RAZR M ROM STOCK
951 replies to this topic
#21 tag619
tag619
  • 9 posts
Posted 06 May 2013 - 12:15 PM
Not really a genius at flashing ROMS, so I may be doing something wrong...
#22 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
  • Twitter:@timpohladthomas
  • Current Device(s):MOTO X
Posted 06 May 2013 - 12:16 PM
Guess I'll be the ginny pig and find out tonight after I get off work
I have looked and yes, the 4.1.2 boot.img is included.  So no worries.
#23 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 06 May 2013 - 12:18 PM
You should not have to mount anything when installing through safestrap.  Just skip the mounting steps.
#24 tag619
tag619
  • 9 posts
Posted 06 May 2013 - 12:37 PM
I am not doing it on the stock ROM slot.
I installed it on ROM slot 1.
So how do I "skip" the mount steps?
#25 clienterror
clienterror
  • 75 posts
Posted 06 May 2013 - 12:38 PM
Are the original rage themes compatible? Only asking because the links are dead for the themes in the OP.
#26 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 06 May 2013 - 12:43 PM
Yes they are! and I will fix the links, thanks for the heads up.
  • clienterror likes this
#27 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Just wipe everything twice and flash
#28 tag619
tag619
  • 9 posts
Posted 06 May 2013 - 12:45 PM
On Stock or ROM Slot 1?
Don't really want to use stock...
#29 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 06 May 2013 - 12:46 PM
ROM Slot 1
#30 clienterror
clienterror
  • 75 posts
Posted 06 May 2013 - 12:51 PM
Thanks :-D
#31 tag619
tag619
  • 9 posts
ROM Slot 1
OK, so wipe twice then install?
#32 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 06 May 2013 - 12:52 PM
Yes sir.
#33 tag619
tag619
  • 9 posts
Posted 06 May 2013 - 12:59 PM
Yes sir.
Thank you.
#34 AK47sForAll
AK47sForAll
  • 50 posts
Posted 06 May 2013 - 02:49 PM
APK link just redirects here. Will give this a try.
#35 JWACK72
JWACK72
  • 103 posts
  • LocationSC
  • Current Device(s):RAZR M
Posted 06 May 2013 - 02:56 PM
Mine keeps failing as well with safestrap. Do u need to accept the OTA update first?
#36 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 06 May 2013 - 03:18 PM
I don't think so. I may have to make a different one that works with safestrap. Did you mount? If so, try without...
#37 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 06 May 2013 - 03:22 PM
Will fix the OP when I get home. Thanks for the heads up.
#38 looneybin
looneybin
  • 23 posts
  • Current Device(s):Rarz M Nook Color
Posted 06 May 2013 - 03:50 PM
Very snappy running without any problems GREAT job
  • timpohladthomas likes this
#39 AK47sForAll
AK47sForAll
  • 50 posts
Posted 06 May 2013 - 04:51 PM
Ok, not sure what happened with mine. I installed, then rebooted after putting the debloated apks and left the room. I came back to a black screen and the phone was HOT and I mean HOT and that's what I felt through my Otterbox. It wouldn't turn on/off until I held in all the buttons to put it into fastboot mode. I'm flashing stock again now, and no idea what happened. It's still really really hot.
#40 Powersonon
Powersonon
  • 5 posts
Posted 06 May 2013 - 05:31 PM
Hey man was wondering when going from 1.0 to 1.1, if i have to re-wipe everything or can i just wipe cache and flash 1.1, in the midst of it now, may try it before you get back to me if so i will let you know how it goes, also would i have to redo the debloated apps.  Btw was running 1.0 for a little while today and let me just say, extremely smooth, nicely done.  I also really like the metallic blue.  i would like to send you a little donation but not sure where to click or send it, so let me know.
And thanks for devoting your time to our needs.
