RAZR M ROM STOCK
951 replies to this topic
#421 jco23
jco23
  • 414 posts
Posted 21 May 2013 - 09:18 AM
update - found this:
I'm sure this is a simple build.prop tweak or something....
ROM: OSE KitKat 4.4.2
#422 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
  • Twitter:@timpohladthomas
  • Current Device(s):MOTO X
Posted 21 May 2013 - 09:28 AM
i have flashed the PACMan ROM (can't recall testing rotation).
however, I think I see what you mean now.  I tried to view some of my landscape pics/vids, and the screen did NOT rotate.  however, all of my apps that work solely in landscape mode, do convert to landscape.  I'm sure this could be a simple tweak.... googling now....
Thanks bud... I'm looking too... Let me know if you find something.
#423 jco23
jco23
  • 414 posts
Posted 21 May 2013 - 09:42 AM
and found this:
did not see this line in the build.prop file: launcher.force_enable_rotation=true
  • timpohladthomas likes this
#424 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 21 May 2013 - 09:59 AM
Anyone having the rotation issue.  Please try this...
You will need to navigate to /system/etc/init.d and drop the file in that folder.  You will need to overwrite the originial one and make sure the permissions are the same.  Then reboot.
To clarify, I had made an option in this tweak to allow 270 degree rotation.  I have removed that part to see if that is what was causing the issue.  For those that test, please respond so I know if I am going in the right direction.  Thanks.
Tim
#425 jco23
jco23
  • 414 posts
Posted 21 May 2013 - 10:11 AM
Tim
i don't see a "26_build.bin" file in that folder - I presume this is to replace the "26_build" file?  can we just edit that line in that file instead?  like delete it all together or adjust the number?
#426 Noigel
Noigel
  • 197 posts
  • LocationUkraine, Ivano-Frankivs`k
  • Current Device(s):Motorola Razr M XT907 / Motorola Razr I XT890
Posted 21 May 2013 - 10:15 AM
What network are you on?
Try this
If I am not allowed to post this link please let me know and I will remove it.
This framework isn`t works for me.. (
I`m on Kyivstar (Ukraine) GMS 2G network.
I`ll try to do "no_ciphering" patch myself..
Thanx for link!
I using path for "no soft buttons"
Motorola Droid Razr M XT907 / ROM: KitStalk by GraberRoms
post-103018-0-11429500-1388984908_thumb.
#427 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 21 May 2013 - 10:17 AM
Try this
Thanx for link!
Yeah, I figure that wouldn't work just flashing but figured you could get some insight there. Good luck.
#428 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 21 May 2013 - 10:18 AM
Tim
Hmm, in the init.d folder? Can you take a screen shot for me?
#429 jco23
jco23
  • 414 posts
Posted 21 May 2013 - 10:23 AM
j/k
#430 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 21 May 2013 - 10:30 AM
j/k
Ha! So my question was answered.  There is a 26_build file there...The file I uploaded was supposed to overwrite the one that was in there...did it? I assume the 26_build.bak is a backup you made just in case?
#431 jco23
jco23
  • 414 posts
Posted 21 May 2013 - 10:34 AM
well, there is a "26_build" file - I guess that copying the "26_build.bin" file will overwrite that?  the .bak file was generated automatically when I edited the file earlier today for the sensor proximity issue.
personally, I'd rather edit a line within that file rather than simply replace it.
#432 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 21 May 2013 - 10:43 AM
Ok, up to you.  I also edited the proximity sensor info for those hanging up on people.
The line is setprop windowsmgr.support_rotation_270=true;
You can just delete it or change it to false.
#433 jco23
jco23
  • 414 posts
Posted 21 May 2013 - 10:52 AM
changing it to false did not work.  :(
#434 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 21 May 2013 - 10:58 AM
What did it do?
#435 jco23
jco23
  • 414 posts
Posted 21 May 2013 - 11:02 AM
What did it do?
nothing that I have noticed thus far.  I also tried placing a "#" in front of that line as well (rebooted both times).
#436 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 21 May 2013 - 11:31 AM
And you still have issues with auto rotation?  Have you tried deleting it all together?
#437 Noigel
Noigel
  • 197 posts
Posted 21 May 2013 - 12:10 PM
Thanx for link!
I did this!
If anybody want this you can give it here (I can`t attach .apk in Droidrzr... )
#438 jco23
jco23
  • 414 posts
Posted 21 May 2013 - 12:14 PM
no, but I might try an app:
  • timpohladthomas and clienterror like this
#439 uscgmatthew
uscgmatthew
  • 7 posts
Posted 21 May 2013 - 03:04 PM
Wow This is absolutely amazing. Fantastic job on this Rom. I will surely be don9'ing :D
Quick question: what is the removal of the no soft keys mod.. I mean.. what is the purpose O_o. Is there a replacement app people are using in place of them? Thanks!
#440 jco23
jco23
  • 414 posts
Posted 21 May 2013 - 03:21 PM
removing the soft keys expands your screen all the way down.  however, you will need a pie launcher like LMT to access those controls.
  • zooyork0721 and timpohladthomas like this
