Can I post screenshots from mobile?
Yes, you should be able to.
Posted 05 July 2013 - 01:41 PM
Sooo....like tomorrow? LolThe M may be getting new software... If so I will update this base or possibly release a new one.
Posted 05 July 2013 - 02:30 PM
I tried. Hahaha. Besides between here and your other stuff I'm staying busy.Haha, nice try.
Posted 05 July 2013 - 06:01 PM
Posted 06 July 2013 - 12:33 PM
What voltages?
Posted 06 July 2013 - 12:34 PM
can we avoid the SOAK update?
Posted 06 July 2013 - 02:56 PM
turn off the porch light and don't answer any phone callscan we avoid the SOAK update?
Posted 07 July 2013 - 08:48 PM
Posted 09 July 2013 - 02:13 AM
Posted 09 July 2013 - 07:23 AM
Hello, I was wondering if this rom does the 4gLTE, The rom i have not does not have the Lte and its so slow xD, Thanks
Posted 09 July 2013 - 08:10 AM
Posted 11 July 2013 - 05:56 AM
Posted 11 July 2013 - 08:11 AM
Anything in the works on this Rom Tim?
Posted 11 July 2013 - 12:22 PM
Posted 11 July 2013 - 12:24 PM
How's the battery life in the AOSP builds compared to 4.1.2, Tim? I last tried one about a month ago and it was probably half as good as deadrage, if that. I was also having problems with Wi-Fi signal strength.
Posted 11 July 2013 - 01:01 PM
A lot of those things are being fixed daily by the developers. It may not the exactly the same as stock... But in my opinion, it is way smoother than stock. It's all user preference. I just prefer it for now... Like I said... If something comes up, like an update... I will update the base of the rom.
Is the new 98.16.3.XT907 build looking promising?
( think that was yesterdays OTA build)
