RAZR M ROM STOCK
951 replies to this topic
#841 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
  • Twitter:@timpohladthomas
  • Current Device(s):MOTO X
Posted 17 July 2013 - 02:26 PM
Op updated with new name only.
#842 jesseg91631
jesseg91631
  • 18 posts
Posted 23 July 2013 - 05:09 AM
I noticed that when I am talking on the phone the screen does not auto blackout. Is this working for anyone else? Thanks.
#843 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 23 July 2013 - 05:53 AM
It's not a bug... It's a tweak.. If you are able to go into the build.prop and edit you will need to change the proximity line to a higher number like 200.
  • jesseg91631 and gambit24 like this
#844 BwingG
BwingG
  • 140 posts
  • LocationSeattle
  • Current Device(s):RazrM
Posted 23 July 2013 - 07:26 AM
Are you using a custom kernel?
  • jesseg91631 likes this
#845 jesseg91631
jesseg91631
  • 18 posts
Posted 24 July 2013 - 07:01 PM
Nope, I simply installed this ROM as is and have not customized anything myself.
#846 jesseg91631
jesseg91631
  • 18 posts
Posted 24 July 2013 - 07:23 PM
Thank you, I found build.prop but did not see anything that said proximity in the file. Could you tell me what the proximity line reads?
#847 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 25 July 2013 - 09:32 AM
I will have to look and get back to you...dont remember exactly.
#848 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 25 July 2013 - 09:33 AM
I have a challenge for everyone following this thread.
If you can find the M fastboot files for the newest update then I will update the base of this rom with all the new goodies!
Ready.......and.........GO!
  • evocop, moto13 and LSDWiZaRd like this
#849 BwingG
BwingG
  • 140 posts
  • LocationSeattle
Posted 25 July 2013 - 09:43 AM
THIS THEM
#850 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 25 July 2013 - 09:54 AM
THIS THEM
No sorry, this are the ones currently being used as a base.
#851 zooyork0721
zooyork0721
    All Around Man
  • 979 posts
  • LocationNew York, NY
Posted 25 July 2013 - 10:40 AM
try this ;)
  • evocop likes this
#852 moto13
moto13
  • 45 posts
  • Current Device(s):Razr M
Posted 25 July 2013 - 11:03 AM
This is great news Tim!
  • evocop likes this
#853 roflBeck
roflBeck
  • 11 posts
  • Current Device(s):Motorola Droid Razr M, Motorola Cliq 2 (deactivated SIM)
Posted 26 July 2013 - 01:52 PM
You still planning on adding in the volume key music controls? I'd love to have that on this awesome ROM and I don't know enough to hack it in myself.
#854 aviwdoowks
aviwdoowks
  • 140 posts
Posted 26 July 2013 - 05:46 PM
Thanks for the super fast stock based rom.
FWISW you can twrp restrore (data) from DeadCalm over the top of this
(system & boot) and have newer kernel & the latest radio.  Built in sd swap.
Just wipe dalvik & cache.
#855 gambit24
gambit24
  • 5 posts
Posted 27 July 2013 - 05:27 AM
First off I'd like to thank Tim on doing an amazing job on this ROM.That being said the op should be updated to include the link to the kernel needed to fix rotation and sensors problem. Also I've read this entire thread from start to finish but no one has mentioned the minor issue I'm having with the No Soft Key Mod. Has anyone else experienced a very light blue tint rectangle at the bottom of their screen? It's hardly noticeable, but it really stands out against a white background. Is it just me?
#856 gambit24
gambit24
  • 5 posts
Posted 27 July 2013 - 06:12 AM
In addition it seems I have encountered another problem. I flashed a few things such as bw theme, boot logo, and honey comb battery mod. Now I keep getting notifications telling me Google+ and gmail are not working. I'm sure this is probably an easy fix I'm just too tired and cross eyed at the moment to figure it out. And yes I wiped yadda yadda yadda...
:update: fixed with tibu by restoring old back up.
#857 jesseg91631
jesseg91631
  • 18 posts
Posted 30 July 2013 - 03:05 AM
So when I flash the Avstralia rom, should I flash the dead calm over it? Will this fix the rotation and proximity issue?
#858 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 30 July 2013 - 05:32 AM
I would just clean flash DeadCalm and use this kernel:
 Make sure you use the stock based kernel in post #2.
#859 gemosupe
gemosupe
  • 6 posts
Posted 31 July 2013 - 09:30 AM
Okay sorry for the stupid question, since the kernel will fix the rotation and proximity issue I want to make sure I'm getting the right one, looks like he has several for 4.12 under FFW-5. Which one is being recommended and what is the best way to flash it.
#860 roflBeck
roflBeck
  • 11 posts
Posted 31 July 2013 - 10:08 AM
I used v0.19 FFW-5 in post #2 in that link. Flashed with TWRP.
