RAZR M ROM STOCK
951 replies to this topic
#301 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 12 May 2013 - 03:09 PM
I used matt's utility to update to 4.1.2 and I just flashed DeadRage. Seems to be working in order after reboot. I will report again later.
Edit: spoke too soon. I was causally watching a YouTube video and it froze so I force rebooted. Then, proximity sensor no longer works and rotation doesn't work as well. These are some screenshots of the auto-rotate options and about phone page.
Well, that rules out baseband...
edit:  not everyone needs to know about that. ;)  Too many bad things can happen in that menu.
#302 xxBrun0xx
xxBrun0xx
  • 41 posts
Posted 12 May 2013 - 05:38 PM
This battery life is obscene. Can't wait to get optimized kernels so we can see what she can really do :D
Love my RAZR M
  • hillmom and timpohladthomas like this
#303 hillmom
hillmom
  • 131 posts
  • Twitter:whillmom
  • LocationIdaho
Posted 13 May 2013 - 06:16 AM
So I reflash it to find of what worked from my post here:
Prior to wiping data on Movement Detection my phone was finding none of the sensors. After wiping its data (and a reboot) all sensors were found and working.
  • timpohladthomas likes this
#304 mainbord
mainbord
  • LocationMoscow
  • Current Device(s):Motorola defy
Posted 13 May 2013 - 08:13 AM
Write in the first post please. DeadRage works well with GSM without any changes.
  • timpohladthomas and RikRong like this
#305 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
  • Twitter:@timpohladthomas
  • Current Device(s):MOTO X
Posted 13 May 2013 - 08:27 AM
Thanks man. I will this evening. In training right now.
#306 Pr0digy
Pr0digy
  • 57 posts
  • LocationLawrence Kansas
  • Current Device(s):Razr M (retail) Samsung Vitality (Sitting unused) iPad 2
Posted 13 May 2013 - 12:15 PM
Auto rotate error is back what info you need?
Gonna run LogCat from adb once I get home.
#307 Pr0digy
Pr0digy
  • 57 posts
Posted 13 May 2013 - 12:25 PM
# Device #
random useless data
# Screen #
Screen width: 540
Screen height: 888
Screen density: hdpi
Physical width pixels per inch: 254.0
Physical height pixels per inch: 256.67368
Calculated screen size: 4.1
Screen size: normal
Screen orientation: Portrait
Screen rotation: 0°
# Camera #
# Camera 1 #
AINT NO TIME FO DAT
# Camera 2 #
AINT NO TIME FO DAT
# Sensors #
ZILCH NADA NOTHING HERE
Is there a system Apk for the Sensors? They have just disappeared like a fc...
Edited by Pr0digy, 13 May 2013 - 02:28 PM.
#308 Pr0digy
Pr0digy
  • 57 posts
Edit: Duplicate Double Post
Ain't nobody got time for dat!
#309 arc1880
arc1880
  • 74 posts
  • Current Device(s):RAZR M
Posted 13 May 2013 - 12:50 PM
Pr0digy, just curious if auto-rotate stopped working after you rebooted your phone. Also, I believe LogCat has been turned off so you will need to enable it.
#310 Pr0digy
Pr0digy
  • 57 posts
Posted 13 May 2013 - 01:20 PM
It came back after I rebooted but it was as I was using it that I first noticed it...... :lightbulb: Each time while watching youtube videos. Also the prox sensor during a call goes out. yeah I do need to turn log cat back on as its off.
I am wondering on a few Samsung devices I have seen where the camera crashes till you reboot because an app gains priority over the camera system apps... Wondering if this is a simmular issue.
#311 hillmom
hillmom
  • 131 posts
  • Twitter:whillmom
  • LocationIdaho
Posted 13 May 2013 - 01:47 PM
That is the app I deleted data in, but I was using App Manager in ROM Toolbox.
  • Pr0digy likes this
#312 Pr0digy
Pr0digy
  • 57 posts
Posted 13 May 2013 - 02:23 PM
Yeah sorry put that ss in and didnt complete my thoughts. is it the app for the sensors or orentation notifier?
Edited by Pr0digy, 13 May 2013 - 02:33 PM.
#313 hillmom
hillmom
  • 131 posts
  • Twitter:whillmom
  • LocationIdaho
Posted 13 May 2013 - 02:32 PM
I believe it is for the sensor. All I really know it that my phone wasn't finding any sensors (proximity, rotation, no turn by turn navigation, etc) before wiping data on that. However, it all worked after with and a reboot.
#314 Pr0digy
Pr0digy
  • 57 posts
Posted 13 May 2013 - 02:33 PM
TIM did you do any modifications to android.hardware with the following classes?
android.hardware.SensorManager
android.hardware.SensorEvent
android.hardware.SensorEventListener
#315 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 13 May 2013 - 03:33 PM
Not that I was aware of. :-)
#316 xxBrun0xx
xxBrun0xx
  • 41 posts
Posted 13 May 2013 - 06:43 PM
Works for me too! Cleared data for "Motion Detection" using titanium backup, rebooted, and all sensors work (auto rotate, proximity). Thanks! :D
Edit: After another reboot, my sensors no longer work. Tried wiping data on that app again and still no luck. Ug
#317 lowvolt
lowvolt
  • 478 posts
Posted 13 May 2013 - 07:38 PM
That was the issue I had as well. Wiped data then rebooted. And sensors worked. Rebooted again and they didn't work. Wiped movement detection data and cache and fixed permissions. Rebooted. Sensors worked. Backed up ROM and sensors still work.
Edit: after flashing a boot logo. Sensors no longer work. I think I will re delete data and reboot and see if that fixes again. Then I will never reboot again. Lol
#318 hillmom
hillmom
  • 131 posts
  • Twitter:whillmom
  • LocationIdaho
Posted 13 May 2013 - 07:48 PM
That is strange. I don't loose sensors on reboot... Wonder what is different from here to there...
#319 lowvolt
lowvolt
  • 478 posts
Posted 13 May 2013 - 08:00 PM
Now not even clearing data will make them work.
#320 lowvolt
lowvolt
  • 478 posts
Posted 13 May 2013 - 08:21 PM
Okay. So I extracted the motion .apk from the zip and copied it into the system app folder changed permission to rw rr and rebooted. Sensors are working again.
