[Cdma Razr][Ics] Rom | Axi0M Cmplx | Ics Leak | Modifier | By Droidth3Ory
140 replies to this topic
#121 theonlycosmic
theonlycosmic
  • 470 posts
  • LocationCalifornia
Posted 22 April 2012 - 08:29 PM
will this be a step stool to a 1 percent battery mod? has anyone come across one for the leak? ive tried to look but all i got is the circle battery that shows percentage.
There is no battery mod that uses 1% increments for the leak yet because it is not deodexed. Once devs deodex the leak then we will see one later on.
#122 benefit14snake
benefit14snake
  • 232 posts
Posted 01 May 2012 - 04:38 AM
Just a heads up....
Yesterday i flashed this on .84 leak and it works awesome!!! Over 480mb ram free on reboot.
If you do this it is at your own risk.
This may inhibit any fixes the devs find to get you back on the upgrade path (it may not..)
Read the op
Install ics razr bootstrap
Made a nandroid backup
Reread op
Wipe cache
Wipe delvik cache
Flash it!
Reboot and enjoy.
Thanks again DT!
Sent from my Axiom MAXX!!
#123 claps1775
claps1775
  • 596 posts
Posted 01 May 2012 - 06:13 AM
Will this work on .75 ics leak?
Sent from my DROID RAZR using Tapatalk 2 Beta-5
#124 benefit14snake
benefit14snake
  • 232 posts
Posted 01 May 2012 - 06:18 AM
That is what it was designed for my friend.
#125 theonlycosmic
theonlycosmic
  • 470 posts
Posted 01 May 2012 - 10:38 PM
Okay so does this ROM work with CWM on boot? I had issues with it in the past.
#126 civichater
civichater
  • 5 posts
Posted 02 May 2012 - 04:29 AM
I just flashed this over the. 84 leak too. Followed the directions in the OP and had no problems. Since I'm stuck in this for now, might as we'll make the best of it.
#127 Guest_ezcats_*
Guest_ezcats_*
Posted 02 May 2012 - 07:54 PM
can someone post a mirror? the link isn't working and droidhive sign in is down
#128 holla
holla
  • 68 posts
  • Locationatlanta,Ga
  • Current Device(s):DNA
Posted 03 May 2012 - 08:31 AM
here u go try this 1
click on axiom then u should see it. :D
#129 Guest_ezcats_*
Guest_ezcats_*
Posted 03 May 2012 - 05:00 PM
thanks...is there a known problem with this and safestrap? it just flashed to a black screen...it wont boot at all
edit: i think it is...i flashed it with bootstrap and its awesome! thanks!
#130 Guest_ezcats_*
Guest_ezcats_*
Posted 05 May 2012 - 09:50 AM
anyone on 85 tried this yet?
#131 Gerland the Oracle
Gerland the Oracle
    Co-Owner and Support Specialist for Team Rage
  • 212 posts
  • Twitter:gerlandh
  • Google+:gerland.hardin@gmail.com
  • LocationJerome, Idaho
Posted 07 May 2012 - 10:33 PM
Yes it worked on .85, not certain what it did for me but it didnt brick my phone and under system it said thats what i was running.
#132 Gerland the Oracle
Gerland the Oracle
  • 212 posts
  • Twitter:gerlandh
Posted 07 May 2012 - 10:36 PM
Used Bootstrap for ICS for it, if thats any help?
#133 holla
holla
  • 68 posts
Posted 08 May 2012 - 12:19 PM
It removed some of the vzw bs apps u
#134 david.hughes27909
david.hughes27909
  • 5 posts
Posted 09 May 2012 - 04:07 PM
Stuck on Android is Upgrading... Starting Applications? Any ideas 10 mins strong.
#135 Guest_BDH_*
Guest_BDH_*
Posted 10 May 2012 - 12:44 AM
Reboot
#136 BigJArm
BigJArm
  • 212 posts
  • LocationIdaho
Posted 27 May 2012 - 09:26 PM
Just incase anyone is wondering. This works with 206. It takes the good stock 206 and makes it awesome.
#137 mcjonesy
mcjonesy
  • 24 posts
Posted 04 June 2012 - 06:54 AM
FYI it works on .208 as well.
This is where I would tell you which ROM I'm running, but I probably just flashed something else.
#138 ncwildcat
ncwildcat
  • 109 posts
Posted 07 June 2012 - 02:55 PM
Tried this on 206 and 208....both times I noticed my battery life was significantly worse...like 12 hours in maxx...took it off and I am back to 18...
#139 crpp2401
crpp2401
  • 40 posts
Posted 07 June 2012 - 11:42 PM
Please i need a mirror
  • crpp2401 likes this
#140 atxgurl
atxgurl
  • 69 posts
  • LocationAustin, Texas
Posted 08 June 2012 - 07:06 AM
When I tried the modifier script on .79 I was no longer able to update SuperUser Binaries due to a constant CRC error. Can someone confirm this is working by going into SuperUser > Settings > Update Binaries ?
Posted Image Keep Austin Weird!!
