The kernel allows for over clocking and more governor and scheduler options.People have gotten 6100 quadrant scores using it.
How would I over clock it?
Posted 20 June 2013 - 12:38 PM
Posted 20 June 2013 - 12:39 PM
How would I over clock it?The kernel allows for over clocking and more governor and scheduler options.People have gotten 6100 quadrant scores using it.
Posted 20 June 2013 - 05:35 PM
Posted 21 June 2013 - 05:47 PM
delete
Posted 21 June 2013 - 06:46 PM
Posted 22 June 2013 - 09:38 AM
The rotation always works for me also after a reboot or power down. But after using it watching YouTube is when it glitches out. Weird how it has the ability to work yet stops after its used a few times.
Yeah. That's what happened. After it slept for a little bit, the rotation quit.
Posted 22 June 2013 - 10:13 AM
I think it comes down to how much debloating you can do before things start malfunctioning. I've had no auto rotate problems whatsoever with 4.1.2 stock ROM so it leads me to think dead rage is missing some building blocks.
Posted 22 June 2013 - 11:59 AM
You are correct sir. Been busy lately... Sorry guys...
No worries, dude. We all know you have somewhat of a life outside of dev'ing.
Posted 22 June 2013 - 01:17 PM
Run the kernel Tim suggested earlier, my sensors and autorotation are back and working like normal.
Posted 23 June 2013 - 05:28 AM
+1
Posted 23 June 2013 - 01:05 PM
Posted 23 June 2013 - 07:03 PM
coming back to rage starting fresh, can the suggested kernel be flashed at the same time as the rom?
Posted 23 June 2013 - 08:07 PM
Yes, flash the ROM, then flash the kernel.coming back to rage starting fresh, can the suggested kernel be flashed at the same time as the rom?
Posted 24 June 2013 - 03:44 AM
Posted 24 June 2013 - 07:55 AM
Posted 24 June 2013 - 08:20 AM
Yup kernel fixed rotation/sensor issue. So happy now with this Rom
Posted 24 June 2013 - 08:50 AM
Posted 24 June 2013 - 01:01 PM
Tim,
If replacing the kernel fixed the auto-rotation issue does Dead Rage have a custom Kernel? I was assuming that it was using the stock 4.1.2 kernel.
