Easy Root for Bionic running stock Jelly Bean
164 replies to this topic
#121 Bratster2
Bratster2
    IDK what I am
  • 560 posts
  • LocationCalifornia
  • Current Device(s):Pixel 2 XL on Google Fi
Posted 13 August 2013 - 08:07 PM
Just got around to rooting JB, Im lazy so I used your utility instead of doing it manually.
Worked perfect!!
Thank you!
#122 mikenoise
mikenoise
Posted 15 August 2013 - 11:21 AM
For added help for numb skulls like me who try to plug in prematurely, perhaps add a line of text after each prompt in Oracle that says "DO NOT PLUG YOUR PHONE IN YET". Then at the correct stage say "WAIT FOR DAEMON TO START SUCCESSFULLY, THEN PLUG IN YOUR PHONE". I finally figured it out, just thought this would help make it idiot proof haha :p
#123 simon_lefisch
simon_lefisch
  • 265 posts
  • Current Device(s):Razr Maxx
Posted 15 August 2013 - 07:03 PM
i know this is a VM but will this work on a mac? im trying to root my friends bionic but su is not taking. i get su installed but when i run TiBu if says root is not acquired. any ideas? thanks
#124 Bratster2
Bratster2
    IDK what I am
  • 560 posts
Posted 15 August 2013 - 09:41 PM
I don't see why not since it is a virtual machine.
You will need to get the Mac version of virtual box obviously.
#125 simon_lefisch
simon_lefisch
  • 265 posts
Posted 15 August 2013 - 09:45 PM
yea i tried it on VB and no go. it said it pushed everything but TiBu cant access root :/ gonna try another method. if anyone else has any ideas why please let me know. thanks
#126 Mange
Mange
    Freakin' Noob
  • 212 posts
  • Google+:goofballone@gmail.com
  • LocationThe Evergreen State
  • Current Device(s):Pixel XL
Posted 01 September 2013 - 02:20 PM
Worked perfect!!
Thank you!
Yup here too. Still working well. Huge Thanks to everyone involed.
#127 jjkoolaid
jjkoolaid
  • 31 posts
  • Current Device(s):bionic
Posted 02 September 2013 - 04:00 PM
I've tried under bridged and I don't have an option under name. Under NAT I can actually get an IP but I can't get my phone to connect. I'm lost. I'm sooo tired of stock I'm loosing my mind. Help. Do I just need more sleep to figure it out?
#128 transmissiontech
transmissiontech
    Your Tranny Specialist
  • 7,484 posts
Posted 02 September 2013 - 04:20 PM
You have to have your computer and cell both connected to same WiFi connection.
Google pixel 32 gig....
#129 jjkoolaid
jjkoolaid
  • 31 posts
Posted 02 September 2013 - 05:02 PM
Yeah, same wifi at my house. On nat is the only one that goes through. Then I go into files and remote storage enter info and phone says no connection.
#130 jjkoolaid
jjkoolaid
  • 31 posts
Posted 02 September 2013 - 05:08 PM
Sorry, under bridged network and then in name I have no option so I can't use that one. I run it under nat and has Linux IP then I go into remote storages on my phone and enter in the info as it says no connection after a bit on my phone
#131 jjkoolaid
jjkoolaid
  • 31 posts
Posted 02 September 2013 - 05:19 PM
Uninstall and reinstall to see if that helps
#132 jjkoolaid
jjkoolaid
  • 31 posts
Posted 02 September 2013 - 05:56 PM
I'm going to apologize right now. When installing virtual box...install everything. Numerous droid x's, x2's evo's and bionics that I've done this was new to me. And I would like to thank everyone who made this possible and trans tech for a quick reply.
  • B.E.McAllister and transmissiontech like this
#133 Jackal1983
Jackal1983
Posted 08 September 2013 - 05:34 PM
Just did this  on my new(ish) bionic. 3 things: Timing is key for the hardware button step. Too late and you'll only get partial root (Su binary update in SuperSU will fail if you are too late). Wait for the daemon to start before attaching the phone, too!!! If you're running a HP DM1Z with the AMD APU combined CPU/GPU and you keep getting BSODs in VirtuaBox, try running the .ova on a Mac. It worked for me.
#134 kellym
kellym
    Droid Oracle
  • 2,794 posts
  • Google+:kellym
  • LocationNY
Posted 17 September 2013 - 05:45 PM
I keep getting the error message to update the SuperSU binary.  I believe I've done all other steps correctly, the phone vibrates like crazy.  I've tried uninstall superuser from any files I can find (old rom files after I deleted safestrap).   Last week I visited HOB and did an FXZ with the keep data option.  I am totally stumped, have done this process at least a dozen times and end up with the update binary error message each time.  Help, please.
#135 livinginkaos
Posted 17 September 2013 - 05:49 PM
Have you used the new house of moto.....
From My S4 Dev Edition
#136 kellym
kellym
    Droid Oracle
  • 2,794 posts
  • Google+:kellym
  • LocationNY
Posted 17 September 2013 - 05:57 PM
No, I saw some talk of it in the Lair.  I was using Marty's Sun virtual box method above.  I assume I can find the house of moto on the main forum page?  Thanks, Kaos, for responding so quickly.
#137 livinginkaos
Posted 17 September 2013 - 06:00 PM
Also, I would suggest reflashing system and try again.
#138 marty45714
marty45714
  • 45 posts
Posted 17 September 2013 - 06:03 PM
So is my method finally deprecated??? Well, if so it had a good run!  :p
#139 kellym
kellym
    Droid Oracle
  • 2,794 posts
  • Google+:kellym
  • LocationNY
Posted 17 September 2013 - 06:04 PM
I think you're right, something is lingering and causing issues.  Just went over to House of Moto and am DEFINITELY heeding Sam's advice.  I need to read some more, there are a few steps I'm unfamiliar with.  Hope to see you on the forum tomorrow. xo
  • SamuriHL likes this
#140 kellym
kellym
    Droid Oracle
  • 2,794 posts
  • Google+:kellym
  • LocationNY
Posted 17 September 2013 - 06:07 PM
I hope not!  A girl has to have choices!  Everything runs flawlessly (well almost, anyway, lol).  Having never used any VM before, your instructions made this a very simple process to follow - thank you!  I've spent hours, literally, today, trying to get past the updated binary message.  But this is my fault, not yours.
  • Int_Rnd_Pooka likes this
