. Can't wait to try this out when I get home.
#155 jco23
jco23
  • 414 posts
Posted 08 May 2013 - 10:58 AM
so if we use a different launcher (say, Holo for example), would we still get the FC?
ROM: OSE KitKat 4.4.2
#156 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 08 May 2013 - 11:09 AM
Yes sir, the force close comes because it is looking for something that it can't find.  I thought I had it linked to the default launchers menu, like cm but apparently I was wrong.  So over the next update or so I will either remove that from settings or fix the broken link.  For now, avoid it or it will close.  Sorry guys.
#157 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 08 May 2013 - 11:10 AM
As a note guys, Dev-host is down (404 error) Hopefully it will be back soon.
In the meantime, I will look for a mirror.
Found a site, uploading now and will post a download link shortly.
Looks like Dev-host beat me to it.  The links are back up and running.  ENJOY!!!
#158 Metman87
Metman87
  • 6 posts
Posted 08 May 2013 - 01:12 PM
looks like the link is down
#159 zooyork0721
zooyork0721
    All Around Man
  • 979 posts
  • LocationNew York, NY
Posted 08 May 2013 - 01:15 PM
Dev Host has been weird today
i think you need to download with Mega through Desktop, you tell me
Mirror for now-
  • timpohladthomas and clienterror like this
#160 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 08 May 2013 - 01:20 PM
Mirror for now-
Thanks Zoo!
Alright guys, sorry about dev-host being intermittent. The link above will work on a computer but sadly those on phones will just have to wait until dev-host is fixed or I get another mirror.
  • zooyork0721 and clienterror like this
