RAZR M ROM STOCK
951 replies to this topic
#201 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
  • Twitter:@timpohladthomas
  • Current Device(s):MOTO X
Posted 09 May 2013 - 12:49 PM
If this built has the boot.img in it it should flash over the cm10.1 image and you should be fine
Should being the key word. :-)
#202 brandon71
brandon71
  • 553 posts
  • Google+:tbd7171@gmail.com
  • LocationKodak, TN
Posted 09 May 2013 - 01:02 PM
I live by shoulds and maybes lol
  • timpohladthomas likes this
#203 th3drow
th3drow
  • 12 posts
Posted 09 May 2013 - 01:11 PM
just FYI been using it all day after flashing through Safestrap and it seems to have gone fine, tested bluetooth, gaming, navigation, phonecalls, texting , sms. Everything seems to be solid, so despite that error it seems to work perfect.
#204 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 09 May 2013 - 01:27 PM
Thanks for getting back to me man, I will update the op tonight.
#205 dreamjaeil
dreamjaeil
  • 107 posts
  • Current Device(s):xt907
Posted 09 May 2013 - 01:44 PM
I somehow managed to trigger display rotating problem again :(
#206 aiur1
aiur1
  • 54 posts
  • LocationCalifornia
  • Current Device(s):Note 3 (SM-N900V)
Posted 09 May 2013 - 02:01 PM
Do you have to use Apex with this ROM? I was hoping that this would have been themed without the aid of Apex. I removed Apex, and it broke the rom and I had to unsoftbrick my phone lol.
#207 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 09 May 2013 - 02:03 PM
You must install some other launcher before uninstalling....Then you will be fine.
  • neckchop likes this
#208 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 09 May 2013 - 02:04 PM
Sorry man. What were you doing?
#209 clienterror
clienterror
  • 75 posts
You can use any launcher you want, theme is done at the framework level for this rom.
#210 aiur1
aiur1
  • 54 posts
Posted 09 May 2013 - 02:05 PM
Where do you get the stock homescreen app?
#211 dreamjaeil
dreamjaeil
  • 107 posts
Posted 09 May 2013 - 02:08 PM
Only setting I was changing was display power saver because it seemed like screen was way too bright for indoor. Is proximity sensor known issue?
#212 aiur1
aiur1
  • 54 posts
Posted 09 May 2013 - 02:09 PM
Actually, I just used TT to backup my homescreen from the rom I'm on and I will just install it into deadrage (I think that will work anyways, and if it doesnt, idc, I have backups. Unlocked bootloader = can't brick phone)
#213 aiur1
aiur1
  • 54 posts
Posted 09 May 2013 - 02:31 PM
And I was wondering what does the no soft key mod do? Is it unnecessary?
#214 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 09 May 2013 - 02:32 PM
Hang on and I will send you a link... you will have to drop it in the /system folder and reboot.
Here you go...
You will need both apk files.  PM me if you need help.
#215 hillmom
hillmom
  • 131 posts
  • Twitter:whillmom
  • LocationIdaho
Posted 09 May 2013 - 02:49 PM
It removes the navigation bar on the bottom. You then need a replacement (like LMT Launcher, Button Saver, etc). I love it that way. The little extra screen room is nice!
#216 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 09 May 2013 - 03:21 PM
Yes that is a known issue.  It will be changed in the next update.
  • hillmom likes this
#217 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 09 May 2013 - 03:22 PM
What she said...ha
#218 Pr0digy
Pr0digy
  • 57 posts
  • LocationLawrence Kansas
  • Current Device(s):Razr M (retail) Samsung Vitality (Sitting unused) iPad 2
Posted 09 May 2013 - 03:58 PM
"You must install some other launcher before uninstalling....Then you will be fine."
Ummm isn't this with any rom
Sent from Your moms XT907 using Tapatalk 2
#219 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 09 May 2013 - 04:11 PM
Some ROMs come with two launchers but in my case, to avoid bloat, I removed the second.
#220 jco23
jco23
  • 414 posts
Posted 09 May 2013 - 05:50 PM
I think you said in a prior post that it could be fixed via build.prop edit. Can you confirm? As we could probably make that edit ourselves.
Thanks.
ROM: OSE KitKat 4.4.2
