Best Answer kang , 03 May 2013 - 03:13 AM
You can wipe everything by doing a factory data reset...... the option for that should be found in recovery....or from home screen hit menu/system settings/privacy/factory data reset....
This should reset the phone back to all factory settings and you will need to re set up your phone, apps, etc
Thanks, fixed by resetting to factory settings. Go to the full post
