But Tim I think you will really like this one your ROM is making the M get better benchmarks than the S3 or RAZR i
Sent from your Mom's XT907 using Tapatalk 2
Nice, thanks for sharing. What benchmark app is that?
Posted 10 May 2013 - 08:30 AM
Posted 10 May 2013 - 08:31 AM
There actually is my freeze list
I flat out just deleted the smartactions
Posted 10 May 2013 - 10:05 AM
yup it runs fine I honestly have no clue what the moto handwritring, english exc does never used them or know exactly how to access them. The fast dormancy and amazingly smart actions i have read in many fourms can be battery hogs. The launcher is just a personal prefrence and I have no clue what the dev feels on using it in Roms but Simple Launcher is very smooth has a low ram footprint and has all I need. I will get back with you on the name of the benchmark app I am sitting on the phone with my cable company. : "Bob" seems like nice guy I think I rode in his Taxi once but am not sure :
Posted 10 May 2013 - 10:20 AM
I tried yesterday to install and every time it boots with no service. Anyone else have this issue. I've been wiping properly.
EDIT: Started Help thread for possibly a similar issue.
Posted 10 May 2013 - 10:32 AM
On the benchmark I used which is made by Qualcomm which is in the
Posted 10 May 2013 - 04:00 PM
i actually figured it out. it was a bad download. i had downloaded with phone then transfered to sd. this time i downloaded with pc then moved with pc and cable. worked like a charm
Posted 10 May 2013 - 04:27 PM
i noticed that the file size between the one posted at 2:10pm yesterday and the one post at 3:23pm yesterday dropped by 100+ MB.... all of that cannot be attributed to the boot animation, is it?
ROM: OSE KitKat 4.4.2
Posted 10 May 2013 - 04:29 PM
Posted 10 May 2013 - 06:49 PM
Yep, it was definitely in 2 places. With that being said, is it safe to delete the one out of data/local, since there's one in System/UI? I wanted to ask, before deleting anything out of data. I didn't flash the 1.2a update, so I still have 2 boot ani's.
As for benchmark, I usually take them with a grain of salt because they're so inconsistent. However, I've run Antutu and Quadrant and both gave me the highest scores that I've seen on this phone. It's also the same result with the benchmark tool in ROM Toolbox.
Posted 11 May 2013 - 02:22 AM
Posted 11 May 2013 - 06:32 AM
Posted 11 May 2013 - 06:38 AM
That is perfectly fine to delete it out of data/local. That is awesome to hear.
Thanks. I went ahead and deleted it, after looking through the files in my tablet last night, and seeing there wasn't one in the data file. I appreciate your quick responses and overall support that you've given everyone. The entire Rage team is outstanding and supportive and a little more patient than some of the other developers/teams out there.
Gave this ROM a shot. And I'm amazed.
That's what I was looking for. Fast and smooth ROM with moto stock camera.
Couldn't get it to work on CM10.
Here's what I got. Cm10/moto looking home screen. Much smoother then stock
Thanks! Glad you are enjoying it!
Posted 11 May 2013 - 06:41 AM
No problem man. Like I said in another thread here. That's why we are all here...to help eachother out. Sometimes we all forget that. Glad everything is running good for you guys. Been really busy lately but plan on hitting the grindstone towards an update next week. Let me know if you find anything else that's needs some work or should be added to the To Do list in the OP. Have a good weekend guys!
Posted 11 May 2013 - 06:49 AM
I was talking through PMs last night with someone and they said they were still having the auto rotate issue. I asked if they had enabled auto rotate in System settings AND the Apex settings, under Behavior. They never got back to me, but I know in the past I've forgotten to check the box in Apex and the it wouldn't auto rotate. That wasn't the problem on 1.1, I triple checked to make sure I was checked in both places. However, a couple of people have talked about still having problems with rotation. People might want to make sure they're checked off in both settings menus.
Posted 11 May 2013 - 06:54 AM
Posted 11 May 2013 - 08:03 AM
Posted 11 May 2013 - 08:26 AM
First let me say this Rom is awesome!!! I am however still having the auto rotate issue, I tried the tip and I have both set to auto but can't get it to rotate. I tried resetting and still nothing. Any help would be appreciated, thanks.
Sent from my XT907 using Xparent Blue Tapatalk 2
