I flashed this using SS, I'm on a locked bootloader. I no longer have any 4G service.
That must be cause your kernel is unchangeable & is newer one than is compatible with DC?
Conclusion? It was SS able but after the UD no?
Posted 21 August 2013 - 08:46 AM
Posted 23 August 2013 - 12:14 PM
Posted 23 August 2013 - 12:25 PM
Posted 23 August 2013 - 01:03 PM
I need help lol I want this rom
Did you mount system?
Posted 23 August 2013 - 01:59 PM
Posted 23 August 2013 - 02:00 PM
Posted 23 August 2013 - 02:14 PM
Make sure you have a good download. What rom are you coming from. If you are coming from a 4.2 Rom you may need the stock Kernel
Posted 23 August 2013 - 02:23 PM
Posted 23 August 2013 - 02:34 PM
Right now I'm on DST with mods but when I tried it I think I was a 4.2
Are you unlocked?? You should be fine coming from dst. That's stock 4.1.2.
Try this...
Make sure zip is on your ext sd card
In recovery..
wipe cache
wipe dalvik
wipe system
wipe data
mount system
install rom from zip
Posted 23 August 2013 - 02:57 PM
Posted 25 August 2013 - 04:50 PM
so...how do you install this? It's been a few years since I hacked my motorola droid...
Posted 26 August 2013 - 03:06 PM
THIS IS A CDMA BUILD FOR VERIZON USERS ONLY!!!!!!
This build is based off mhous33's DST 4.1.2 build
Credits:
mhous33 - DST base build (thank you!)
Android
Motorola (lol yeah right)
Team OSE
Hashcode
Dhacker
DDX
Mattlgroff
vtwinbmx
Bytecode
Vantenkiest
Gerland The Oracle
jvasquezhhi
Ok I could go on and on doing this, too many people here deserve thanks.
What Works?
Everything
Bugs?
Hopefully None
Features:
Deodexed
Debloated
Zipaligned
Pre-Rooted
Adb InsecuredLoopy Smoothness (Scrolling Smoothness Tweak)
Full Init.d Support
CPU SleeperSeeder
Amazing Battery Saving Tweaks
Tons Of Awesome build.prop TweaksCustom Boot Animation and Sound (Thanks to ZKK007)
Custom Boot Logo (Thanks to Zooyork)
MORE TO FOLLOW!
TO DO LIST:
I am always up for suggestions....
INSTALL:
You know the deal.Mount Everything, Wipe Everything (cache, dalvik cache, factory reset, system) TWICE, Reboot Recovery, Mount Everything Again, Flash, Reboot, Profit
Download DeadCalm:
Download DeadCalm No Soft Key Mod (Thanks to Clienterror)
(Must be Flashed after ROM zip)
Link to s.dubs Mods
Does this require you to be Unlocked?
Posted 26 August 2013 - 03:28 PM
Posted 26 August 2013 - 04:11 PM
Good grief, the entire OP?
To answer your question, you should be able to flash this on a locked BL, with SafeStrap.
Posted 26 August 2013 - 04:14 PM
Posted 26 August 2013 - 04:41 PM
How do we change the soft keys or colors of the status bar and soft keys?
Posted 26 August 2013 - 04:44 PM
Use the last 2 links in the OP for mods.
Posted 26 August 2013 - 08:09 PM
Ok....got my razr m rooted and have safestrap installed, but for the life of me cannot get this rom to install..am I doing something wrong?
Posted 26 August 2013 - 08:10 PM
Mount system?Ok....got my razr m rooted and have safestrap installed, but for the life of me cannot get this rom to install..am I doing something wrong?
Posted 26 August 2013 - 08:12 PM
Mount system?
Honestly, I'm confused...it's more complicated then my old droid 1
