reboots help everything!
#722
Posted 14 June 2013 - 06:38 PM
Anyone having some issues with MMS in 1.4? When I attach a picture, it ends up sending a blank message.
Twitter: @motoroid7
ADN: @seven07
#723
Posted 15 June 2013 - 03:07 PM
#724
Posted 15 June 2013 - 04:07 PM
Wondering what's the deal with the no soft key mod. I flashed it and all went well. The extra screen space is great only problem is what you supposed to do not having those keys? I had to go into recovery and restore because I couldn't figure out how to get back to my main screen. Also probably gonna answer my own question but should you flash no soft key and lock screen mod at the same time? I lost lock screen mod after. Awesome ROM BTW starting to feel real comfortable using it even with the auto rotate being wacky .
you need to install the LMT app first (and set to start at startup)
- Someolddude and LSDWiZaRd like this
ROM: OSE KitKat 4.4.2
#725
Posted 15 June 2013 - 04:20 PM
- LSDWiZaRd likes this
#726
Posted 16 June 2013 - 11:33 AM
I've discovered a solution to my whole MMS problem I was having sending pictures. It seems I have to select "view" after I attach the image... then it'll send correctly. If I don't hit view it will send a blank message of 1KB. I've provided a screenshot of what it looks like:
Twitter: @motoroid7
ADN: @seven07
#727
Posted 18 June 2013 - 05:02 AM
Soo for some reason that has so far escaped me, I am not getting any notifications in the notifications bar. Any ideas/suggestions? Everything else is smooth as butter. Love it!
#728
Posted 18 June 2013 - 12:16 PM
You get no notifications at all? or just for certain apps? Screenshot of your notification shade and/or homescreen?
#729
Posted 19 June 2013 - 02:52 PM
So, is the download link updated for 1.4? Or is that not publicly released yet? I'm running 1.2, and would like to update soon! When I click on the link below Download DeadRage, it brings me to the page, but it says v1.2!
#730
Posted 19 June 2013 - 03:25 PM
#731
Posted 19 June 2013 - 03:28 PM
DL said 1.4 for me
- timpohladthomas likes this
#732
Posted 19 June 2013 - 05:47 PM
None at all. And now having issues with my soft keys. Running twrp on rooted unlocked dev ed. Screenshot attachedYou get no notifications at all? or just for certain apps? Screenshot of your notification shade and/or homescreen?
15.68KB 28 downloads
#733
Posted 19 June 2013 - 06:10 PM
http://www.droidrzr.com/public/style_images/dark_matter/attachicon.gif
Sounds like a bad flash as this is the first I have heard of these issues. Try reflashing on a clean slate.
#735
Posted 20 June 2013 - 04:24 AM
- LSDWiZaRd and justinjohnson86 like this
#736
Posted 20 June 2013 - 05:16 AM
Just flashed this kernel as per your recommendation. Also just bought SetCPU. This is actually the first time I've flashed a non-stock kernel, so do you have any recommended settings that I should be using? Not too familiar with any of the options for governor's etc in SetCPU. Thanks for any guidance.
For anyone that has not seen this yet. I highly recommend running this kernel with DeadRage.
The best way to flash if already running DeadRage is to wipe cache and dalvik, mount system, flash, reboot, enjoy.
#737
Posted 20 June 2013 - 06:27 AM
Flying jelly doesn't have this issue. Is it a bad download then causing it?So it looks like the sensor issue is not a rom specific issue.
Could be a 4.1.2 issue
#738
Posted 20 June 2013 - 07:52 AM
#739
Posted 20 June 2013 - 08:34 AM
I don't think you can access it.Just flashed the kernel, not sure what it helps or how to access it, only flashed because Tim recommended it:)
via RAZR S4
