RAZR M ROM STOCK
951 replies to this topic
#781 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
  • Twitter:@timpohladthomas
  • Current Device(s):MOTO X
Posted 27 June 2013 - 05:09 PM
Does wifi tether work on this rom?
Yes sir.
  • boomerxyz likes this
#782 boomerxyz
boomerxyz
Posted 27 June 2013 - 08:54 PM
Thanks for the wifi tether! If i wanted to restore default motorola launcher, which files would I restore?
#783 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 28 June 2013 - 02:47 AM
Homescreen and homescreen config
#784 boomerxyz
boomerxyz
Posted 28 June 2013 - 04:18 PM
Were you able to fix the autorotate? Mine will not rotate at all in any app.
#785 BwingG
BwingG
  • 140 posts
  • LocationSeattle
  • Current Device(s):RazrM
Posted 28 June 2013 - 04:19 PM
Use the above mentioned kernel. It fixes it
  • timpohladthomas and justinjohnson86 like this
#786 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 28 June 2013 - 05:54 PM
What he said.
#787 doanlc
doanlc
Posted 29 June 2013 - 01:07 PM
Having a little problem...
Was using Safe-Strap to flash this, and I got this error:
"assert failed: write_raw_image1"/boot.img". "boot"
E:Error in /sdcard/Download/DeadRage.zip
(Status 7)"
However, I rebooted, and hit continue instead of going back into recovery. After the phone loading, it seems the mod was flashed.
My about phone says
Build Number: Dead Rage 1.4 etc. etc.
Phone seems to be working alright. Should I redo the flash because of the above error?
#788 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 29 June 2013 - 01:14 PM
(Status 7)"
My about phone says
No, if it's running fine then just run with it! :ph34r:
#789 LSDWiZaRd
LSDWiZaRd
  • 59 posts
  • LocationColcord, OK
  • Current Device(s):Motorola Droid RAZR M
Posted 03 July 2013 - 12:07 PM
Hey Tim I have a request if possible.
Can I get a mobile data enable/disable feature in the power settings or maybe a sub menu when you hit airplane mode while in the power settings, that would be great if you can since there's no quick settings on the home screen anymore:)
#790 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 03 July 2013 - 12:22 PM
Hey man... Not sure I can do that. Are you talking about the toggles on the home screen? I can find you a good free one.
Here ya go...
#791 LSDWiZaRd
LSDWiZaRd
  • 59 posts
Posted 03 July 2013 - 04:54 PM
Hey man... Not sure I can do that. Are you talking about the toggles on the home screen? I can find you a good free one.Here ya go...
I was thinking of the menu when you hold the power button but this might work too:)
  • timpohladthomas likes this
#792 Someolddude
Someolddude
  • 426 posts
Posted 03 July 2013 - 05:17 PM
(Status 7)"
My about phone says
Mine did the same thing when I flashed with safe strap. Only problem was it used my internal memory for the ROM slot and didn't like that so I unlocked and used twrp.
#793 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 03 July 2013 - 05:35 PM
That is a much better option.
#794 kendog
kendog
  • 234 posts
  • LocationMillville, NJ
  • Current Device(s):droid bionic
Posted 03 July 2013 - 06:49 PM
Took me an hour or two to get this phone setup the way I like it but I really love this ROM!! It is really great.. One question what gov do y'all put it on msm-dcvs or interactive?
  • BwingG likes this
#795 LSDWiZaRd
LSDWiZaRd
  • 59 posts
Posted 03 July 2013 - 07:28 PM
On Demand with 96Mhz undervolted and 1.89Mhz overvolted:)
#796 kendog
kendog
  • 234 posts
Posted 03 July 2013 - 07:30 PM
You got an overclock zip it only goes too 1.512 max freq
#797 LSDWiZaRd
LSDWiZaRd
  • 59 posts
Posted 03 July 2013 - 07:33 PM
Use this kernel that Tim suggested
just go into recovery mount and flash
#798 kendog
kendog
  • 234 posts
Posted 03 July 2013 - 07:44 PM
Your using the 0.19 ver? Thank you I appreciate the help..
#799 mykalmunlight
mykalmunlight
  • 88 posts
  • Current Device(s):XT907 (DROID RAZR M)
Posted 03 July 2013 - 09:10 PM
What voltages?
#800 LSDWiZaRd
LSDWiZaRd
  • 59 posts
Posted 05 July 2013 - 12:23 PM
What voltages?
Can I post screenshots from mobile?
