Can I ever re-lock it in case I drop my phone and need it repaired?
No. Its permanent. But worth it if your into ROMs
Posted 31 May 2013 - 06:50 PM
Posted 01 June 2013 - 09:36 AM
if you drop it claim stolen lol.. or put it in microwave for 30 secs that would do the job too
Posted 01 June 2013 - 11:41 AM
Posted 01 June 2013 - 11:59 AM
Posted 01 June 2013 - 02:15 PM
Posted 01 June 2013 - 03:03 PM
Reboot into TWRP 2.3.2.3 Mount Everything, Wipe Everything (cache, dalvik cache, factory reset, system) TWICE, (Reboot)Then reboot into
? Mount Everything Again, Flash, Reboot. Where it says mount everything ( Mount system, data, cache, SD card.. ( use external or internal storage.. and do the same mounting for the second reboot as well?
Posted 01 June 2013 - 03:05 PM
Reboot into TWRP 2.3.2.3 Mount Everything, Wipe Everything (cache, dalvik cache, factory reset, system) TWICE, (Reboot)Then reboot intoRecovery? Mount Everything Again, Flash, Reboot. Where it says mount everything ( Mount system, data, cache, SD card.. ( use external or internal storage.. and do the same mounting for the second reboot as well?
thanks man! just want this time i flash it to work!
Edited by basiljames, 01 June 2013 - 03:10 PM.
Posted 01 June 2013 - 03:06 PM
do i flash the theme when i flash the ROM or flash rom then reboot set up phone boot recovery flash theme ..do i need to wipe anything when i flash theme?
Edited by basiljames, 01 June 2013 - 03:08 PM.
Posted 01 June 2013 - 03:08 PM
Posted 01 June 2013 - 03:11 PM
when mounting?
Posted 01 June 2013 - 03:16 PM
when mounting?
Posted 01 June 2013 - 03:23 PM
so don't mount SD card. data, or cache just System. The last couple of times i tried to flash this rom I did not have system mounted and it didnt work because im guewssing it said unable to mount cache.
Or because system was not mounted.
Edited by basiljames, 01 June 2013 - 03:26 PM.
Posted 01 June 2013 - 03:24 PM
In mount menu do i check use external or internal storage.
Posted 01 June 2013 - 03:27 PM
Can I flash the soft key mod on the orion ROM without problems?
Posted 01 June 2013 - 03:35 PM
In mount menu do i check use external or internal storage?
Posted 01 June 2013 - 04:30 PM
Thank you sir I was debating that for a very long timeIt will cause your phone not to boot if you flash it.
2
Posted 01 June 2013 - 04:37 PM
Facebook will not install.. error 491.
Posted 01 June 2013 - 05:11 PM
