Easy Root for Bionic running stock Jelly Bean
164 replies to this topic
#61 transmissiontech
transmissiontech
    Your Tranny Specialist
  • 7,484 posts
Posted 04 May 2013 - 08:49 AM
Im having network issues...Invalid IP address.....im using a mifi(EVDO) for my wireless broad band server which my phone and computer connects wirelessly. I have selected each one of the options and to no avail.
Google pixel 32 gig....
#62 transmissiontech
transmissiontech
  • 7,484 posts
Posted 04 May 2013 - 02:18 PM
I guess no one has an answer ...sooo i guess i dont root....im on windows 7 64 bit to.
#63 SgtShockah
SgtShockah
  • 9 posts
  • Twitter:PHatwatts
  • Current Device(s):Bionic, Nexus 7, Galaxy Tab 2 10.1
Posted 04 May 2013 - 05:24 PM
I was running into the same issues for a couple of days and finally got it to work. Can't guarantee it'll work for you but here's what I did: After trying all of the listed "names" I opted to try switching "Bridged" to "NAT" as mentioned earlier in this thread. That change got me past the "InavlId IP" error but I was unable to connect to the phone as it wasn't on the same subnet as my laptop. I restarted the VirtualBox, went back to "Bridged" and went thru the "name" options...miraculously the process went through and I'm rooted once again as confirmed via Root Checker Basic. Give it a shot...it just might work.
@marty45714 Thanks for the assist!!
#64 jpr9845
jpr9845
    JPR9845
  • 102 posts
  • Twitter:jpr9845
  • Google+:jpr9845
  • LocationSan Diego
  • Current Device(s):Samsung Galaxy Note 4
Posted 04 May 2013 - 06:18 PM
Posting this for anyone that's having issues getting rooted. This may help discover what is happening:
Here are some tips that I posted for someone over on Droid Forums. Hopefully some of this will help us figure out what is going on:
Need you to do some investigation. Run the exploit again. Once your phone is connected to the SMB share and the Linux script verifies the connectivity, press Ctrl-C to break out of the script and return to the Linux command prompt. Make sure your phone is connected to USB. From there execute the following commands and share the output with me:
sudo ash
cd /home/guest/share
./adb.linux shell
(if you execute the above command and DO NOT see this prompt: shell@cdma_targa/ $
then you have USB connectivity issues and need to make sure you get your phone successfully connected
to VirtualBox and the Linux VM)
ls -l /storage/rfs0
I want to see the output of the "ls" command to verify that the SMB share is being mounted to /storage/rfs0
This can cause the exploit to fail is it's not.
If you see no output from that command, run this command:
find /storage -name pwn
If you get that far and this looks good. Can you type:
su -
and see if you get a root prompt? A root prompt means your prompt will end with '#' instead of '$' before the cursor.
If you do get this, it could be that your Superuser app is simply broken and need re-installed.
The command that the exploit runs to root the phone, once you get this far is:
/storage/rfso/pwn 1
You can try running that manually and see what happens.
I cannot get VirtualBox/LinuxVM to see my USB connection. I have tried all USB port, each time the PC sees the phone offers Verizon backup assistant and autoplay opens asking me what to do. But nothing from the VM. Phone is connected as Media device (MPT) and Developer options are on with USB debugging enabled. What I see on VM screen at this point
Waiting for phone to be connected to USB...
Please plug in the pone or troubleshoot your Virtualox USB connectivity.
When I check Devices/USB Devices/Motorola XT875 (0216) I get the following in a dialog box titled VirtualBox error
Failed to attach the USB device Motorola XT875 [0216] to the virtual machine Linux Minimal.
USB device 'Motorola XT875' with UUID {1e169170-54ba-4a5f-bdcd-6637330e312d} is busy with a previous request. Please try again later.
Result Code: E_INVALIDARG (0x80070057)
Component: HostUSBDevice
Interface: IHostUSBDevice {173b4b44-d268-4334-a00d-b6521c9a740a}
Callee: IConsole {db7ab4ca-2a3f-4183-9243-c1208da92392}
#65 transmissiontech
transmissiontech
  • 7,484 posts
Posted 04 May 2013 - 06:44 PM
Im hanging at dameon started sucssefully , now its just sitting there..i think i screwed up plugging in my phone before i started...down at the bottom is like 2 little monitors and a green light flashing sometimes.
Got it i think...superuser app says no superuser policys..binary's need updating. Updated superuser and hit install ...now says there was an error installing superuser.
#66 transmissiontech
transmissiontech
  • 7,484 posts
Posted 04 May 2013 - 07:25 PM
In my remote storage i have adb   busybox pwn run.sh su and superuser apk...but i cant get superuser working.
#67 jpr9845
jpr9845
    JPR9845
  • 102 posts
  • Twitter:jpr9845
  • Google+:jpr9845
  • LocationSan Diego
Posted 04 May 2013 - 07:28 PM
I finally got this to work for me. I unplugged an USB device (webcam) and used that port for plugging in my XT875, viola VirtualBox USB driver installed phone recognized. Phone successfully rooted.
#68 transmissiontech
transmissiontech
  • 7,484 posts
Posted 04 May 2013 - 08:02 PM
Im rooted...i uninstalled everything and reinstalled it and it all worked out...thanks
#69 greggor01
greggor01
Posted 05 May 2013 - 12:24 PM
Anyone have issues connecting your bionic so that VirtualBox recognizes it?  I am completely unable to have VB find my phone.
As per Marty's post later in the thread, I ran:
sudo ash
and I get ash: cd: can't cd to home/guest/share
If i go to the devices menu, the motorola xt875 is under USB, but there is also an unknown device (not sure it matters).
If I select moto xt875 I get this:
USB device 'Motorola XT875' with UUID {0ae987f6-1333-4190-8a5e-bf3f7fedc68a} is busy with a previous request. Please try again later.
Result Code: E_INVALIDARG (0x80070057) Component: HostUSBDevice Interface: IHostUSBDevice {173b4b44-d268-4334-a00d-b6521c9a740a} Callee: IConsole {db7ab4ca-2a3f-4183-9243-c1208da92392}
Any ideas guys?
#70 greggor01
greggor01
Posted 05 May 2013 - 12:39 PM
Turns out the issue appeared to be that I was plugged into a USB 3.0 port.  For whatever reason, that wasn't okay.  Things appear to be working now, just waiting for my phone to reboot after the exploit.
#71 greggor01
greggor01
Posted 05 May 2013 - 12:47 PM
Rooted!!  Thanks to everyone!   :)
  • milski65 likes this
#72 CPKIII
CPKIII
  • 8 posts
Posted 07 May 2013 - 03:18 AM
I am rooted, the process was very easy.  Thanks.
 Should I know be able to use Safestrap?    When I launch it on the Bionic I get an error that Safestrap has shut down.
#73 twinkyz1979
twinkyz1979
    Veteran Flasher
  • 188 posts
  • LocationOhio
  • Current Device(s):Motorola Droid Ultra XT1080
Posted 07 May 2013 - 10:30 PM
Did you first uninstall SS Recovery from your phone? Not the app but actually go into the app and uninstall the recovery?  If you did not do this you may have to FXZ back to stock JB and re-root all over again.
This might need to be posted in the opp as it is posted over in the HoB discussion thread if not in the OP over there.
#74 CPKIII
CPKIII
  • 8 posts
Posted 08 May 2013 - 05:47 AM
I was stock JB, never rooted, and no safestrap before.
I downloaded a root checker and it says I do not have root.
I will try the FXZ route and see if It will re-root.
#75 daimonmustdie
daimonmustdie
  • 13 posts
Posted 08 May 2013 - 09:20 AM
rooted :thumbsup:
#76 twinkyz1979
twinkyz1979
    Veteran Flasher
  • 188 posts
  • LocationOhio
Posted 09 May 2013 - 12:56 AM
Let us know how it turns out for you. Maybe you just missed some minor detail in the process.
#77 ksimp88
ksimp88
  • 9 posts
Posted 09 May 2013 - 08:32 PM
Made my life easier! I had the network and usb errors, but the posts in this thread helped! I ended up moving to another usb port, worked like a charm! thx!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11 one
#78 taller238
taller238
  • 6 posts
Posted 11 May 2013 - 08:22 PM
I got the same error when launching the superuser.app "There are currently no Superuser app policies"
I uninstalled the superuser app, rebooted, and re-go through again, but still get the same error.
So what have you uninstalled (i.e. what means 'everything')?
Thanks.
#79 transmissiontech
transmissiontech
  • 7,484 posts
Posted 11 May 2013 - 09:16 PM
I had to uninstall and reinstall the virtualbox and the ova and then that part worked...but with the superuser problem i uninstalled superuser and installed superSU and all worked fine...i like superSU personally.
  • livinginkaos likes this
#80 jalh
jalh
Posted 13 May 2013 - 06:08 PM
Hello everyone, I tried the virtual image and I got this error. Any work around ?
