RAZR M ROM STOCK
951 replies to this topic
#701 Guest_BDH_*
Guest_BDH_*
Posted 09 June 2013 - 11:31 PM
CORRECTION!!!!
webchat.freenode.net
Channel: #TeamRage
Come hang out and chat with the Team 24-7!!!
  • timpohladthomas likes this
#702 romma1
romma1
  • 127 posts
  • Current Device(s):Razr M
Posted 10 June 2013 - 08:51 AM
This rom is outstanding so far. I have zero issues that I am aware of, and it is pretty damn buttery smooth!! The best so far for me on the 907!
  • timpohladthomas and LSDWiZaRd like this
#703 jvasquezhhi
jvasquezhhi
    Frankensteiner
  • 330 posts
Posted 10 June 2013 - 12:01 PM
I didn't install the debloated apps and I had issues
you dont have to install the debloated apps... and i think only issue this rom has is the rotation
#704 justinjohnson86
justinjohnson86
  • 23 posts
Posted 11 June 2013 - 02:53 AM
I know, i realized that after a fresh install to get rotation working. Just pointing out that the debloated apps werent the issue. I wonder if i did a nandroid backup of a stock (like) rom and used titanium backup to extract the movement apk fron the nandroid to rage if it would fix it.... Or soft brick lol. Always worth a shot
  • timpohladthomas and jco23 like this
#705 Bmplekan
Bmplekan
  • 27 posts
  • Twitter:@plekanb
  • LocationNY
Posted 12 June 2013 - 05:24 AM
2 Things, 1) For me, the rotation issue was fixed on a fresh install until the phone screen timed out. When I woke it back up, no more rotation. Not a big deal at all, and not a reason to not flash the rom IMO. However, since then I've flashed like 3 other roms, 4.1.2 and 4.2.2 based and since inevitably I had to fastboot back to stock to clean it up i noticed something. Which leads me to 2) I no longer get the unlocked bootloader screen on boot, I get a steal-ur-face like logo instead, even after restoring to stock. In case I do sell / trade the phone, is there a way to get rid of that (not that I like to bootloader warning screen), i just would want to give someone a "stock" phone for a trade. Thank you in advance.
#706 jco23
jco23
  • 414 posts
Posted 12 June 2013 - 05:29 AM
just flash a stock ROM - there are few of them floating around.  I think you can use the one Tim created in this forum, and there's a clean rom on XDA as well.  can't speak to Tim's, but the clean rom on XDA has the stock bootloader logo and boot animation.
  • Bmplekan likes this
ROM: OSE KitKat 4.4.2
#707 motoroid7
motoroid7
  • 56 posts
  • Twitter:motoroid7
  • LocationBloomington, Indiana
  • Current Device(s):RAZR M
Posted 12 June 2013 - 03:48 PM
I'm not sure if this has already been asked somewhere for this ROM, but how do I possibly change the 1% battery mod to say... 10% or anything else so that status bar icon's from say Rom Toolbox PRO work correctly? I've noticed when picking a different battery theme from there it doesn't work correctly unless the theme has all icons for 1%.
Twitter: @motoroid7
ADN: @seven07
#708 justinjohnson86
justinjohnson86
  • 23 posts
Posted 13 June 2013 - 03:03 AM
You can also use the RAZR m toolbox (p3 toolbox) and change the boot logo while running deadrage. Won't affect the ROM. Or use the razr m utility to flash stock ROM which I believe removes root and any recovery you have.
#709 jco23
jco23
  • 414 posts
Posted 13 June 2013 - 04:08 AM
i believe that the RAZR m toolbox only worked on 4.1.1. - and it could alter the boot animation, not the boot logo.
#710 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 13 June 2013 - 06:00 AM
The only time I've ever had the Toolbox work correctly was on my 4.1.1 stock ROM.  After I updated to a 4.1.2 ROM, I tried updating the battery icon and it turned me into a soft brick.
Go here for some flashable boot logos:
#711 motoroid7
motoroid7
  • 56 posts
  • Twitter:motoroid7
Posted 13 June 2013 - 02:38 PM
I have the logo if whoever needs it for the stock boot logo. Then just use fastboot to "fastboot flash logo logo.bin" via command line. (If you have adb/fastboot setup on your computer) Thought I would try and help if I could... This is the process I use for changing my boot logo.
  • Bmplekan and timpohladthomas like this
Twitter: @motoroid7
ADN: @seven07
#712 jsbenson
jsbenson
  • 5 posts
  • Current Device(s):RAZR M, Nexus 7 (16GB WiFi)
Posted 13 June 2013 - 03:23 PM
Got a quick question about the D.R. themes. I flashed the blue steel and liked it. I then flashed the BW and decided I liked the blue better. I try installing the blue theme but it doesn't take. In TWRP it posts success but it runs too quickly. The apps update on the next boot but the theme is still BW.
The one time I didn't do a backup :(
Anyone got any advice?
#713 BwingG
BwingG
  • 140 posts
  • LocationSeattle
  • Current Device(s):RazrM
Posted 13 June 2013 - 06:19 PM
ive never had that issue.  sounds like fresh install time.
#714 BwingG
BwingG
  • 140 posts
  • LocationSeattle
Posted 13 June 2013 - 06:23 PM
no rotation issue on fjelly.  i hope this means we can get it fixed on rage.   i like rage so much more.
  • timpohladthomas and brandon71 like this
#715 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
  • Twitter:@timpohladthomas
  • Current Device(s):MOTO X
Posted 13 June 2013 - 07:24 PM
Oh, we can... Don't worry. :ph34r:
  • BwingG, jco23, romma1 and 1 other like this
#716 justinjohnson86
justinjohnson86
  • 23 posts
Posted 14 June 2013 - 05:23 AM
Yeah the battery mod will softbrick 4.1.2. I was able to change bootlogo when I flashed using ROM toolbox. Adb/fastboot is good as well though
#717 Someolddude
Someolddude
  • 426 posts
Posted 14 June 2013 - 04:55 PM
Wondering if its possible to get Google circles working on the rage? I've grown fond of them . Also adfree didn't want to function is it not compatible?
  • LSDWiZaRd likes this
#718 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 14 June 2013 - 05:40 PM
I am not sure what you are talking about when you say Google circles. I was not aware ad free didn't work... There is no reason that should be true.
If you can give me more information I may be able to help.
#719 Someolddude
Someolddude
  • 426 posts
Posted 14 June 2013 - 06:24 PM
Adfree just keeps twirling the circle like its stuck and doesn't get to the point of asking for su permitions. The Google circles I'm talking about are the stock main page where the clock/weather and bat status are. I couldn't get titanium backup to restore them. Not sure how many things need to be restored for them to function.
#720 Someolddude
Someolddude
  • 426 posts
Posted 14 June 2013 - 06:30 PM
Wtf just tried again and adfree worked. I tried like 5 times before may have been the reboot.
