I am hearing stories of relocking bootloaders... So I am just gonna wait till someone tears it apart and pulls all that stuff out of it.. then I will update the base.Is the new 98.16.3.XT907 build looking promising?
( think that was yesterdays OTA build)
#821
Posted 11 July 2013 - 01:10 PM
- moto13 likes this
#822
Posted 11 July 2013 - 03:39 PM
So... been running this for awhile. Since the last version went online. I'm having the following issues that just don't seem to fix themselves. Has anyone else experienced the following? Should I try re-flashing?
- No Tilt (realize this is a issue with others and heard that it was because of YouTube)
- Proximity sensor doesn't work
- Doesn't detect phone taps (Think of applications like "BUMP" that require you to tap your phone)
Any ideas?
Twitter: @motoroid7
ADN: @seven07
#823
Posted 11 July 2013 - 03:43 PM
you need the kernel up some postsSo... been running this for awhile. Since the last version went online. I'm having the following issues that just don't seem to fix themselves. Has anyone else experienced the following? Should I try re-flashing?
Any ideas?
- motoroid7 likes this
#824
#825
Posted 11 July 2013 - 03:53 PM
Just to make sure, are you referring to this one?
Use this kernel that Tim suggested
just go into recovery mount and flash
- BwingG likes this
Twitter: @motoroid7
ADN: @seven07
#826
Posted 11 July 2013 - 03:55 PM
yup! Sorry I didn't put a linkJust to make sure, are you referring to this one?
#827
Posted 11 July 2013 - 04:01 PM
Kernel or 1.3 BW was what I was flashing, yes in the right order. Haha
#828
Posted 12 July 2013 - 10:26 AM
#829
Posted 12 July 2013 - 11:01 AM
Using crossbreeder with this ROM is amazing. Wish I could find a frandom module that worked with this ROM and arrrghhh's kernel.
Pull it out of my kernel. Should still work.
Sent from my Nexus 4 using Tapatalk 4 Beta
- timpohladthomas likes this
#830
Posted 12 July 2013 - 03:45 PM
WE ARE DOING BIG THINGS! :
- LSDWiZaRd likes this
#831
Posted 13 July 2013 - 08:39 AM
#832
Posted 14 July 2013 - 09:46 AM
Push frandom.ko to system/lib/modules?Pull it out of my kernel. Should still work.
#833
Posted 14 July 2013 - 01:33 PM
#834
Posted 14 July 2013 - 04:41 PM
#835
Posted 14 July 2013 - 05:10 PM
I downloaded a deodexed messaging.apk and put into system/apps after deleting mms.apk. Of course it is back to stock messaging but have no issues with group messaging or pictures now.I have MMS issues sometimes too. Sends a whit dot instead if a picture and it's never received by the people I send it to. Not every time just occasionally.
#836
Posted 14 July 2013 - 05:34 PM
#837
Posted 14 July 2013 - 06:15 PM
I understand but it wasn't working for me all that great so that is why I switched, send a lot of group text and pictures so I need those Features to work consistentlyWould do but I like the quick reply and other features of the MMS.apk in this build.
#838
Posted 16 July 2013 - 07:39 AM
#839
Posted 16 July 2013 - 07:44 AM
Sounds good. Bradgeorge4@gmail.comHey guys, just want to let you know that OSE has a Google hangout setup for any Q/A and it will also be the place I or any other team member will be releasing test builds. So if you wanna be on the bleeding edge of development then just let me know your Gmail in the thread or through pm!
