RAZR M ROM STOCK
951 replies to this topic
#921 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 27 August 2013 - 02:44 AM
Honestly, I'm confused...it's more complicated then my old droid 1
Stock based ROMs don't have a mount script built in.  You'll need to choose the "mount system" option in SafeStrap, after doing your wipes and prior to flashing.
#922 jco23
jco23
  • 414 posts
Posted 27 August 2013 - 03:12 AM
To answer your question, you should be able to flash this on a locked BL, with SafeStrap.
rarely is RikRong wrong (despite his name and being a Cardinals' fan).
however, I'm fairly certain the file posted in the OP is flashable via TWRP/CWM only - meaning that the bootloader must be unlocked.  I think it requires a slightly different file to install via SS vs. TWRP/CWM.
so while this ROM maybe installable via SS, you may need the dev to create a separate file to do that.
but I could be wrong....
ROM: OSE KitKat 4.4.2
#923 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 27 August 2013 - 03:14 AM
Hey, a Cards fan can never be wrong. ;)
However, you may be right. I thought I remember reading that people have flashed this with SS, but it may have been the previous version.
#924 Caleb
Caleb
  • 12 posts
  • Current Device(s):Razr M
Posted 27 August 2013 - 01:51 PM
 do you flash via RSD lite like the droid 1 or do you copy the zip file to the external SD card?
#925 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 27 August 2013 - 03:16 PM
Copy to external SD.  Heck, on my OG Droid, I still copy to the SD and just change the name to get it to flash.
#926 LarrysAndroid
LarrysAndroid
  • 62 posts
  • Current Device(s):Motorola Droid Razr M
Posted 28 August 2013 - 03:29 PM
I did exactly as the OP said. In that order and this ROM says Failed to install. What's up? :( I'm on a locked 98.18.78 RAZR M running Safestrap
#927 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
  • Twitter:@timpohladthomas
  • Current Device(s):MOTO X
Posted 29 August 2013 - 02:44 AM
I have not changed anything in terms of the method for flashing this rom since my days on safestrap, so all should be working in safestrap. What slot are you installing to?
#928 LarrysAndroid
LarrysAndroid
  • 62 posts
Posted 29 August 2013 - 03:04 AM
I have not changed anything in terms of the method for flashing this rom since my days on safestrap, so all should be working in safestrap.What slot are you installing to?
ROM Slot 1
#929 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 29 August 2013 - 04:23 AM
Did you reboot recovery and then mount system? Also, some of ROMs will report a fail on install, but if you reboot, the install actually did work. IIRC, Eclipse was like this.
#930 LarrysAndroid
LarrysAndroid
  • 62 posts
Posted 29 August 2013 - 04:40 AM
Yea I rebooted and then mounted again. When I mount do I check the boxes until they read unmount next to them and click the Mount USB Storage? If so then yes I did that. I'll try it again and reboot to see if it still works.
#931 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 29 August 2013 - 04:59 AM
Just mount system, and leave it checked.
#932 supercolin
supercolin
  • Current Device(s):Verizon RAZR M
Posted 05 September 2013 - 10:10 AM
I am having some serious data and wifi drop issues with this rom, has anyone else had this problem? Suggestions? I am locked on stock kernel.
#933 ANDROIDRAZRM
ANDROIDRAZRM
  • 56 posts
Posted 05 September 2013 - 02:25 PM
This was actually one of the best roms I had used as far as signal strength is concerned. Are you on the 78p baseband? It couldn't hurt to try a different kernel, either.
#934 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 05 September 2013 - 06:48 PM
He won't be able to change the kernel, if his bootloader is locked.  However, when I did run this, my bootloader was unlocked, but I didn't have issues with dropping data or WiFi.  You might want to try re-flashing.
#935 Caleb
Caleb
  • 12 posts
Posted 12 September 2013 - 11:31 AM
So, I'm running this ROM and my 3g/4g doesn't work
#936 ANDROIDRAZRM
ANDROIDRAZRM
  • 56 posts
Posted 12 September 2013 - 11:42 AM
Did you mount everything before flashing? What baseband are you running?
#937 Caleb
Caleb
  • 12 posts
Posted 12 September 2013 - 12:45 PM
Thought I mounted everything, not sure what baseband. How do I find out?
#938 Caleb
Caleb
  • 12 posts
Posted 14 September 2013 - 06:50 AM
Ok...got the 3g/4g to work, but now I cannot send group message...well I can but any text i put in the group message or pictures even, won't send. And to add to that, I get individual texts from people I send group messages to instead of receiving them in group messages. It works on stock ROM, but not in deadpool...
...any fix to this?
#939 brianjamiel747180
brianjamiel747180
  • 100 posts
  • Locationkent
  • Current Device(s):xt907
Posted 14 September 2013 - 12:12 PM
...any fix to this?
you got further then me when i flashed this i got a black screen i am unlocked and i flashed the gapps package didn't get anywhere with this ROM but now my boot logo is dead calms skull for some reason where it would show the Motorola M kicker is im not even running the ROM im running liquid smooth i have liquid smooths boot animation that it goes through but before that its dead calms boot logo ive wiped it idk how many times and still the same logo so idk what happened
61ZM(0)
#940 aviwdoowks
aviwdoowks
  • 140 posts
Posted 14 September 2013 - 12:50 PM
The "dead clam head fix" is many posts back & @ xda. Lol.
