Sticky Bit Fastboot
34 replies to this topic
#1 akg021494
akg021494
Posted 30 April 2013 - 11:25 PM
Im not sure if this topic has been cleared for the droid razr m and i cant get any decent answers. I flashed my phone in october cuz beats audio bricked my phone and ever since its boots into the sticky bit fastboot no matter what i do it still boots up like that. before it really wasnt a problem but no its getting extremely aggravating having to hold the power and volume buttons just to turn my phone on. if any one can help me that would be great. Plus im selling this phone so i want it to be in perfect working condition.
EDIT:
PROBLEM HAS BEEN RESOLVED I FIGURED OUT HOW TO GET RID OF THE STICKY BIT FACTORY_FASTBOOT BULL$#!+ AND NOW MY PHONE TURNS ON NORMALLY... f%$kING FINALLY..(PARDON MY LANGUAGE BUT IM EXTREMELY EXCITED NOW MY PHONE IS IN FULLY PERFECT CONDITION.
Edited by akg021494, 01 May 2013 - 12:11 AM.
  • mauri6870 and siulm3 like this
#2 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 01 May 2013 - 01:30 AM
What did you do to fix it?  The solution will help out other people.  Also post the solution in your thread on XDA, you'll help a lot of people.
#3 akg021494
akg021494
Posted 01 May 2013 - 02:56 AM
]Make sure you have the latest usb drivers installed  (also this wont relock you bootloader if you unlocked it already, this will wipe your date so back it up)
you can download them here:
just click on USB drivers for devices.
you can download the android file here:
First you want to download this zip file extract the file to your computer so it should read C:\Android
Next click on it once so it's selected hold left shift and right click and click on "open command window here"
Now plug in you phone and boot it up normally, then make sure usb debugging is enabled.
now in the command window type "adb devices" (this makes sure your device is hooked up and ready to be fixed)
List of commands to type in. ( in order)
1. adb reboot bootloader
2.fastboot oem fb_mode_set
3.fastboot oem fb_mode_clear
3.fastboot erase userdata
4.fastboot erase cache
5.fastboot reboot
thats all your phone should bootup normally (like when you first bought it ;) ) or like me i get the warning unlocked bootloader blah blah then phone boots up.
if you dont have an unlocked bootloader you can unlock it by typing the command fastboot oem unlock
decided to take matters in my own hands instead of searching my A$$ of to find solutions.
  498.82KB   564 downloads
  510.27KB   620 downloads
  23.11KB   511 downloads
  • calebgoesbig, anand9892, fsaikano and 8 others like this
#4 Aixelsyd
Aixelsyd
    Freak on a Leash
  • 640 posts
  • LocationWindy City
Posted 01 May 2013 - 04:21 AM
^^^^^ FYI fastboot oem unlock only works on a Developers Edition Razr M. A consumer verison from VZW will NOT unlock using that command. To unlcok a consumer version Razr M you need to use the unlock process Dan J put out and is posted here on DR.
  • shane1 likes this
#5 akg021494
akg021494
Posted 01 May 2013 - 01:18 PM
didnt know that
#6 jasalomonc
jasalomonc
Posted 24 August 2013 - 11:34 AM
Thanks a lot, I had the same problem as you.
All solved now.
#7 alanmarques
alanmarques
  • Current Device(s):Razr HD (XT925)
Posted 25 September 2013 - 06:18 AM
Thank you, I followed all the steps and it worked perfectly.  :D
#8 Someolddude
Someolddude
  • 426 posts
Posted 25 September 2013 - 05:51 PM
Hmmm wonder if doing this will solve my little problem with 4.3 ROMs not rebooting without formatting data.
#9 Someolddude
Someolddude
  • 426 posts
Posted 27 September 2013 - 03:47 AM
That's a no if anybody wondered also. Tried last night and all went good only when it rebooted it got stuck at the boot animation. Waited 20min and figured if it didn't fully boot by then it wasn't going to.
#10 tabasco
tabasco
  • Twitter:TabascoTX
  • LocationTexas
  • Current Device(s):Atrix HD
Posted 22 November 2013 - 10:56 AM
Fastboot Comands totally saved my rear end akg021494..Thanks a bunch!!!!!!!
#11 mcassedy
mcassedy
Posted 15 January 2014 - 12:41 PM
Awesome, the only thing that worked!
#12 anand9892
anand9892
  • Current Device(s):razr m xt907
Posted 31 January 2014 - 09:28 PM
u saved my razr m
thnks a lot
#13 frankp1979
frankp1979
  • Locationbingo
  • Current Device(s):pager
Posted 17 February 2014 - 08:29 AM
YOU ROCK!!! SAVED ME A BUNCH OF BEING PISSED
#14 mauri6870
mauri6870
  • Current Device(s):Razr M
Posted 18 June 2014 - 05:34 PM
You're the boss OP!
Sorry for necroing this thread.
#15 Aizarxplosiv
Aizarxplosiv
  • 7 posts
  • Current Device(s):Motorola Droid Razr M
Posted 15 July 2014 - 06:46 AM
Only two commands are needed to get you out of the Stick bit Fastboot which are listed below:
adb reboot bootloader or goto the fastboot by holding (power key + both the volume keys together) and then releasing the power key.
1. fastboot oem fb_mode_set
2. fasboot oem_fb_mode_clear
Then simply reboot your Droid either by using power key or by using command
fastboot reboot
And you will be able to solve your problem without data loss.
  • calebgoesbig and homo123 like this
#16 dee3
dee3
Posted 27 July 2014 - 12:05 AM
Thanks, worked perfect step by step.
#17 flashedinaflash
flashedinaflash
  • Locationsummerville, sc
Posted 01 September 2014 - 05:45 AM
AMAZING!! I have been fighting with this phone for over 8 hours. these commands worked like a charm!!
#18 autumnmystie
autumnmystie
Posted 16 September 2014 - 11:47 AM
Im trying so hard to fix my phone, which is rooted and unlocked, but its showing as offline when I type in adb devices >.< Please help!!
#19 livinginkaos
Posted 16 September 2014 - 12:10 PM
Not really the right thread for this, but follow the directions in
thread.  Your adb pairing security has gotten flummuxed and you need to reset the connection, basically.
#20 autumnmystie
autumnmystie
Posted 16 September 2014 - 12:38 PM
Oh, I figured it was cause im trying to solve my problem using the OP's post but I cant get it to recognize my device :(
