RAZR M ROM STOCK
951 replies to this topic
#281 jco23
jco23
  • 414 posts
Posted 11 May 2013 - 07:58 PM
just wanted to report that I tried this out today.  very nice - quick and smooth.  my lone concern was that I had wifi problems right off the bat (ESPN streak for the CASH app).  i don't think that it was an issue with your ROM though, as I tend to experience wifi issues previously (although mostly with FB or apps using FB).  also, I had troubles restoring my system data via TiBu - so I'll have to go back and figure that out.
however, I did not experience any force closes when accessing launcher settings via Holo Launcher.
after I can get a better backup file created for my settings, then I'll try this again.
  • timpohladthomas likes this
ROM: OSE KitKat 4.4.2
#282 dankgreens
dankgreens
  • LocationArizona
  • Current Device(s):RAZR M
Posted 12 May 2013 - 04:49 AM
I downloaded and flashed your ROM 2 days ago via safestrap. I got failed response each time I tried. Reading further into the thread I saw that someone else was having this issue. They rebooted and the ROM loaded. As did mine.
I've played with it a bit since then and have found a few issues.
1. In the settings menu, when you choose "Launcher" settings force close
2. Text messaging force closes upon opening
3. Phone force closes upon dialing.
4. Flashing no button mod cancels parts of theme out and flashing theme cancels out no button mod.
Other than these issues every other feature seems to be up and working. Hadn't have the time to test every thing yet. I was going to unlock bootloader today and flash that way. I like the ROM and the themes. Keep up the good work.
#283 lowvolt
lowvolt
  • 478 posts
Posted 12 May 2013 - 07:08 AM
You may have a bad flash. I know the launcher settings doesn't work as of know, but have not heard of or had any issue with phone or messaging. I haven't flashed the no button mod so couldn't tell you there. I thought I saw something in an earlier post about that and possibly a fix.
#284 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
  • Twitter:@timpohladthomas
  • Current Device(s):MOTO X
Posted 12 May 2013 - 07:22 AM
I will address these in order.
1. As was said already the force close in settings is a known issue and will be fixed or removed in the next update.
2.and 3. I have not heard of these issues. However this ROM was built more to be flashed on a unlocked bootloader with custom recovery. Some of these issues may be because of that.
4. Most themes have there own no soft key mod. Otherwise you are right. It will cancel the systemui part of the theme.
Hope I have been helpful.
#285 dreamjaeil
dreamjaeil
  • 107 posts
  • Current Device(s):xt907
Posted 12 May 2013 - 07:44 AM
Just adding onto the no rotating issue; When flashed 1.2a not rotating issue occurred initially. However, after rebooting the phone, the issue became permanent and won't fix itself even after rebooting again.
#286 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 12 May 2013 - 08:21 AM
Sorry that you are having these issues. Did you flash with Safestrap or another custom recovery?
#287 dreamjaeil
dreamjaeil
  • 107 posts
Posted 12 May 2013 - 08:28 AM
TWRP
#288 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 12 May 2013 - 08:50 AM
TWRP
OK, shouldn't be any issues. Will look deeper into it next week and see what I can come up with.
  • hillmom likes this
#289 Pr0digy
Pr0digy
  • 57 posts
  • LocationLawrence Kansas
  • Current Device(s):Razr M (retail) Samsung Vitality (Sitting unused) iPad 2
Posted 12 May 2013 - 10:02 AM
I began to have the rotation issue last night. I went into bulid.prop and changed some settings and its now resolved the problem is I did it at 3AM so I forget what I did I am gonna load the bulid.prop from my phone in a text editor and from the rom zip and compare I will post the differences soon but kinda occupied so it may be an hour or two.
  • hillmom and timpohladthomas like this
#290 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 12 May 2013 - 10:31 AM
Sounds good man. Thanks
  • Pr0digy likes this
#291 Pr0digy
Pr0digy
  • 57 posts
Posted 12 May 2013 - 11:45 AM
Here is the differences I see... I know some of them are just my personal tastes
ro.qc.sdk.camera.facialproc=true MY MOD
ro.qc.sdk.camera.facialproc=false DEADRAGE ZIP
With the Compass issues I am wondering????
persist.mot.gps.assisted=true MY MOD
persist.mot.gps.assisted=false DEADRAGE ZIP
ro.mot.ds.fastdormancy.disable=true MY MOD
ro.mot.ds.fastdormancy.disable=false DEADRAGE ZIP
dalvik.vm.heapsize=256m MY MOD
dalvik.vm.heapsize=128m DEADRAGE ZIP
persist.sys.use_dithering=1 MY MOD
persist.sys.use_dithering=0 DEADRAGE ZIP
ro.telephony.call_ring.delay=200 MY MOD
ro.telephony.call_ring.delay=1000 DEADRAGE ZIP
MAX_HIDDEN_APPS=true MY MOD
MAX_HIDDEN_APPS=false DEADRAGE ZIP
MAX_ACTIVITIES=true MY MOD
MAX_ACTIVITIES=false DEADRAGE ZIP
ACTIVITY_INACTIVITY_RESET_TIME=true MY MOD
ACTIVITY_INACTIVITY_RESET_TIME=false DEADRAGE ZIP
MAX_RECENT_TASKS=true MY MOD
MAX_RECENT_TASKS=false DEADRAGE ZIP
MAX_PROCESSES=true MY MOD
MAX_PROCESSES=false    DEADRAGE ZIP
CPU_MIN_CHECK_DURATION=true MY MOD
CPU_MIN_CHECK_DURATION=false DEADRAGE ZIP
Probally should add also that I have not installed the softkey mod, any themes or installed any of the debloated APKs
Notepad++ is nice to have for this :D
Edited by Pr0digy, 12 May 2013 - 11:52 AM.
#292 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 12 May 2013 - 12:10 PM
Thank you for this post. I will check it out.
#293 dankgreens
dankgreens
  • LocationArizona
Posted 12 May 2013 - 12:15 PM
I figured that it was because I'm flashing in safestrap. Just looking for a confirmation. I just recovered from a minor brick screwing around with safestrap so I hasn't had chance to try to re flash. I will probably unlock my bootloader in a while and try that way.
Thanks again
#294 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 12 May 2013 - 12:53 PM
Will someone that is having auto-rotate/GPS/WiFi/prox sensor issues please post a screen shot from their "About Phone" screen, showing Android/Baseband/Kernel version?  I'm just doing some trouble guessing here...
  • neckchop and Pr0digy like this
#295 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 12 May 2013 - 12:56 PM
Ha, you beat me to it. And as a follow up question, the ones with problems...did you come from 4.1.1 straight to this ROM?
#296 Pr0digy
Pr0digy
  • 57 posts
Posted 12 May 2013 - 01:15 PM
Accessibility menu... Is auto rotate checked there also for the ones with probs
#297 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 12 May 2013 - 01:29 PM
Good call.
#298 dreamjaeil
dreamjaeil
  • 107 posts
Posted 12 May 2013 - 02:04 PM
I used matt's utility to update to 4.1.2 and I just flashed DeadRage. Seems to be working in order after reboot. I will report again later.
  • cdavid469, timpohladthomas and RikRong like this
#299 dreamjaeil
dreamjaeil
  • 107 posts
Posted 12 May 2013 - 02:26 PM
Edit: spoke too soon. I was causally watching a YouTube video and it froze so I force rebooted. Then, proximity sensor no longer works and rotation doesn't work as well. These are some screenshots of the auto-rotate options and about phone page.
#300 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 12 May 2013 - 03:02 PM
I will be looking into this this week. Hopefully find a fix soon.
