I can try it out. Can you explain step by step? What I need wipe, what I need leave etc.
Edit: on first boot, auto rotation seemed to work but after I rebooted again, it stopped working.
Posted 22 May 2013 - 05:12 PM
Posted 22 May 2013 - 07:11 PM
Interesting. I wanted to see what the build.prop file read from a stock 4.1.2 ROM, and install one.
I had made a nandroid last night of dead rage. After checking out the stock ROM, I restored my old ROM.... And what do you know, auto rotate is back for me without me making any edits.
So perhaps a remedy is to reflash this ROM without clearing data/system?
Hmm, Idk... . Maybe... Anybody else wanna test it?
Posted 22 May 2013 - 07:22 PM
Posted 22 May 2013 - 08:49 PM
Posted 23 May 2013 - 02:52 AM
could be the cache. I read on another thread somewhere that auto-rotation is due to memory size (heap, perhaps?). so clearing cache/dalvik could help.
I'm pretty sure that if you wiped cache/dalvik and re-install this ROM (without doing a data wipe/factory/system reset), then your phone will be just fine - it would be like replacing the framework. someone correct me if I am wrong.
ROM: OSE KitKat 4.4.2
Posted 23 May 2013 - 04:13 AM
TO DO LIST:
Notification Toggles
Volume Music Controls
Circle Mod Battery Icons
Fix screen staying on during call
GSM Fix?
Motorola Droid Razr M XT907 / ROM: KitStalk by GraberRoms
Posted 23 May 2013 - 05:50 AM
Edit your TO DO listTO DO LIST:
GSM Fix?
It's not necessary to do GSM-fix for this ROM.It works perfect in GSM-network!Thanx for perfect ROM!
Thanks Buddy!
Posted 23 May 2013 - 06:40 AM
Posted 23 May 2013 - 07:07 AM
I actually did this after I disabled CPU sleeper. I wanted to delete it but could not find it in app drawer. I reflashed ROM only wiping cache and dalvik. Auto rotate still did not function. I then found and enabled CPU sleeper and the deleted it. Rebooted and rotation was fine.
Posted 23 May 2013 - 07:11 AM
Wow, well it certainly sounds like that's the culprit. I will remove it in the next update.
Posted 23 May 2013 - 07:37 AM
Couldn't hurt just to eliminate it for testing purposes. You could always put it back in if it turns out that's not it.
Posted 23 May 2013 - 08:07 AM
Posted 23 May 2013 - 08:31 AM
Also, I don't want to be that guy, but could we get a built in flashlight? Not even sure if that's possible on blur, but it would be really handy
Also, just want to say this is one of the most stable roms I've ever used on any device. Despite a few hiccups every once in a while (v6 supercharger seems to solve this), this is incredibly awesome. Thanks!
Love my RAZR M
Get the Power Toggles app and you can add a flashlight toggle in your notification drawer.
Posted 23 May 2013 - 05:18 PM
Posted 23 May 2013 - 06:37 PM
Any word of fixing the screen shaking every once in a while from side to side?
Love my RAZR M
Posted 23 May 2013 - 06:58 PM
Posted 23 May 2013 - 09:33 PM
I deleted all the build.prop mods and now rotation work fine... im thinking adding one by one to see if there is one that messes it up. 24 hours now and no problem
Posted 24 May 2013 - 02:45 AM
curious to see if anyone gets e-mail notifications? I get g-mail and yahoo just fine, but none for the stock e-mail app (linked to my verizon account). when I go into the app, I have to hit the refresh button in order for my new e-mail to appear. I have the settings to check for once for every 30 minutes (changed to once an hour). this was not an issue on other ROMs/stock.
other than that, LOVING the battery life:
Posted 24 May 2013 - 02:52 AM
