RAZR M ROM STOCK
951 replies to this topic
#461 jvasquezhhi
jvasquezhhi
    Frankensteiner
  • 330 posts
Posted 22 May 2013 - 07:18 AM
yeah, you can do that with Holo as well.  I tried Bruno's suggestion, but that did not work for me.
Bruno suggestion worked for me for a while untill i rebooted.. than it stopped again and didnt work after... this is so far a great ROM... but the rotation issue is a big deal breaker... im still keeping it because im also working to see if i can fix it (no much luck yet) and like i said its great rom.. hope we find solution to that bug soon
  • timpohladthomas likes this
#462 lowvolt
lowvolt
  • 478 posts
Posted 22 May 2013 - 07:19 AM
I was having rotate issues until I deleted CPU sleeper. Cleared data in the movement .apk using ROM toolbox and rebooted. Haven't had an issue since.
  • xxBrun0xx and timpohladthomas like this
#463 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
  • Twitter:@timpohladthomas
  • Current Device(s):MOTO X
Posted 22 May 2013 - 07:23 AM
For anyone using nova launcher and having problem with rotate issue, you can temporarily switch to land scape mode via in-launcher force rotate option.
Sorry bud. This autorotation thing is a puzzle.
#464 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 22 May 2013 - 07:24 AM
Hmm, I just don't see why that would affect it.
#465 dreamjaeil
dreamjaeil
  • 107 posts
  • Current Device(s):xt907
Posted 22 May 2013 - 07:47 AM
Wondering the same thing as I still had issue after doing all that.
#466 lowvolt
lowvolt
  • 478 posts
Posted 22 May 2013 - 10:43 AM
If I'm not mistaken Hillsmom reported no issues with rotation and that she deleted CPU sleeper as well.
#467 jco23
jco23
  • 414 posts
Posted 22 May 2013 - 11:26 AM
changing the proximity sensor in the 26_build file from 150 to 800 did not help.  the screen still remains on while on call and next to my face.
thinking that perhaps we could import the 4.1.2 stock 26_build file?  this might correct both the proximity delay and auto-rotation?
ROM: OSE KitKat 4.4.2
#468 xxBrun0xx
xxBrun0xx
  • 41 posts
Posted 22 May 2013 - 11:50 AM
If you stopped CPUSleeper and your problems came back when you rebooted, it's worth asking: do you have "enable at boot" set in cpusleeper? Since disabling that, I've rebooted quite a few times and my issues have never come back. I have no idea what sorcery happens to make cpusleeper work, but this definitely seems to be the source of the issue for at least some of us.
#469 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 22 May 2013 - 12:14 PM
On stock there is no init.d folder in the etc folder.  That is something I added in the building process.
#470 jco23
jco23
  • 414 posts
Posted 22 May 2013 - 12:40 PM
then perhaps it can be added to the build.prop file?
#471 lowvolt
lowvolt
  • 478 posts
Posted 22 May 2013 - 01:13 PM
I tried this approach as well. Didn't work for me either. Deleting CPU sleeper did. I have had no issues since.
  • jco23 likes this
#472 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 22 May 2013 - 01:22 PM
Yeah, just put it on a line at the end. Should be fine.
#473 jamminjon82
jamminjon82
  • 610 posts
  • Twitter:@jamminjon82
  • LocationGloucester, VA
  • Current Device(s):LG G2, Moto X, Kindle Fire 2,Razr M, Nexus 7, Acer A100
Posted 22 May 2013 - 02:18 PM
Tim, did you get your computer setup back to normal?
#474 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 22 May 2013 - 02:32 PM
Almost... Just one last thing... And I have been working on getting setup to compile straight 4.2.2 AOSP from source. :ph34r:
Oh and not normal... Better than normal. :D
  • jamminjon82, clienterror and jco23 like this
#475 xxBrun0xx
xxBrun0xx
  • 41 posts
Posted 22 May 2013 - 02:48 PM
Think you'll get stock-like battery life on 4.2.2? I'd be all over that :D
Love my RAZR M
#476 dreamjaeil
dreamjaeil
  • 107 posts
Posted 22 May 2013 - 03:50 PM
Isn't 4.2.2 very laggy?
#477 clienterror
clienterror
  • 75 posts
Posted 22 May 2013 - 04:11 PM
It's choppy. Lag isn't too bad.
#478 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Yeah, for now it still has a little lag. And no, this will never have stock battery life. Just fun to compile stuff from scratch. :-D
  • clienterror likes this
#479 jco23
jco23
  • 414 posts
Posted 22 May 2013 - 05:00 PM
Interesting. I wanted to see what the build.prop file read from a stock 4.1.2 ROM, and install one.
I had made a nandroid last night of dead rage. After checking out the stock ROM, I restored my old ROM.... And what do you know, auto rotate is back for me without me making any edits.
So perhaps a remedy is to reflash this ROM without clearing data/system?
#480 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 22 May 2013 - 05:06 PM
Hmm, Idk... . Maybe... Anybody else wanna test it?
