#401
Posted 19 May 2013 - 05:15 AM
Love my RAZR M
- timpohladthomas and mrnathanman like this
#402
Posted 20 May 2013 - 03:07 AM
so curious to see if anyone is using bytecode's custom kernel on this ROM, and if there are any advantages to doing so?
- timpohladthomas likes this
ROM: OSE KitKat 4.4.2
#403
Posted 20 May 2013 - 03:22 AM
third time's a charm for me - I didn't really do anything differently this time. after 13+ hours, phone is at 80%.
Glad it worked out for you. As far as byte codes kernel. I haven't heard of any reports of anyone using it. Doesn't mean it won't work. Just haven't heard about it yet. May test later today and let you guys know.
- jco23 likes this
#404
Posted 20 May 2013 - 03:32 AM
#405
Posted 20 May 2013 - 03:38 AM
That kernel is for aosp roms
Oh I know.... Don't worry. But if we didn't almost break our phones everyday how would we know what we could do. :-D
- hillmom likes this
#406
Posted 20 May 2013 - 03:55 AM
#408
Posted 20 May 2013 - 06:06 AM
Alrighty guys, just a heads up...I flashed Bytecodes kernel with this ROM and as expected....they do not play nicely with eachother. So, if you would like a working ROM, do not flash that kernel with this ROM. On another note, I have been having issues with my computer this weekend and am almost back to square one. I have all my stuff downloaded just need to get it up and running again. Thanks for sticking in there.
Tim
- neckchop and jco23 like this
#409
Posted 20 May 2013 - 06:12 AM
Derp, didn't read the already had discussionAlrighty guys, just a heads up...I flashed Bytecodes kernel with this ROM and as expected....they do not play nicely with eachother. So, if you would like a working ROM, do not flash that kernel with this ROM. On another note, I have been having issues with my computer this weekend and am almost back to square one. I have all my stuff downloaded just need to get it up and running again. Thanks for sticking in there.
Tim
#410
Posted 20 May 2013 - 08:15 PM
Think I've got the sensor issue figured out. I just had no sensor response, so I rebooted. I have cpusleeper turned off. It seems after its been enabled for a while, the sensors stop working. Don't think you have to clear data on motion sensors, though. Just don't use cpusleeper and you'll be good
Love my RAZR M
I tried freezing cpu sleeper today with TB and rebooted but still had sensor issue. Not sure what went wrong with mine. Hopefully this issue and rotation issue gets sorted out on next release when Tim gets his set up.
#411
Posted 21 May 2013 - 04:14 AM
did you read post #221 regarding the sensor?
#412
Posted 21 May 2013 - 04:34 AM
Is it possible to remove message about "ciphering is not available in your network" from status bar?
Motorola Droid Razr M XT907 / ROM: KitStalk by GraberRoms
#413
Posted 21 May 2013 - 08:24 AM
not really sure how you can improve on battery performance here:
#414
Posted 21 May 2013 - 08:30 AM
What network are you on?
Try this
If I am not allowed to post this link please let me know and I will remove it.
#415
Posted 21 May 2013 - 08:39 AM
No I did not. I'm currently back on stock since I use rotation a lot. Screen brightness something I could change but not rotation. Was rotation fix mentioned as well? If so, I will try both out.
#416
Posted 21 May 2013 - 08:46 AM
regarding rotation, I never had an issue with that. but then again, I rarely use landscape mode except for some web browsing and some apps. have you tried a different launcher (or adjusting the launcher settings) - not sure if that would help or not.
perhaps if you can give specific examples where you expect the screen to rotate and doesn't, I can see what I get (FWIW, I still use Holo launcher).
#417
Posted 21 May 2013 - 08:48 AM
I am in the same boat with the rotation. I haven't noticed it but also never use it or rarely use it. Reading other forums I have noticed it is happening to people on cm 10.1 as well.
@dream, have you flashed 10.1 at all?
@everyone with the issue... Did you flash 10.1 at all?
#418
Posted 21 May 2013 - 08:54 AM
I'm currently using Nova launcher and I tried mix of settings but still had issue. Rotation just doesn't work at any given time when it is expected to work.
I don't think so, well not since I used matt's utility to get to 4.1.2 stock
#419
Posted 21 May 2013 - 09:04 AM
Hmm, I just don't know what could be causing it... Do you have this issue on other ROMs?
#420
Posted 21 May 2013 - 09:07 AM
i have flashed the PACMan ROM (can't recall testing rotation).
however, I think I see what you mean now. I tried to view some of my landscape pics/vids, and the screen did NOT rotate. however, all of my apps that work solely in landscape mode, do convert to landscape. I'm sure this could be a simple tweak.... googling now....
