#621
Posted 01 June 2013 - 05:27 PM
- timpohladthomas likes this
#622
Posted 01 June 2013 - 06:07 PM
Oh... Besides Facebook.
#623
Posted 01 June 2013 - 06:10 PM
Everything works great. Love the ROM. Is there more themes then just the black and white, red, metallic blue.
Not yet... But I am sure some are in the mix.
#624
Posted 01 June 2013 - 06:13 PM
#625
Posted 02 June 2013 - 07:22 AM
#626
Posted 02 June 2013 - 08:02 AM
#627
Posted 02 June 2013 - 08:08 AM
What's this LMT pie launcher everyone's talking about and where do I get it?
Its a customizable launcher with pie controls. People like it because you can then get rid of the soft keys and use LMT and pie controls. Giving you a true full screen effect. I found it doing a Google search. I used it for a bit but didn't personally care for it.
#628
Posted 02 June 2013 - 08:09 AM
Try rebooting and then see if Facebook will install.
#630
Posted 02 June 2013 - 08:34 AM
I just used it and I'm going to install the red theme once the link goes back up, will I be able to install the no soft keys mod on that theme?
#631
Posted 02 June 2013 - 08:53 AM
If the theme has one.
#632
Posted 02 June 2013 - 08:54 AM
You should be able to install the mod on any theme. It flashes through recovery.
#633
Posted 02 June 2013 - 10:17 AM
#634
Posted 02 June 2013 - 11:12 AM
Anybody use m utility and have the rotation issue. I'm thinking about starting all over to see if that's the difference but before I do i wanted to know if others had used it but still had the issue. Thanks
Are you referring to Matt's utility.
#635
Posted 02 June 2013 - 11:14 AM
Yes
#636
Posted 02 June 2013 - 12:04 PM
Yes
I used both 1.10 and 1.20. And still had sensor issues.
#637
Posted 02 June 2013 - 02:55 PM
Facebook will not install.. error 491.
It's not a Rom issueFacebook will not install.. error 491.
Clear the cache of the Google Play Store app(visit Settings > Applications > Clear cache) or wipe Dalvik and Cache partition in your recovery
Restart your device
Wait 10 minutes with it turned on not doing anything on it just let it sit there after 10 min try your download again.
This is a ROM settling issue usually
#638 Guest_BDH_*
Posted 02 June 2013 - 09:52 PM
Sent from my Raged Out HD using Tapatalk (VIP)
- timpohladthomas and PantherVT like this
#639
Posted 04 June 2013 - 06:47 AM
I will most likely release it tonight but at the latest first thing in the morning.
Thanks for sticking in there guys. And feel free to vote for me in the developer HD giveaway. :
- jamminjon82, jco23 and moto13 like this
#640
Posted 04 June 2013 - 07:08 AM
OK first im new to this so sorry if this is a stupid question
So I have an issue I installed via safestrap. Slot one. Flash back to stock and flashed a diff ROM to slot one. But I still have dead rage skull for a boot logo. I unlocked my boot loader so that replaced the warning screen so that's nice so the question is how do I remove the boot or change it thanks alot. Cool ROM very streamlined.
