#261
Posted 11 May 2013 - 08:48 AM
Sent from my XT907 using Xparent Blue Tapatalk 2
#262
Posted 11 May 2013 - 08:57 AM
No dice on the wiping. I had it working then had to reboot and it stopped. Very strange. Any other thoughts? Thanks in advance.
Does your compass and turn by turn navigation still work? When I was having that problem (not sure what fixed it), none of that worked.
#263
Posted 11 May 2013 - 09:23 AM
I am headed to a wedding but can help later. Sorry for the trouble.
#264
Posted 11 May 2013 - 10:12 AM
Love my RAZR M
#265
Posted 11 May 2013 - 10:53 AM
No problem sir thank you. No my compass and nav not working which is odd. It worked fine yesterday then I had to reboot and no go. I hope it is something easy I really don't want to reflash but if no other choice I will. Thanks again
#266
Posted 11 May 2013 - 11:06 AM
My phone is getting making my hands sweat when I use it on hspa+. Rage never did this. Ideas?
Love my RAZR M
Just after you flash or also at least a couple of hours afterwards? Android does a lot in the background for quite some time after a new flash.
#267
Posted 11 May 2013 - 11:17 AM
Weird my location services at the bottom shows a "@string/location_access_tittle" with the on off switch. and it took like 3 times in google maps reopening to get it to work.
#268
Posted 11 May 2013 - 02:16 PM
First let me say this Rom is awesome!!! I am however still having the auto rotate issue, I tried the tip and I have both set to auto but can't get it to rotate. I tried resetting and still nothing. Any help would be appreciated, thanks.
I was having the auto-rotate issue as well. I decided to flash my phone again. After doing the initial setup of the phone, the auto-rotate was functioning correctly. I updated Apex launcher to 2.0 and it was still working. I then changed other preferences and it stopped working. I tried to re-launch Apex launcher and it would not work. I then went ahead and did a reboot. It started working after that. Both auto-rotate options are checked in the normal phone settings under display as well as Apex launcher. Since late last night, my auto-rotate has been running fine.
#269
Posted 11 May 2013 - 02:23 PM
When I did the initial setup after flashing this ROM. I went ahead went to settings and turned it on manually. Google maps seems to be working for me. I haven't tried any nav.
#270
Posted 11 May 2013 - 03:16 PM
Have you reset since you fixed the rotation?
#271 Guest_BDH_*
Posted 11 May 2013 - 03:17 PM
I've made a possible fix for the rotation issue if anyone would like to try it?
- timpohladthomas likes this
#272 Guest_BDH_*
Posted 11 May 2013 - 03:24 PM
Possible rotation fix
Should allow all rotations:
- hillmom, timpohladthomas and matthius7 like this
#273
Posted 11 May 2013 - 03:54 PM
My phone was getting hot when using it for long stretches on hspa+, but I think that's pretty standard. It wasn't fry an egg hot, just hotter than on wifi.
On an unrelated note, anyone working on a custom kernel? Is it possible without source?
Love my RAZR M
#274
Posted 11 May 2013 - 04:11 PM
This gets rid of the "no sw buttons" mod. If you reflash the SW buttons mod, your ability to auto rotate breaks. Looks like they're mutually exclusive for now.
*Edit: just to be clear, I didn't actually test this without the "no sw button" mod. I saw I had buttons and immediately rebooted and reflashed the button mod. Sorry!
#275 Guest_BDH_*
Posted 11 May 2013 - 04:25 PM
I can edit zooyorks no softkey modxas well as long as he doesn't care.
#276
Posted 11 May 2013 - 04:55 PM
Just tried but not rotating.
#277
Posted 11 May 2013 - 05:38 PM
If by reset you mean by rebooting my phone; I have not.
UPDATE: I just rebooted my phone, and now auto-rotate does not work.
#278
Posted 11 May 2013 - 05:49 PM
UPDATE: I just rebooted my phone, and now auto-rotate does not work. Oh and the fix did not work either sorry.
Sorry, didn't want you to break rotation but at least we know now there is something up.
#279
Posted 11 May 2013 - 05:53 PM
I tried as well. Still not working. Both in settings and Apex behavior settings are set to auto-rotate.
#280
Posted 11 May 2013 - 06:10 PM
It was in semi-working condition before flashing the zip but now it's not working at all. Hopefully BDH comes up with another zip soon.
