RAZR M ROM STOCK
951 replies to this topic
#501 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
  • Twitter:@timpohladthomas
  • Current Device(s):MOTO X
Posted 24 May 2013 - 02:53 AM
Any word of fixing the screen shaking every once in a while from side to side?
Love my RAZR M
I noticed this also. I just attributed it to me being crazy :-P
Ha, that's funny. I also thought I was crazy... And maybe I am. Just not because of that.
#502 BwingG
BwingG
  • 140 posts
  • LocationSeattle
  • Current Device(s):RazrM
Posted 24 May 2013 - 05:17 AM
I've tried everything you guys have mentioned about auto rotate but nothing fixes mine? Any suggestions? I've never unzipped and signed a file after deleting a file but could this be done to remove cpu sleeper?
#503 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 24 May 2013 - 05:50 AM
Just use titanium backup to remove it.
#504 BwingG
BwingG
  • 140 posts
  • LocationSeattle
Posted 24 May 2013 - 06:06 AM
I did. But like I said my rotate doesn't come back. I'll try starting over from the top.
#505 BwingG
BwingG
  • 140 posts
  • LocationSeattle
Posted 24 May 2013 - 06:07 AM
So is it true only some of us are having rotate problems?
#506 ANDROIDRAZRM
ANDROIDRAZRM
  • 56 posts
Posted 24 May 2013 - 06:15 AM
I've never had a rotation issue, but the first thing I do is remove all of the apks I don't use like cpu sleeper, seeder, Motorola junk, etc, etc.
#507 justinjohnson86
justinjohnson86
  • 23 posts
Posted 24 May 2013 - 06:25 AM
I'm having the rotate problem too. Used to have it. Now its gone....gone I say! :(
  • BwingG likes this
#508 BwingG
BwingG
  • 140 posts
  • LocationSeattle
Posted 24 May 2013 - 06:27 AM
Even after reboots?
#509 BwingG
BwingG
  • 140 posts
  • LocationSeattle
Posted 24 May 2013 - 06:29 AM
I just did a fresh install and rotation is back. I guess I'll just never reboot again. Haha. But that means no themes which sucks
#510 jco23
jco23
  • 414 posts
Posted 24 May 2013 - 06:31 AM
mine is themed (s.dubs' icons and lock screen). CPU sleeper installed (but not activated - yet I get incredible battery life) and I have rotation back too.
here are my suggestions:
1.) reboot to recovery, mount system, wipe cache, wipe dalvik, reboot system
2.) reboot to recovery, mount system, wipe cache, wipe dalvik, install deadrage 1.2a, reboot system
on a side note, curious to see if anyone noticed that their battery drops 10% on each reboot?
ROM: OSE KitKat 4.4.2
#511 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 24 May 2013 - 06:46 AM
If you have been working in recovery that eats your battery up. Does it happen even if you don't use recovery?
#512 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 24 May 2013 - 06:47 AM
Yes...I have never experienced the issue.
  • Pr0digy likes this
#513 jco23
jco23
  • 414 posts
Posted 24 May 2013 - 07:11 AM
yup.  i don't recall this happening on other ROMs, but this is the first time I used TWRP (so I doubt that has anything to do with the ROM).
I did calibrate my battery via 3rd party app.  but this is not a huge issue, I'll just save my reboots and flashes for when my phone is plugged in.
#514 BwingG
BwingG
  • 140 posts
  • LocationSeattle
Posted 24 May 2013 - 07:12 AM
Anything different on how you install? Is your phone different? Even after reboots? Why dies my phone suck then... Must be me. Lol
#515 jco23
jco23
  • 414 posts
Posted 24 May 2013 - 07:14 AM
hmmm.... certainly not a hardware issue - are you making sure to follow the install instructions exactly?  I know it seems pointless to wipe cache/dalvik before wiping factory reset/system and then rebooting - but doing these "extra" steps that may take a total of 10 seconds could help prevent future problems.
  • timpohladthomas likes this
#516 BwingG
BwingG
  • 140 posts
  • LocationSeattle
Posted 24 May 2013 - 07:18 AM
Rotation back but just from the fresh install
  • timpohladthomas and jco23 like this
#517 BwingG
BwingG
  • 140 posts
  • LocationSeattle
Posted 24 May 2013 - 07:25 AM
Yes wipe everything! Learned that lesson before. Ha. I feel like on my phone anyway that CPU sleeper has nothing to do with it. Seems like the reboot kills rotation on my phone. I tried installing rom and theme together but like said before it doesn't like that. Unfortunately rotation is more important then theme for me. Still a great rom though
#518 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 24 May 2013 - 07:27 AM
If this happens after reboot the problem is probably coming from an init.d tweak. I will look through them again.
  • jco23 likes this
#519 BwingG
BwingG
  • 140 posts
  • LocationSeattle
Posted 24 May 2013 - 07:34 AM
I can test for you if you need. Im free all weekend and willing. I want this ROM with rotate and themed so bad like some of you already have.
#520 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 24 May 2013 - 08:01 AM
Ok. I will do what I can. Been super busy lately and having trouble getting apktool setup on my computer. I will release an update soon...however it may not have toggles as s.dubs and I are working towards a flashable toggle mod. I think the next update is going to polish off the ROM and then just make mods for it.
So that being said...I will most likely work on.
Autorotation fix
Fix proximity while in call
Fix settings to remove launcher settings option
Am I missing something?
  • jco23 likes this
